Data inscrierii: 31 Mar 2006 Mesaje: 5565
Trimis: 14 Feb 2013 15:05 Download mesaj |
De data asta nu am sa mai pun o lectura ci imaginea unui instrument care mi-a placut in mod deosebit.
Luneta din imaginea de mai jos e construita de un amator din Michigan si este echipata cu un obiectiv acromat Jaegers de 50mm si raport focal 20.
Constructorul ei spune ca a investit 300 de ore de munca in aceasta bijuterie:
PS. Se vede ca mai avem multe de invatat! ...
Descriere: |
Marime fisier: |
157.08 kb |
Vizualizat: |
de 19481 ori |
Teo Membru
Trimis: 19 Feb 2013 00:40 Download mesaj |
O luneta de 6 inch cu f/15 construita de la zero.
Obiectivul este facut de un amator ( daca se mai poate numi amator un astfel de om... )
Are toata admiratia mea !
Va dau mai jos linkul. Sunt de urmarit toate paginile pana la final unde se arata si luneta finalizata.
Iata linkul :
http://www.cloudynights.com/ubbthreads/sho...art/8/vc/1
Data inscrierii: 12 Feb 2008 Mesaje: 9081
Teo Membru
Trimis: 28 Feb 2013 00:23 Download mesaj |
Ceva util si instructiv :
http://www.rfroyce.com/refractor%20spots.htm
si aici :
http://www.rfroyce.com/refobs.htm
" Without getting into details, secondary spectrum increases both as the focal ratio decreases and aperture increases. An 8" f/15 will make more secondary spectrum than a 6" f/15. In fact, an 8" refractor will have to work at f/18 to be as achromatic as the 6" f/15. "
" We do not recommend the construction of refractor objectives for serious planetary or lunar astronomical work in ratios less than f/15. This has been considered the nominal standard for acceptable performance since the mid 1800s when the Clarks began making virtually all of their refractors in focal length to aperture ratios of 15 to 1. However, the use of the BaK1 glass does allow for f/12 focal ratios in 6" sizes if customers insist - though f/15 is still preferred. I am occasionally asked to make refractors of 6" and 8" at f/10. I avoid the production of these refractors inasmuch as they will invariably produce a rather strong secondary color spectrum. The ability to recognize secondary color is interesting in that while some people do not see it at first, progressive use of the instrument and an increasing skill and awareness will eventually result in dissatisfaction. The existence of secondary color is nothing more than a defocused blur in the red and blue and a loss of contrast and information. "
Se pare ca la lunete acromate cu apertura de 6 inch, cel putin un raport f/15 ar fi de dorit pentru observatiile planetare si selenare, iar la cele cu apertura de 8 inch, un minim de f/18 ar fi ideal .
Desigur, pana la urma pentru corectarea cromatismului mai intervine si tipul de sticla utilizat.
Totusi, asta nu inseamna ca valorile de f/10- f/12 nu ar fi bune pentru lunetele acromate cu aperturi mai mici de 6 inch.
Totul consta pana la urma in a construi, a experimenta si a observa.
Satisfactia vine la final cand indrepti telescopul spre cer.
Ultima modificare efectuata de catre Teo la 28 Feb 2013 00:54, modificat de 1 data in total |
Trimis: 03 Mar 2013 13:45 Download mesaj |
Am gasit aseara inca un review, relativ "proaspat" pentru luneta acromata de 102/1100 fabricata de United Optics. Cred ca merita parcurs. Review-ul e semnat de Raphael Braga:
http://translate.googleusercontent.com/tra...ZfV6LqIA6w
Trimis: 11 Mar 2013 23:15 Download mesaj |
In alta parte a acestui forum a fost proclamata incapacitatea unei lunete de 50mm de a prezenta diviziunea Cassini.
Am sa las imaginile sa vorbeasca,spunand ca il pomenim aici pe Charles Grower si luneta sa de 50mm F=900mm deci F/18.
Evident,aceea a fost o excelenta luneta,dar ce avea Charles si ce au ,,...urmasii Romei'' e deja o alta poveste.
Descriere: |
Marime fisier: |
56.68 kb |
Vizualizat: |
de 19206 ori |
Descriere: |
Marime fisier: |
62.84 kb |
Vizualizat: |
de 19206 ori |
Descriere: |
Marime fisier: |
57.02 kb |
Vizualizat: |
de 19206 ori |
Descriere: |
Marime fisier: |
157.17 kb |
Vizualizat: |
de 19206 ori |
Alexandru Savin Membru
Data inscrierii: 09 Mai 2011 Mesaje: 464
Trimis: 22 Noi 2013 11:42 Download mesaj |
Chestia aia portocalie stie cineva ce e? Banui ca e un catadioptric ce seamana cu MTO-ul lui Erwin
Mi-a starnit grav interesul !
O zi buna!
Alexandru
