Numar total de mesaje in forum: 242784
Cei mai multi utilizatori conectati au fost 1604 la data de Joi Aug 27, 2026
Alimentare priză Celestron 130 SLT
MesajTrimis: 29 Iun 2010 12:38 Download mesaj
Majoritatea monturilor care au tensiune de alimentare nominala de 12V pot fi alimentate cu tensiune pana la 15V. Scrie in prospectul lor. Asa ca alimentarea de la un acumulator nu constituie un risc. Eu am utilizat-o ani in sir, si nu sunt probleme.
MesajTrimis: 29 Iun 2010 14:18 Download mesaj
Daca scrie este OK. Doar ca acest caz nu face parte din "majoritatea monturilor". Cand afirmi ceva atat de general e bine sa dai si referinte. Cam asa:
Celestron NexStar SLT INSTRUCTION MANUAL
http://www.celestron.com/c3/images/files/d...manual.pdf
Input Voltage 12 V DC Nominal
Batteries Required 8 AA Alkaline
Power Supply Requirements 12 VDC-750 mA (Tip positive)
What are the specifications for an AC adapter that will work with Celestron’s GOTO mounts?
http://www.celestron.com/c3/support3/index...cleid=2254
Most of Celestron’s GOTO mounts will work with an AC adapter that has these characteristics:
12VDC output
2.5 amps (2500 milliamps) current output
Inside tip positive
Inside diameter is 2.1mm
Outside diameter is 5.5mm
Jack length 10-15mm
Some smaller mounts might work with adapters with less amperage output. Our largest, newest mount , the CGE Pro, works best with adapters delivering 3.5 amps maximum or higher.
Celestron GOTO mounts need 12 volts direct current power to work at their best. Voltages that are too low may turn on the hand control but will either not run the motors or lead to erratic behavior. Voltages that are too high can damage the electronics or even cause burning of the circuit boards. Exclamation
MesajTrimis: 29 Iun 2010 15:39 Download mesaj
Oricine a lucrat efectiv, stie ca orice sursa in gol, ca e o baterie noua, sau un acumulator proaspat incarcat da o tensiune mai mare decat cea nominala. Si asta o stiu si cei care proiecteaza aceste monturi. Mai mult, exista normative care prevad tolerante la care trebuie sa reziste TOATE aceste circuite.
Evident ca e o mica diferenta. E una sa iei aparatul de masura si sa faci niste masuratori cu propria mana, si alta e sa cauti pe net incercand sa creezi impresia ca le stii pe toate.
MesajTrimis: 29 Iun 2010 16:25 Download mesaj
dragos.n a scris:
Acest lucru este valabil doar la sursele nestabilizate low-cost. Si functioneaza un pic invers ... tensiunea scade de la valoarea nominala dupa cum cresti curentul datorita rezistentei interne a sursei.
dragos.n a scris:
Care sunt acele normative ?
dragos.n a scris:
Eu masor, nu cu mana, ci cu osciloscopul pentru a prinde si fenomenele tranziente.
dragos.n a scris:
Eu am vrut sa ajut cu ceea ce stiu. E interzis "sa cauti pe net" ori sa sustii cu referinte ceea ce afirmi ?? Deranjeaza informatiile ? Ori asta este echivalent cu incercarea sa creezi impresia ca le stiu pe toate ? Ce as avea de castigat ? Ne cunoastem personal ca sa-ti permiti sa afirmi ceva despre persoana mea ? Stii ce stiu si ce nu stiu ? Nu cred.
Oricum, una e sa moderezi si alta sa insinuezi. Bravo !
Te rog sa dovedesti, in mod explicit, ca nu stiu despre ce vorbesc inainte sa aduci acuzatii personale din pozitia de moderator!
MesajTrimis: 29 Iun 2010 16:28 Download mesaj
Într-adevăr, Dragoș, din practica de radioelectronică am observat destul de des această diferență dintre tensiunea nominală și cea măsurată efectiv cu voltmetrul fără sarcină. Cred că în cazul nostru cea mai importantă este stabilizarea sursei având în vedere consumul de curent variabil când se orientează montura pe ambele axe cu viteză mare și când e pe urmărire și merge doar un motor la turație mică. Este importantă de asemenea protecția la scurt-circuit a sursei, mai ales în cazul în care se montează și demontează des.
MesajTrimis: 29 Iun 2010 16:34 Download mesaj
Da, protectia la scurt circuit e necesara.
creizi
Data inscrierii: 04 Feb 2009
Localitate: București
MesajTrimis: 29 Iun 2010 16:39 Download mesaj
Deci, în concluzie, așadar, deși merge și fără acel montaj, e mai bine cu.
Întrebare de greenhorn a la Karl May, Eu ce voi cere la magazinul de electronică? Embarassed Mă duc cu schema prezentată de nobody?
Black holes are where God divided by zero.
MesajTrimis: 29 Iun 2010 16:49 Download mesaj
Poti sa te duci cu acea schema. Eu insa am optat de mult pentru acumulatori cu plumb, de 12V/7Amh, si a mers foarte bine.
MesajTrimis: 29 Iun 2010 16:53 Download mesaj
Am fost chiar ieri pe str.Maica Domnului pe la magazinele de electronice, cam toate au surse de tensiune, cele de tip mai nou sunt toate în comutație, implicit sunt stabilizate, sunt ușoare, similare cu cele de laptop și au curent mare. Sunt protejate la scurt-circuit, asta întrebi la magazin, ceri sursa 12V/2,5-3A. Tot acolo am văzut acumulatori sealed-acid sau cu gel de diferite mărimi, până la 17Ah. Atenție, sunt atât de 6V cât și de 12V. Dacă iei acumulator ai nevoie de un încărcător potrivit, găsești tot acolo.
MesajTrimis: 29 Iun 2010 17:35 Download mesaj
@creizi: E alegerea ta. Unele merg, altele se prajesc. Se mai prajesc si alea care merg daca incurci polaritatea. Producatorul da prea putine detalii despre limite si sa te joci cu ele e cam loz in plic. De obicei necastigator. Wink
Aceea nu este o schema ci sunt specificatiile circuitului integrat care face stabilizarea. S-ar putea (mai mult ca probabil in Romania) sa nu gasesti un modul bazat exact pe acel circuit integrat. Sunt mii de variante. Ceva echivalent iti trebuie.
Daca nu se descurca, ceri e un modul de stabilizare a tensiunii (DC-DC) la 12V, 1A ce lucreaza cu diferenta de tensiune mai mica de 0.5 V.
Sa NU fie facut cu integratul 7812, care este foarte des folosit dar care are nevoie de minim 2 V diferenta.
Ca idee, cam asa arata unul home-made:http://blog.makezine.com/upload/2009/02/voltReg.jpg
Unul mai industrial: http://www.ereshop.com/images/ere/pw78.jpg
(asta are si punte redresoare de care tu nu ai nevoie, chiar te incurca dar n-am gasit la repezeala alta poza)
Ori daca stii sa lipesti 2 fire poti folosi modulul electronic dintr-un convertor DC-DC in comutatie universal pentru masina.
Poate cei de la magazinele auto au ceva ce nici nu trebuie modificat.
http://www.vitacom.ro/Products/28761/P_SUP...00-mA.html
MesajTrimis: 29 Iun 2010 18:02 Download mesaj
@nobody sursele stabilizate de la vitacom sunt bune?
MesajTrimis: 29 Iun 2010 18:52 Download mesaj
Pai cam ca peste tot in Romania. Ce se cere: chinezarii ieftine dar care functioneaza fara sa fie bataie de joc. Dpdv electronic fac ceea ce spun ca fac. Dpdv mecanic si de aspect lasa mult de dorit.
Eu nu mai cumpar de la Vitacom (mai bine zis din Romania) de vre-o 5 ani dar functioneaza si in ziua de azi tot ce am luat de la ei. Asta include si cateva convertoare DC-DC, DC-AC pe care se poate zice ca le-am abuzat destul de serios. Deci chinezarii decente cu conditia sa nu cumperi chiar ce-i mai ieftin.
cmatei
Data inscrierii: 09 Sep 2009
MesajTrimis: 29 Iun 2010 20:33 Download mesaj
"Car adapter"-ul de la celestron e un simplu cablu. celestron #18769. O baterie de masina, in masina sau afara, e absolut ok.
Altfel, eu am la telescop o sursa stabilizata de 13.8V/3A (sunt de 13.8 ca sa poti incarca si baterii cu ele) luata de la conex (unul din magazinele de pe maica domnului). Daca alegi calea asta, gandeste-te daca nu vrei una mai mare - pentru potentialele accesorii suplimentare (dew heaters, montura mai mare, camera CCD racita Smile Mai au o sursa de 6A si una de 10A, dar 10A e deja mult.[/url]
MesajTrimis: 29 Iun 2010 22:03 Download mesaj
Bateriile cu gel si cele cu calciu se incarca la tensiune mai mare, undeva intre 14.5-15.0 V. Cele normale intre 14.2-14.5 V.
Trebuie sa scrie pe ea tensiunea de incarcare (la cele cu gel).
A nu se confunda cu "float voltage" care este tensiunea de mentinere dupa ce s-a incarcat complet.
La o tensiune mica bateria se incarca doar partial.
MesajTrimis: 30 Iun 2010 12:26 Download mesaj
Revin cu informatii ce le-am gasit pe alte forumuri (de pe net, e mai greu sa discuti cu fiecare in parte de prin toate colturile lumii) referitor la problema alimentarii.
- unele monturi mai vechi functioneaza chiar si intre 8-18 V semn ca ori au convertor DC-DC intern, ori au o electronica mai simpla putin sensibila la variatii de tensiune
- la cele cu GoTo s-a observat ca functioneaza diferit daca se alimenteaza chiar cu o diferenta de 1V fata de tensiunea nominala. Incep sa aiba erori de pozitionare ori sa varieze viteza de deplasare semn ca nu au un stabilizator prea grozav
- unele module GPS pur si simplu se blocheaza (nu se ard) la o tensiune mai mare de 13 V
- exista oameni care efectiv si-au prajit hand-held-ul cand au alimentat direct de la bricheta de masina, la propriu cu fum si cablaje topite
- multi se plang de solutiile date de Celestron la alimentare in special de acel PowerTank portabil
- tot referitor la Celestron se recomanda inlocuirea mufei de alimentare coaxiale deoarece, se pare, este de proasta calitate, nu face bine contact si creeaza probleme ciudat la tensiune redusa ori la miscari ale cablului
- multi si-au rezolvat problemele ciudate prin folosirea unui convertor DC-DC stabilizat cu tensiunea maxima de 12.8 V
- in general, se recomanda folosirea unui alimentator ce scoate minim 2.5 A chiar la monturile care precizeaza un curent maxim de 1 A deoarece apar probleme la initializare ori la pornirea motoarelor cand are varfuri scurte de consum de peste 1A (parca cineva avea o asemenea problema chiar pe acest forum). Vreau sa percizez ca acest fenomen NU se vede cu un multimetru obisnuit ci doar pe osciloscop !
Referinte gasiti cautand, da, pe net. In lumea intreaga. Exista si alta lume.
Nu ma mai chinui sa le dau pentru ca observ ca putini sunt cei care le urmaresc si oricum este subiect de bascalie ieftina.
Ca o buna practica generala, daca nu se cunosc exact limitele tensiunii de alimentare garantate de producator, se alimenteaza cu tensiunea nominala pentru a evita fenomenele ciudate, inexplicabile ce pot aparea, nu neaparat artificii ci supraincaziri, functionarea defectuoasa a motoarelor, blocarea anumitor module mai sensibile, etc.
Nu toate monturile sunt la fel si nici macar asemanatoare. Trebuie luata in calcul si dispersia tehnologica care este mai mare la produsele mai ieftine. Adica monturi de acleasi fel se pot comporta diferit in conditii extreme din care fac parte tensiunea de alimentare, temperatura, incarcarea mecanica, etc.
Ca incheiere, fiecare e liber sa faca ce vrea cu montura si cu aparatura electronica ce o detine. Fiecare evalueaza diferit. Insa generalizarile superficiale, tipic romanesti, de genul "daca mie imi functioneaza" ori "eu n-am vazut si nici n-am auzit ca ar fi vre-o problema" si atunci " ce mi-a functionat mie, functioneaza la majoritatea" nu au nici o valoare informativa in conditiile in care nu se specifica "majoritatea" care poate fi foarte restransa, deci si aplicabilitatea "regulii generale".
Va multumesc daca ati avut rabdarea sa cititi pana la capat.
Creaza un subiect nou   Raspunde la subiect   Lunete/Telescoape Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6  Urmatoare
Pagina 3 din 6
