Sarrah Membru
Data inscrierii: 08 Dec 2013 Mesaje: 362
Sarrah Membru
Sarrah Membru
Sarrah Membru
Trimis: 30 Dec 2013 23:51 Download mesaj |
Problema dei 100.000 Anni: non dovrete temere il caldo, ma il freddo....
http://www.meteoportaleitalia.it/scienze/s...reddo.html
Desigur, asta nu explica totul, dar am mai spus de ipoteza astronomilor Victor Clube si Bill Naipier
in cartea "The Cosmic Serpent" despre care ma incapatanez sa nu vorbesc deocamdata... |
Sarrah Membru
Sarrah Membru
Data inscrierii: 02 Apr 2010 Mesaje: 4817
Trimis: 31 Dec 2013 12:49 Download mesaj |
Am gasit mai multe legaturi intre Svensmark si Antena 3:
Nevertheless, it has been noted by climate scientists actively publishing in the field that Svensmark has inconsistently altered data on most of his published work on the subject, an example being adjustment of cloud data that understates error in lower cloud data, but not in high cloud data.
‘Cosmoclimatology’ – tired old arguments in new clothes http://www.realclimate.org/index.php/archi...w-clothes/
More recently, Laken et al. (2012) found that new high quality satellite data show that the El Niño Southern Oscillation is responsible for most changes in cloud cover at the global and regional levels. They also found that galactic cosmic rays, and total solar irradiance did not have any statistically significant influence on changes in cloud cover. http://journals.ametsoc.org/doi/abs/10.1175/JCLI-D-11-00306.1
Lockwood (2012) conducted a thorough review of the scientific literature on the "solar influence" on climate. It was found that when this influence is included appropriately into climate models causal climate change claims such as those made by Svensmark are shown to have been exaggerated.http://link.springer.com/article/10.1007/s...ltext.html
Sloan and Wolfendale (2013) demonstrated that while temperature models showed a small correlation every 22 years, less than 14 percent of global warming since the 1950s could be attributed to cosmic ray rate. The study concluded that the cosmic ray rate did not match the changes in temperature, indicating that it was not a causal relationship.
Morala:
To ignore aspects that don’t fit the hypothesis is definitely not science.
Neither is adjusting data so to provide a good fit without a solid and convincing justification.
Furthermore, it is only a lack of respect for the readers to publish an article that doesn’t provide all relevant sides to the story. |
Sarrah Membru
Trimis: 01 Ian 2014 13:46 Download mesaj |
Morala ar fi ca asta ai facut in loc sa te distrezi.
Si una din regulile forumului ar fi ca trebuie sa atasezi traducere, limba oficiala a forumului fiind romana. (de citit regulamentul forumului) |
Sarrah Membru
Sarrah Membru
Sarrah Membru
Sarrah Membru
Doru Dragan Membru
Trimis: 10 Ian 2014 22:42 Download mesaj |
Din pacate continui sa ignori sau sa dai cu tifla singurului forumist care pare ca te urmareste cu atentie si iti aduce contra-argumente din cand in cand (nobody). Subiectul este interesant. Si pe mine m-au preocupat problemele catastrofelor cosmice care ameninta Pamantul. E un taram al ipotezelor si (evident) exista mai multe ipoteze care aduc diferite argumente. Exista ipoteza trecerii ciclice a sistemului solar prin bratele Galaxiei, exista ipoteza companionului intunecat al Soarelui etc. Tu pari sa te inspiri dintr-o sursa, vrei sa expui ideile dar nu prea esti receptiva la eventuale critici. In felul asta nu prea se ajunge la adevar. Fii mai flexibila chiar daca cineva (nobody ) "te calca pe nervi" |
Sarrah Membru
Trimis: 10 Ian 2014 22:53 Download mesaj |
Sursa mea e forumul propriu, aici pot expune (din pacate) doar portiuni din studiile climatice, acelea care au tangenta cu esenta forumului...
Multe materiale le-am avut deja, doar le-am postat si aici.
Forum(urile) mele sunt inchise, altii ma vor critica...
Nu trebuie trasa o concluzie, iar concluzia nu poate fi trasa cu lejeritate, cu superficialitate.
Aici am expus poate si materiale din surse mai putin credibile, dar poate un sambur de adevar e si acolo.
Cand cineva trage apa...ti se ia.
Dar tin cont de avertisment! |
Sarrah Membru
Trimis: 11 Ian 2014 09:30 Download mesaj |
Acest topic poate fi inchis, multumesc. |
