2SKY Membru
Trimis: 29 Oct 2015 20:09 Download mesaj |
Vrei sa spui despre un impact cu Pluto ? . Apare ceva pe YouTube .
Data inscrierii: 02 Apr 2010 Mesaje: 5171
Trimis: 29 Oct 2015 20:29 Download mesaj |
Vezi si aici: http://arxiv.org/abs/0901.4882v1
Pluto's lower atmosphere structure and methane abundance from high-resolution spectroscopy and stellar occultations
E. Lellouch, B. Sicardy, C. de Bergh, H.-U. Käufl, S. Kassi, A. Campargue
(Submitted on 30 Jan 2009)
Context: Pluto possesses a thin atmosphere, primarily composed of nitrogen, in which the detection of methane has been reported.
Aims: The goal is to constrain essential but so far unknown parameters of Pluto's atmosphere such as the surface pressure, lower atmosphere thermal stucture, and methane mixing ratio.
Methods: We use high-resolution spectroscopic observations of gaseous methane, and a novel analysis of occultation light-curves.
Results: We show that (i) Pluto's surface pressure is currently in the 6.5-24 microbar range (ii) the methane mixing ratio is 0.5+/-0.1 %, adequate to explain Pluto's inverted thermal structure and ~100 K upper atmosphere temperature (iii) a troposphere is not required by our data, but if present, it has a depth of at most 17 km, i.e. less than one pressure scale height; in this case methane is supersaturated in most of it. The atmospheric and bulk surface abundance of methane are strikingly similar, a possible consequence of the presence of a CH4-rich top surface layer.
CAdi Membru exclus
Motto: Cogito ergo sum
Trimis: 29 Oct 2015 22:43 Download mesaj |
Articolul tau este din 30 ianuarie 2009 si nu este de pe site-ul NASA.
Nu imi amintesc ca New Horizons sa fi ajuns la acel moment pe Pluto.
Articolul pe care il amintesc in link are ultimul upgrade in 30 Iulie 2015 cand deja sonda
New Horizons trecuse la mai putin de 12500 km de planeta.
Intregul complex de date transmise de sonda vor ajunge pe Pamant dupa 4 luni ,adica la sfarsitul lui Noiembrie.
Vom mai vedea atunci ...
La acest moment sonda nu a raportat existenta metanului in atmosfera lui Pluton,doar prezenta
ghetii de metan la suprafata planetei.Asa ca semnele de intrebare raman...
Trimis: 30 Oct 2015 07:31 Download mesaj |
Daca deschideai documentul, poate ti-ai fi dat seama despre ce este vorba si cum a fost detectat metanul gazos din atmosfera lui Pluto, cu mult inainte de New Horizons. Sau macar sa intuiesti ca metanul solid sublimeaza in conditiile de pe Pluto, pana la echilibrarea presiunii de vapori ...
Iar daca ESO nu ti se pare credibil, este si la NASA:
Detection of a CH4 atmosphere on Pluto
http://ntrs.larc.nasa.gov/search.jsp?R=19810041856
Detection of Gaseous Methane on Pluto
http://ntrs.larc.nasa.gov/search.jsp?R=20020032307
Observations.
Both solid and gaseous CH4 absorb in the near infra-red. At sufficiently high spectral resolution, it is possible to distinguish between these two phases because narrow rotation–vibration lines are present only in the gas phase.
CAdi Membru exclus
Trimis: 30 Oct 2015 13:33 Download mesaj |
Articolele mentionate de tine sunt depasite ,sunt din octombrie 1980 ! si ianuarie 1995 !!
Cea mai noua stire este data de NASA pe 31 Iulie 2015 in urma prelucrarii primelor date
primite de la sonda New Horizons.
Ai rabdare pana la receptionarea tuturor datelor,adica pana la sfarsitul lui Noiembrie 2015.
Nici eu nu sunt sigur (pana acum s-a raportat numai metan inghetat la suprafata lui Pluto)
dar vom vedea atunci.
Trimis: 31 Oct 2015 02:01 Download mesaj |
Depasite de ce ? De Facebook sau de Youtube ?
Rezultatele acelor observatii au fost reconfirmate, de mai multe ori, si de NASA, si de ESO, si de altii.
Crezi ca intre timp a disparut tot metanul gazos, iar cel aflat in stare solida la suprafata nu mai sublimeaza ?
CAdi Membru exclus
Trimis: 31 Oct 2015 12:50 Download mesaj |
Acele articole de la NASA se refera la analiza spectrala a luminii venita de la Pluto
care a fost captata de telescoapele de pe Terra si care este prelucrata de un spectroscop.
Metan se gaseste pe Pluto ,dar pe suprafata lui asa cum ne-a transmis sonda New Horizons ,
nu in atmosfera lui Pluton. Acestea sunt datele ... pana acum.
Am sa va spun ce vad eu ca este ciudat la Pluto si totodata poate si cercetatorilor de la NASA
precum Alan Stern si Silvia Protopapa.
In primul rand cateva date cunoscute, transmise pina in prezent de sonda New Horizons ,
despre Pluto:
Pluto are apa inghetata si blocuri mari de metan inghetat la suprafata.
Pluto are o atmosfera densa care se situeaza pana la inaltimea de 114 km.
Ea este alcatuita din azot si monoxid de carbon .In atmosfera lui Pluto predomina o ceata deasa formata din acele tholins,despre care am mai vorbit.
Dupa ultimile date transmise de sonda New Horizons ,Pluto in deplasarea lui pe orbita are o coama alcatuita in principal din azot si pierde cam 500t/s din atmosfera sa in spatiu.
Ce este ciudat la Pluto ?
In principal faptul ca ceata are culoare albastra in bataia razelor soarelui .Apoi faptul ca pe langa
apa inghetata care apare in imaginile transmise de culoare albastra mai sunt prezente si portiuni de la suprafata lui Pluto in care apa are culoarea rosie !
Apoi prezenta acelor macromolecule numite tholins .
Sigur mai exista si sublimarea de care vorbeste Nobody ,dar asta inseamna ca Pluto ar putea avea
izvoare termale subterane de care amintea Teo sau poate un Vulcan activ caci este greu de crezut ca se poate produce o sublimare la -190*C sau la -200*C atunci cand orbita lui Pluto
este mai apropiata de Soare,la periheliu .
O alta curiozitate surprinsa in imaginile transmise de New Horizons este ca masa de gheata isi
schimba forma !
Vorba lui Andi se pare ca Pluto este viu !
Dar daca Pluto are izvoare termale, atunci ,...
CAdi Membru exclus
Trimis: 30 Iul 2020 18:32 Download mesaj |
https://www.impact.ro/descoperirea-care-sc...ign=fidmee
Noi descoperiri dupa analiza fotografiilor transmise de New Horizons spre Terra:
Unii din Vulcanii inghetati sunt mai mari decat Everest!
La suprafata planetei se gaseste apa inghetata!
Muntii de azot inghetat seamana cu coastele Norvegiei!
Pe suprafata planetei exista canioane mai adanci decat Marele Canion din SUA!
Planeta are un Cer Albastru!
Descriere: |
Marime fisier: |
89.41 kb |
Vizualizat: |
de 10516 ori |
_________________ The truth is out there |
2SKY Membru
Trimis: 30 Iul 2020 19:20 Download mesaj |
Ca si compozitie seamana mai mult cu o cometa imensa , resturi de la formarea sist solar, cind corpurile se tot ciocneau , si erau mai calde . Asa este posibil sa aiba materie organica veche de miliarde de ani , dar viata e imposibil . Poate sa aiba si cer in 3 culori ...lumina abia ajunge acolo , in plina zi e ca la noi ~ noapte cu luna plina
CAdi Membru exclus
Trimis: 06 Aug 2020 23:37 Download mesaj |
2SKY a scris: | ...lumina abia ajunge acolo , in plina zi e ca la noi ~ noapte cu luna plina |
Daca e asa, cum si-au dat seama ca cerul este albastru?
Ce inseamna cer albastru?
2SKY Membru
Trimis: 07 Aug 2020 00:11 Download mesaj |
Atmosfera ca si compozitie da culoarea cerului , daca e asa ..albastru inseamna ca are atmosfera . Poate fi si periodic , cind e mai aproape de soare sa aiba alta culoare mai deschisa .
CAdi Membru exclus
2SKY Membru
Trimis: 08 Aug 2020 03:43 Download mesaj |
Nu prea , multe corpuri din sist solar contin apa inghetata si posibil oceane din apa chiar lichida , dar nu au detectat urme de viata , vezi Europa . Cer albastru ... Nori alb/albastri are si Titan https://www.nasa.gov/content/goddard/nasa-...-on-titan/
Pluto are azot si metan in atmosfera . In ce sens viata pe Pluto ? in subsol ? . Savantii si lumea au fost surprinsi de culoriile vii de pe Pluto , dar nu se pune problema sa se creada 1sec ca exista viata . Are compozitia unei comete ca toate corpuriile din centura Kuiper. Daca e de 5 ori mai usor ca luna , inseamna ca nu are miez de fier , nici cimp magnetic protector . Luna la rindul ei contine f putin fier , fiind creata din mantaua Terrei , si nu capturata , dupa aberatii , din alte aberatii .
CAdi Membru exclus
Trimis: 18 Sep 2020 20:40 Download mesaj |
Ce sa mai zic 2 SKy? Totul se schimba de la un moment la altul dupa ce sunt analizate pe Terra
mai multe fotografii luate de sonda New Horizons:
https://youtu.be/Xm6qj7CI7Hw?t=4
Descriere: |
Marime fisier: |
632.28 kb |
Vizualizat: |
de 9930 ori |
