Numar total de mesaje in forum: 242511 |
kiss marco paul Membru
Data inscrierii: 12 Aug 2012 Mesaje: 32
Motto: Did i ever tell you......the definition of insanity!!! Localitate: Timisoara
Trimis: 08 Dec 2012 01:40 Download mesaj |
| Titlul subiectului: oculare |
buna am nevoie de ajutor va rog, cine poate sami spuna ce tip de oculare as putea sami iau pentru modeulul meu de telescop celestron powerseeker 50 az? astept raspuns..  _________________ Сталинград |
Trimis: 08 Dec 2012 02:05 Download mesaj |
| Nu ai deloc oculare? |
Incepator Membru
Data inscrierii: 28 Iun 2012 Mesaje: 142
Trimis: 08 Dec 2012 21:14 Download mesaj |
gasesti manualul la http://www.celestron.com/c3/images/files/d..._21039.pdf
care spune :
Eyepieces – An assortment of 1¼” eyepieces are available to give you a wide range of
magnifications.
• OMNI Plössl - Plössl eyepieces have a 4-element lens designed for low-to-high power observing.
The Plössls offer razor sharp views across the entire field, even at the edges! In the 1-1/4" barrel
diameter, they are available in the following focal lengths: 4mm, 6mm, 9mm, 12.5mm, 15mm,
20mm, 25mm, 32mm and 40mm.
• Ultima – Ultima is not really a design, but a trade name for our 5-element, wide field
eyepieces. In the 1-1/4” barrel diameter, they are available in the following focal lengths:
5mm, 7.5mm, 10mm, 12.5mm, 18mm, 24mm, 30mm, 35mm, and 42mm. These eyepieces
are all parfocal. The 35mm Ultima gives the widest possible field of view with a 1-1/4”
diagonal. |
sternchen Membru
Trimis: 09 Dec 2012 11:42 Download mesaj |
la un telescop cu diametru de 50mm s-ar putea sa ai nevoie de oculare pe 1",nu pe 1,25".
nu sunt sigur dar la unele lunete am observat asta. |
MrMxyzptlk Membru
Localitate: Sfantu Gheorghe
Trimis: 09 Dec 2012 12:01 Download mesaj |
strenchen de data asta are dreptate, desi vorbim de diametrul de 0.96" nu 1" (nu este idiferent, daca va cauta oculare de 1" nu va gasi).
Daca ma uit la manualul postat de Incepator si ai acest telescop se pare ca chiar vine cu oculare de 0.96" din dotare. Insa tot in acel document spune:
"Diagonal, Hybrid Mirror 90° (.96 to 1¼") #94106 - The economy Hybrid Mirror Diagonal (90°) provides a cost
effective way to upgrade telescopes supplied with .96" eyepieces, to higher quality 1¼" eyepieces."
Probabil ca ar fi indicat sa cumperi diagonala indicata si sa folosesti oculare de 1.25" ... _________________ SkyWatcher 150/750 EQ6-R; Oculare: Gold Line 6mm, Celestron Omni 32mm, 10mm, 25mm, GSO SuperView 30mm pe 2"; Filtre: Green #58A, ND 0.6, O-III Castell, Solar. CLS CCD; Barlow 2x, 3x; Canon 1100Da |
sternchen Membru
Trimis: 09 Dec 2012 12:04 Download mesaj |
| MrMxyzptlk a scris: | | strenchen de data asta are dreptate |
no.in sfarsit..  |
Data inscrierii: 02 Aug 2008 Mesaje: 9936
Trimis: 09 Dec 2012 12:32 Download mesaj |
[offtopic]
O carte de gramatică nu strică niciodată, Paul!
[/offtopic] _________________ bino: 8x22, 7x42, 10x50, 10x80, spotting: 10x46, 20x60
