Numar total de mesaje in forum: 241097
Chang'e-3: Aselenizare in ~20 minute
cmatei
Data inscrierii: 09 Sep 2009
MesajTrimis: 14 Dec 2013 15:39 Download mesaj
Titlul subiectului: Chang'e-3: Aselenizare in ~20 minute
Transmisie live: http://english.cntv.cn/live/p2p/index.shtml
MesajTrimis: 14 Dec 2013 17:01 Download mesaj
Deja a aterizat, sau alunizat.
Cu 20 de milioane de oameni angajati in cercetare, si 1 mie de miliarde de dolari buget pentru acestia, (conform datelor publicate de BBC), nu e de mirare.
Din transmisie, inteleg ca au la bord si un telescop, ca sa profite de lungile nopti lunare. Sper sa aiba succes.
MesajTrimis: 15 Dec 2013 23:44 Download mesaj
Au dat drumul la iepuras: http://www.youtube.com/watch?v=cFb1E63AxNI#t=592
Stiti ce telescop au dus acolo?
cmatei
MesajTrimis: 16 Dec 2013 00:24 Download mesaj
150mm am auzit la un moment dat.
MesajTrimis: 16 Dec 2013 00:29 Download mesaj
Skywatcher sau GSO?
MesajTrimis: 16 Dec 2013 02:00 Download mesaj
Citez:
One of the primary instruments of the lander is the Lunar-based Ultraviolet Telescope (LUT) that is used to observe galaxies, binary stars, active galactic nuclei and bright stars.
The LUT instrument sets out to perform multiple-day observation campaigns, looking at variable stars and active galaxies in the near-UV band. Objects that are bright in the NUV band include variable stars, binaries, novae, quasars and blazars. LUT will attempt to study the variability of these objects to examine the temperature and accretion rate in order to better understand stellar atmospheres and improve current models.
The LUT instrument consists of a Ritchey-Chretien telescope.
LUT has an aperture of 150mm and uses a pointing mirror that features a two-dimensional gimbal to track objects. A Charge-Coupled Device enhanced for observations in the ultraviolet band is used as detector. The CCD uses pixels 13 micrometers in size. LUT covers a wavelength range of 245 to 340 nanometers and is capable to detect objects at a brightness down to 13 mag.
Chang'e 3 - Mission Overview: http://www.spaceflight101.com/change-3.html
P.S. referitor la limita de 13 mag, am ceva dubii ...
LUT Subsystems: telescope body (left) & mounting platform with two-axis gimbal
 Marime fisier:  64.78 kb
 Vizualizat:  de 12391 ori
MesajTrimis: 16 Dec 2013 08:39 Download mesaj
Cam ciudat. Din descriere si fotografii inteleg ca nu au o montura care ghideaza telescopul, ci o oglinda plana mare, care se roteste in doua axe, si care ghideaza razele catre un telescop fix..De ce or fi ales sistemul asta, nu stiu.
MesajTrimis: 16 Dec 2013 10:03 Download mesaj
@nobody 150mm f/3.5, mag. 13 limita la SNR 8 pt o expunere de 30s in UV cu un ccd E2V47-20, mi se pare rezonabil. http://arxiv.org/pdf/1108.0727.pdf
MesajTrimis: 17 Dec 2013 00:49 Download mesaj
http://apod.nasa.gov/apod/astropix.html
Cam ciudat.
Sa fie si asta un hoax?
Din cate am inteles miscarea de rotatie a lunii e de cateva ori mai lenta decat a pamantului astfel, combinat cu timpi de expunere scurti probabil simplifica mult montura necesara. Sau poate au alte mecanisme mai eficiente pe acolo.
MesajTrimis: 17 Dec 2013 02:49 Download mesaj
Intre timp, mi-a trecut prin cap o vaga amintire despre libratia Lunii, deci o miscare mai complexa decat cea a Pamantului. In plus, o oglinda e mai usoara decat un telescop, deci si montura oglinzii e mai usoara. Cam astea ar fi explicatiile pe care le-am gasit.
MesajTrimis: 17 Dec 2013 23:42 Download mesaj
Daca BBC-ul are dreptate :
''Cu 20 de milioane de oameni angajati in cercetare, si 1 mie de miliarde de dolari buget pentru acestia''
atunci,la asemenea resurse, m-as astepta la misiuni spatiale mult mai impresionante.
(Risca sa fie ajunsi din urma ,ba chiar depasiti , de baloanele spatiale mioritice... Very Happy )
Inteleg si respect faptul ca aceasta misiune are insemnatatea istorica pentru chinezi.
Dar nu pentru noi.
Pentru noi, va exista insemnatate istorica daca aceasta misiune va aduce rezultate mai importante decat , de pilda,descoperirea apei pe Luna de catre misiunea indiana Chandrayaan-1 din 2008.
Sau telescopul mentionat va face poze mai grozave ca ale lui Hubble...
Pana atunci, parasolarul meu functioneaza...nu ma las aburit!
MesajTrimis: 18 Dec 2013 01:01 Download mesaj
Depinde cum interpretezi asta: presupun ca nu totul era dedicat zborului astuia, cred ca se refera la toata cercetarea chinezeasca in toate domeniile. Poate parea putin tendentios alaturarea cifrelor cu actuala misiune pe Luna.
In astfel de misiuni o parte e propaganda, o parte e cercetare/explorare. Acum cat procent e explorare ramane de vazut, ideea e sa fie > 0.
MesajTrimis: 18 Dec 2013 01:52 Download mesaj
@auriga: Merci pentru document. Inteleg ca acea magnitutidne este o estimare destul de conservatoare. Ma asteptam la un pic mai mult, dar acum are sens.
auriga a scris:
MesajTrimis: 18 Dec 2013 11:03 Download mesaj
Nici eu, si nici sursa de unde am aflat acele date, BBC, nu am spus ca astea sunt pentru cercetare spatiala, ci pentru cercetare in general.
Cat de relevanta este ea pentru programul spatial chinezesc, nu am idee. Dar stiind si alte cifre de genul asta, cred ca acestea sunt destul de mari pentru a-i face gelosi chiar si pe cercetatorii americani, si in special pe cei de la NASA, al caror buget tot scade de cativa ani.
Interesant este faptul ca pe vremea cand americanii mergeau pe Luna, in China sute de milioane de oameni sufereau de foame, iar noi faceam export de tehnologie moderna catre ei. Sunt tare curios ce va fi peste alti 40 de ani.
MesajTrimis: 18 Dec 2013 11:44 Download mesaj
Am remarcat doar alaturarea notiunilor, nu cred ca au facuto pur si simplu intamplator.
Pe de alta parte si acum in China se moare de foame, de la 20 de milioane de cercetatori la 1.3 miliarde de oameni e cale lunga. In plus, poate ca acum 40 de ani exportam tehnologie in China, dar sa nu uitam ca si cum 60 de ani cineva importa ceva din germania de exemplu, dupa care americanii in 10 ani au ajuns pe luna. Insa important e rezultatul, vorba unui personaj "scopul scuza mijloacele".
Creaza un subiect nou   Raspunde la subiect   Aeronautica / Misiuni spatiale Du-te la pagina 1, 2  Urmatoare
