› Numar total de mesaje in forum: 243548
Anunt update MaximDL 6
Soft pentru astronomie
Emil
Data inscrierii: 30 Aug 2007
Localitate: Fuerstenfeld
MesajTrimis: 07 Dec 2013 19:39 Download mesaj
Titlul subiectului: Anunt update MaximDL 6
Preiau o infomatie referitoare la upgrade-ul planuit pentru MaximDL 6. Am sa mentin topicul actualizat pe masura ce primesc informatii suplimentare
Emil
On 12/3/2013 11:32 AM, Douglas B. George wrote:
> This is a *preliminary* summary of V6 feature improvements:
> Quick Color
> - See Raw RGB Bayer-encoded images in color instead of monochrome
> - Uses nearest-neighbour decode for speed
> - Does not degrade dark subtraction, etc., since image is not actually modified
> - User must still perform Convert Color prior to image processing and for
> optimum quality
> Narrowband image blending tool
> - Stack arbitrary number of images planes
> - Choose wavelength match for each filter band
> - Can insert same filter multiple times for multiple wavelength blending
> Major upgrade to Photometry command
> - Group-based analysis similar to Stack tool
> - Multispectral analysis
> - Unlimited input files
> - Reject images based on quality
> - Astrometric or auto star match star identification
> Support for PinPoint V6
> - Astrometry.net integration for all-sky solving
> - UCAC4 support
> - Hot pixel detection and removal for more robust solving
> - Improved point-spread function fitter
> - Deprecated support for obsolete catalogs GSC (non-corrected) and USNO SA 2.0
> - Now "modeless", allowing the PinPoint dialog box to remain open when
> switching images, using other commands, etc.
> ASCOM Switch control
> - Control hardware switches such as power, lights, reboot equipment, etc.
> Observatory webcam integration
> - Live view of inside of observatory via webcam
> - Switch control panel (handy for operating lights etc.)
> Built-in Davis weather station support
> - Display current weather status
> - Add weather information to image FITS headers
> Built-in Boltwood Cloud Sensor support
> Automated equipment shutdown capability
> - Triggers include:
> - Sunrise
> - Civil, nautical, or astronomical twilight
> - Target low
> - Loss of autoguiding (clouds etc.)
> - Cloud sensor warning
> - Perform shutdown sequence:
> - Shutdown cameras
> - Park telescope
> - Park and close dome
> Multi-star autoguiding
> - Average measurements of multiple stars to reduce effect of seeing
> Support for SBIG Differential Guider accessory
> - Flexure-free autoguiding with separate guide scope
> Single or dual axis dither operation
> - Avoid triggering mount stiction cycles
> Automatic script execution on Expose command
> - Option to save image prior to modifications or after modifications
> - Handy for running "quick look" filters on faint images, etc.
> Automatic pointing refinement using PinPoint
> - Takes pointing exposure to verify telescope position
> - Resynchronizes automatically
> - Centers target precisely
> Automated pier flipping
> - Detect telescope approaching limit
> - Pause imaging sequence
> - Flip telescope over pier
> - Automatic pointing refinement
> - Relocate guide star
> - Continue image sequence
> Bookmark locations on the sky
> - Right Ascension and Declination
> - Rotator angle
> - Save current telescope position
> - Load current solved position
> - Goto bookmark
> - Load and save bookmarks
> User can hide unused Observatory Window tabs
> - Only see tabs for equipment that you are actually using
> Simulated Telescope Park
> - Slew telescope to park position
> - Turn off sidereal tracking
> ASCOM device threading
> - All telescope, dome, focuser, and rotator interfaces are now fully threaded
> - Keeps the user interface more responsive
> - Prevents user interface lockup if device driver locks up
> Enhanced camera interfaces
> - Camera downloads are now threaded
> - Eliminates user interface delays during download
> More image processing filter options
> - Save fit profiles in Flatten Background
> - Gaussian Blur option added Unsharp Mask and Digital Development
> Redesigned Calibration Wizard for quick and easy calibration frame setup
> Many other minor enhancements and "under-the-hood" improvements
> Doug
Procyon
Data inscrierii: 25 Ian 2013
Localitate: Galati
MesajTrimis: 07 Dec 2013 22:33 Download mesaj
Mistooo...
Cand e data de lansare ?
Stoian Andrei-Marian
Emil
MesajTrimis: 08 Dec 2013 18:30 Download mesaj
Dupa cate am inteles sfarsitul lunii Dec. insa nu sunt sigur daca o sa reuseasca.
EDIT: alte surse specifica luna Februarie.
Ultima modificare efectuata de catre Emil la 08 Dec 2013 20:57, modificat de 1 data in total
jimao22
Data inscrierii: 12 Apr 2010
Motto: [descopera lumina]
MesajTrimis: 08 Dec 2013 19:45 Download mesaj
Wow.
O multime de chestii tari si noi. Era timpul fiindca o multime de alte programele ultraspecializate (si free in plus) faceau treaba mai buna decat Maxim pe anumite segmente.
Sa vedem si cat costa.
Procyon
Localitate: Galati
MesajTrimis: 08 Mar 2014 02:42 Download mesaj
Informatii noi, ceva ?
Emil
MesajTrimis: 11 Mar 2014 07:39 Download mesaj
Nu,
pana acum nu, nu am dat nicaieri de ceva nou.
Emil
MesajTrimis: 24 Apr 2014 20:02 Download mesaj
It will be released when it's ready. It's in beta testing. Still working
through a few issues.
Doug
Doug George
dgeorge@cyanogen.com
MesajTrimis: 05 Iun 2014 12:06 Download mesaj
E lansat: http://www.cyanogen.com/maxim_main.php
Emil
MesajTrimis: 05 Iun 2014 12:49 Download mesaj
OK multumesc frumos pentru update.
L-am bagat in download insa sunt cu "jucariile" stranse asa ca nu am cum sa il testez, decat eventual pe "uscat"
Numai bine
Emil
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie
