› Numar total de mesaje in forum: 243544
Descoperirea EURONEAR a asteroidului NEA 2014LU14 cu INT
ovidiuv
Data inscrierii: 30 Mai 2013
Localitate: Santa Cruz de La Palma
MesajTrimis: 12 Iun 2014 02:06 Download mesaj
Titlul subiectului: Descoperirea EURONEAR a asteroidului NEA 2014LU14 cu INT
Dragi colegi,
O stire despre o descoperire recenta EURONEAR a primul asteroid apropiat de Pamant (NEA) de catre o echipa formata din 3 romani (doi de la ING in La Palma si unul din Cluj) in cadrul unei echipe majoritar formate din amatori si studenti, care reprezinta prima astfel de descoperire facuta din La Palma si cu telescopul INT.
EURONEAR Press Release
Discovery of the Near Earth Asteroid 2014 LU14 with the Isaac Newton Telescope
Roque de Los Muchachos Observatory, La Palma, 11 June 2014
Contact: Ovidiu Vaduvescu (email: euronear@imcce.fr)
http://www.minorplanetcenter.net/db_search...=2014+LU14
Born in 2006 at IMCCE Observatoire de Paris, the European Near Earth Asteroid Research project (EURONEAR) aims to grow the European contribution in studying of Near Earth Asteroids (NEAs). One first aim has been to ameliorate the NEA orbits via astrometry derived from new observations and archive data mining, while another more recent aim is to study physical properties of NEAs via photometry and spectroscopy.
Fifteen telescopes (from 30cm to 4m diameter) accessible to the EURONEAR network from Spain, Chile, France, Romania and Germany have been used for NEA observations, including since 2009 the 2.5m diameter Isaac Newton Telescope (INT) owned by the Isaac Newton Group (ING, an English-Dutch-Spanish institution) located in the Spanish "Observatorio Roque de los Muchachos" (ORM) of the "Instituto de Astrofisica de Canarias" (IAC) in La Palma, Canary Islands. Endowed at its prime focus with the relatively wide field mosaic camera WFC (34x34 arcmin field), the INT is a very good facility to recover important NEAs not observed for years, as faint as limiting magnitude V=23-24, above the limit of the current NEA surveys.
Besides follow-up work which succeeded in improving about 1500 NEA orbits during the last 8 years via EURONEAR, some important incidental survey work has been carried and published thanks to the involvement of many amateur astronomers and students working mostly remotely who carefully blinked thousands of CCD images to search and measure all moving objects using the Astrometrica software written by Austrian amateur astronomer Herbert Raab. Together, about 10,000 orbits of known main belt asteroids (MBAs) falling in the observed fields have been improved, while other 10,000 unknown MBAs have been reported by EURONEAR using mostly three telescopes, namely the INT 2.5m from La Palma, ESO/MPG 2.2m and Blanco 4m from Chile. Among the unknown moving objects, about 20 became best NEA candidates, unfortunately lost mostly due to lack of any follow-up telescope time.
This situation was improved in the semester 2014A, when Dr. Ovidiu Vaduvescu (EURONEAR founder, ING astronomer, IAC and IMCCE associated) was awarded by the Spanish time allocation committee 30 hours INT target of opportunity (ToO) time for recovery of important NEAs (one opposition fainter objects less accessible to major surveys) and rapid follow-up of important new NEAs and eventual discoveries. Part of this C136 program carried out in a team comprising a few amateurs and students mostly from Romania and the ING, during 1 hour of the 1/2 June 2014 night the ING student Vlad Tudor observed a few fields with the aim to recover four important NEAs. In one of the observed fields, the amateur astronomer Lucian Hudin based in Cluj Napoca, Romania, identified and measured a few other unknown asteroids among which the faint R=21.6 magnitude object baptized EUHT171 was clearly detected at signal to noise S/N=6 in good conditions (dark and clear night with good INT seeing 1.2"). Moving faster and in a different direction than all other main belt objects in the field, he could flag immediately EUHT171 as a very probable NEA (score 100%). We include in Figure 1 an animation of the discovery frames (field 6.5'x5' in normal sky orientation) marking the 2014 LU14 NEA (in red circle) in comparison with the known main belt asteroid (7204) Ondrejov (marked with a green circle) moving slowly and in a different direction.
Image 1: http://euronear.imcce.fr/tiki-download_file.php?fileId=497
Thanks to the extremely rapid data reduction by the observer student Vlad Tudor (in almost real time) combined with the very fast and keen visual detection and accurate measurement and classification of all moving objects by the amateur Lucian Hudin, after only 3 hrs we reported this finding to the Minor Planet Centre (MPC) as "New NEO Candidate (EUHT171) from 950 - La Palma while recovering 2012 MR7". Although this object was rapidly posted on the MPC NEO confirmation list during next four days, no other observatory could recover it, thus during the following few nights using same ToO time, we recovered the object and promptly report the astrometry data to MPC. Finally, following five nights astrometry of EUHT171 collected during one week, the MPC linked all our 31 observations in a NEA orbit and assigned the number 2014 LU14 to EUHT171, these findings being published in the MPS 518060 and MPEC L49 circulars. Thus, EUHT171, now officially known as 2014 LU14, became the first NEA discovered and secured by EURONEAR, the first NEA discovered from La Palma, the first NEA discovered using the INT and also the first NEA discovered by three astronomers of Romanian origin, thanks to an excellent collaboration between professionals, amateurs and student astronomers and to the Spanish ToO time.
One of more 10,000 NEAs known today thanks to five major American surveys, 2014 LU14 in an Apollo NEA which resides quite close to the Earth orbit (semi-major axis a=1.29 AU, minimum orbital intersection distance MOID=0.197 AU) revolving around the Sun every 1.5 years in an elongated orbit (eccentricity e=0.45) quite tilted with respect to the Earth equator (inclination i=25 deg). We include in Figure 2 its orbit and position at discovery in respect with the Earth and other planets. Having an absolute magnitude H=18.6, our discovered NEA has an estimated size of about half kilometer (assuming a mean albedo 0.2) and will become better visible in of June 2014 (estimated magnitude V=20).
Image 2: http://euronear.imcce.fr/tiki-download_file.php?fileId=498 [si inclusa mai jos]
Besides Ovidiu Vaduvescu (ING, IAC and IMCCE associated), the whole team comprises Vlad Tudor and Teo Mocnik (ING students), Lucian Hudin (amateur astronomer, ROASTERR-1 Observatory, Romania), Andrei Marian Stoian (amateur astronomer, Schela Observatory, Romania), Stefan Mihalea (amateur astronomer, SARM Romania), Farid Char (Universidad de Antofagasta, Chile), Mansour Karami (IPM and BA Tehran and former ING student), Javier Licandro (IAC and ULL, Tenerife), Alexandru Tudorica (PhD student, Bonn), Marcel Popescu (Bucharest Observatory and IMCCE Paris) and Ruxandra Toma (PhD student Armagh Observatory and SARM Romania).
Press release and pictures included also on the EURONEAR page File Galeries / NEA Discoveries: http://euronear.imcce.fr/tiki-list_file_gallery.php?galleryId=4
 Marime fisier:  6.09 kb
 Vizualizat:  de 8112 ori
Ovidiu
theogon
Membru de onoare
Membru de onoare
Data inscrierii: 20 Mar 2009
Localitate: cluj
MesajTrimis: 12 Iun 2014 09:36 Download mesaj
O realizare de excepție pentru astronomia romanească. FELICITĂRI echipei!
mihai
MesajTrimis: 12 Iun 2014 10:01 Download mesaj
Felicitări! La cât mai multe descoperiri și cer senin! Smile
cmatei
Data inscrierii: 09 Sep 2009
MesajTrimis: 12 Iun 2014 10:20 Download mesaj
Excelent, felicitari!
achy1978
Data inscrierii: 24 Dec 2007
Localitate: Targu Jiu
MesajTrimis: 12 Iun 2014 17:59 Download mesaj
Bravo, bravo, bravo intregii echipe!
Observ ca perseverenta lui Lucian (auriga) incepe sa dea roade Smile ... felicitari
Marian Lucian ACHIM
SRCSTV - www.srcstv.ro
SARM - www.sarm.ro
psemil
Data inscrierii: 16 Aug 2010
MesajTrimis: 12 Iun 2014 18:28 Download mesaj
SuperB.
Felicitari pentru reusita.
iqarmy
Data inscrierii: 25 Apr 2014
MesajTrimis: 12 Iun 2014 18:34 Download mesaj
Felicitari intrgii echipe, si la mai mare!Smile.
Skywatcher - 10" F/4 newtoinan reflector, 9x50 right angle finder
Canon 450Da, Nikon d3100
Matrixul
Data inscrierii: 17 Iun 2012
MesajTrimis: 12 Iun 2014 18:35 Download mesaj
Felicitari pentru reusita !!!
ovidiuv
MesajTrimis: 18 Iun 2014 10:53 Download mesaj
Iata si un excelent prim articol romanesc/Cluj despre descoperire:
http://www.monitorulcj.ro/actualitate/3752...un-clujean
Ovidiu
Data inscrierii: 19 Dec 2012
MesajTrimis: 18 Iun 2014 20:57 Download mesaj
Este doar inceputul inteleg. Felicitari. Sint sanse la ceva comete, sau trebuie alta orientare a micutului telescop?
MesajTrimis: 19 Iun 2014 08:23 Download mesaj
Felicitari echipei, si spor la cautari in continuare.
MesajTrimis: 23 Iun 2014 09:53 Download mesaj
2014 LU14 primeste confirmare si din partea altor doua observatoare:
807 – Cerro Tololo Observatory, La Serena
474 – Mount John Observatory, Lake Tekapo
Asta inseamna deja o recuperare relativ usoara la urmatoarea opozitie, dar probabil Ovidiu il va mai observa cel putin o data pana atunci.
ovidiuv
MesajTrimis: 02 Iul 2014 10:35 Download mesaj
... iar recent obiectul a fost recuperat si de Pan-Starrs:
Iar pe pagina main a ING a aparut urmatorul news release featuring cele trei nume romanesti ale descoperitorilor primului NEA EURONEAR, descoperit din La Palma, si folosind telescopul INT.
http://www.ing.iac.es/PR/press/1stnea.html
In caz ca mai exista amatori seriosi pentru data reduction si realizari similare pe viitor, ii rog sa ma contacteze pe mine sau Lucian/auriga.
Ovidiu
MesajTrimis: 02 Iul 2014 10:56 Download mesaj
ovidiuv a scris:
In caz ca mai exista amatori ...
Pai suntem: http://www.astronomy.ro/forum/viewtopic.php?t=12528&start=15
tsa
Data inscrierii: 03 Iun 2011
Localitate: Cluj
MesajTrimis: 02 Iul 2014 19:37 Download mesaj
abia acum citesc stirea, bravo Luci!
felicitari echipei!
reflector: Dobson 254 mm, Sky-Watcher
Filtre: Astronomik UHC, Lumicon OIII, Lumicon H-Beta.
