› Numar total de mesaje in forum: 243722
KIC 8462852 - o megastructura misterioasa inconjoara steaua
Du-te la pagina 1, 2, 3, 4, 5, 6  Urmatoare
Science Fiction
CAdi
Membru exclus
Membru exclus
Data inscrierii: 07 Iun 2015
Motto: Cogito ergo sum
MesajTrimis: 26 Noi 2015 19:45 Download mesaj
Titlul subiectului: KIC 8462852 - o megastructura misterioasa inconjoara steaua
Se pare ca aceasta stea aflata la 1400 de ani lumina de Terra este inconjurata de o
megastructura misterioasa .
Aceasta megastructura a fost descoperita de Kepler telescop NASA in 2011 .
Acest telescop in prezent este retras din activitate dar steaua este urmarita din 2015 in
continuare de un alt telescop Spitzer ,care apartine tot de NASA.
De asemenea radiotelescoapele terestre din reteaua ATA (Allen Telescope Array) si-au orientat antenele spre steaua aceasta misterioasa KIC 8462852, si incearca sa capteze eventuale semnale radio ce ar putea sa indice activitatea unor civilizatii extraterestre in jurul stelei.
http://www.seti.org/seti-institute/mysterious-star-kic-8462852
Subiectul provoaca numeroase dispute si in mass- media :
https://youtu.be/j5UHULLK1sY?t=2
MesajTrimis: 26 Noi 2015 21:36 Download mesaj
Stai linistit ca SETI n-a gasit nimic interesant acolo:
No narrowband radio signals were found at a level of 180-300 Jy in a 1 Hz channel, or wideband signals above 100 Jy in a 100 kHz channel. http://arxiv.org/abs/1511.01606
This rules out omnidirectional transmitters of approximately 100 times today’s total terrestrial energy usage in the case of the narrow-band signals, and ten million times that usage for broad band emissions.
http://www.seti.org/seti-institute/press-r...ic-8462852
Si nici NASA:
But, like WISE, Spitzer did not find any significant excess of infrared light from warm dust. That makes theories of rocky smashups very unlikely, and favors the idea that cold comets are responsible. It's possible that a family of comets is traveling on a very long, eccentric orbit around the star. At the head of the pack would be a very large comet, which would have blocked the star's light in 2011, as noted by Kepler. Later, in 2013, the rest of the comet family, a band of varied fragments lagging behind, would have passed in front of the star and again blocked its light.
http://www.nasa.gov/feature/jpl/strange-st...-by-comets
CAdi
Membru exclus
Membru exclus
MesajTrimis: 26 Noi 2015 22:47 Download mesaj
Nu inca .Steaua e sub observatie ....Doar nu te-ai fi asteptat sa primim mesaje te salut
S-ar putea sa nu gasim ceva in aceasta viata .Semnele de intrebare insa raman...
Sunt miliarde si miliarde de stele in univers ,nu se poate sa fim singurele fiinte din
acest univers ....
Smile
Ultima modificare efectuata de catre CAdi la 26 Noi 2015 23:04, modificat de 1 data in total
MesajTrimis: 26 Noi 2015 23:03 Download mesaj
https://www.pinterest.com/pin/456059899744779777/
Ultima ''explicatie'', care de fapt ar trebui numita in cel mai bun caz speculatie, este ca un val imens de comete inconjoara aceasta stea. Dovada faptului ca, uneori, si astronomii profesionisti pot fi total penibili.
CAdi
Membru exclus
Membru exclus
MesajTrimis: 26 Noi 2015 23:22 Download mesaj
Asa - zisele comete reci nu se pot observa prin telescoapele Kepler si Spitzer
NASA insa a si,, vazut" cometele la distanta aceasta (1400 de ani lumina).
Inca o informatie clasificata ,nu-i asa ? Wink
MesajTrimis: 27 Noi 2015 00:59 Download mesaj
Asa s-a zis cand s-au descoperit pulsarii, ca-s ET, alieni ... si oare cine a cazut in penibil ?
MesajTrimis: 27 Noi 2015 01:39 Download mesaj
Personal, nu stiu cine a cazut in penibil atunci, dar, oarecum paradoxal, stiu cu siguranta cine o sa cada in penibil intr-un viitor, mai apropiat sau mai indepartat. Locul este rezervat celor care sustin ca actualele modele ale stiintei mainstream sunt perfecte, si toate noile descoperiri trebuie interpretate in conformitate cu vechile paradigme, si in nici un caz, nu trebuie sa ne gandim ca poate exista ceva dincolo de ele. Este vechea metoda ''stiintifica'' a Inchizitiei. Stiu cu siguranta pentru ca s-a mai intamplat la fel de nenumarate ori in trecut. Este noul ''Pat al lui Procust'', de data asta, masurat cu laserul.
Teo
Data inscrierii: 23 Aug 2009
MesajTrimis: 27 Noi 2015 01:51 Download mesaj
Poate ca steaua respectiva are o zona mai rece. Ca un fel de pata solara giganta pe o parte.
Cand se roteste cu acea parte spre noi, intensitatea luminoasa scade.
MesajTrimis: 27 Noi 2015 01:53 Download mesaj
Doar cei ce se ocupa de pseudo-stiinta "sustin ca actualele modele ale stiintei mainstream sunt perfecte".
MesajTrimis: 27 Noi 2015 02:04 Download mesaj
Chiar asa, se stie cu siguranta ce sunt quasarii, si chiar pulsarii? Deocamdata sunt multi care pun la indoiala teoria privind Soarele. si avand in vedere succesele din ultimul timp privind predictia cutremurelor pe Pamant in functie de activitatea solara, se pare ca lucrurile se complica rau.
De cat timp este acceptat, si subliniez pe cuvantul acceptat, faptul ca sunt miliarde de planete in galazia noastra? Pentru ca pana in '89, teoria mainstream era ca sistemele cu planete sunt cel mult singulare, daca cumva exista. Stiu sigur, am trait acele vremuri, si ma indigna foarte tare aroganta unor savanti, care extrapolau o cunoastere incompleta, la intreg Universul.
Dar se pare ca ultimele descoperiri nu au reusit sa-i invete nimic, atat pe ei, cat si pe sustinatorii lor fideli, prezenti, din pacate, si aici pe forum.
Si nimic nu imi pare mai penibil decat sa lansezi o ipoteza, fara o minima argumentatie, doar pentru a nu lasa cumva loc unei interpretari extra ... Extra mainstream.
Va rog, sa nu cumva sa credeti ca eu as crede ca undeva in infinitul, relativ? al Universului ar putea exista o civilizatie, cu atat mai mult una de gradul trei, sau care grad o fi ala. Nu, noi suntem singurii, nu exista extraterestri, si orice posibil semn al unei astfel de existente trebuie negat si desfiintat cu orice pret. Traiasca tovarasul Nicolae Ceausescu, si ......oricine e la putere! Exclamation Exclamation Exclamation
Ultima modificare efectuata dragos.n la 27 Noi 2015 02:35, modificat de 2 ori in total
MesajTrimis: 27 Noi 2015 02:09 Download mesaj
Am ajuns la quasari ?
Te ascult.
P.S. Ti-ai editat mesajul de 2 ori pana acum. Apropo, o ipoteza nu elimina o alta ipoteza.
In rest ... no comment.
MesajTrimis: 27 Noi 2015 11:46 Download mesaj
Ce se cunoaste despre aceasta megastructura ?
Cand a fost observata si cum ?
Care sunt ultimele noutati ?
P.S. Am atasat o pagina de observatii din
Planet Hunters X. KIC 8462852 - Where's the Flux?
http://arxiv.org/abs/1509.03622
 Marime fisier:  70.03 kb
 Vizualizat:  de 21033 ori
Ultima modificare efectuata de catre nobody la 27 Noi 2015 13:13, modificat de 1 data in total
CAdi
Membru exclus
Membru exclus
MesajTrimis: 27 Noi 2015 13:08 Download mesaj
Prin telescopul Kepler s-a studiat fenomenul in perioada 2011 si 2013.
Se pare ca observatiile astronomice prin telescopul Spitzer nu au mai semnalat in 2015
ceva deosebit .
Interpretare personala ar fi ca in acea perioada pe langa stea s-a aflat un
obiect sau mai multe obiecte spatiale (naturale sau nu ).
In spatiu cosmic mai apar si asa numitele planete ratacitoare ,dar aici nu este cazul
pentru ca fenomenul a avut o repetitie aleatorie fapt ce i-a intrigat pe astronomi...
Ipoteza NASA cum ca de acea stea s-au ciocnit o planeta sau asteroizi, nu a fost confirmata
deoarece nu s-au gasit radiatii infrarosii in jurul stelei ,cu atat mai putin comete reci...
Ultima stire am gasit-o la Mediafax .ro :
http://www.mediafax.ro/stiinta-sanatate/o-...-bombardat
MesajTrimis: 27 Noi 2015 13:41 Download mesaj
Ma refeream la informatii cu valoare stiintifica.
In principiu s-au observat 2 grupuri de anomalii, unul mai puternic, altul mai slab. Adica este o singura "repetitie" observata.
NASA (si nu numai) are mai multe ipoteze, cum este si normal in faza de ipoteza. Unele raman, altele se infirma sau se confirma. Cea referitoare la comete este in ideea unei perturbatii interstelare a obiectelor aflate pe orbite indepartate (de genul norului Oort). S-a mai observat o stea mai mica invecinata care ar putea face asa ceva prin mecanismul Kozai. Ti se pare absurda ipoteza ?
CAdi
Membru exclus
Membru exclus
MesajTrimis: 28 Noi 2015 14:43 Download mesaj
Nu mi se pare absurda ,dar putin probabila.
Daca vrei o explicatie pe pozitiile actuale ale stiintei ,mai degraba iau totusi in calcul trecerea
prin fata stelei KIC 8462852 a catorva planete ratacitoare scapate din atractia vreunui
sistem solar ,din cauza unui anumit eveniment cosmic.
Astronomii considera ca exista in univers de 2 ori mai multe planete ratacitoare de marimea lui Jupiter ,
decat stele !
Insa spre deosebire de voi eu accept si posibilitatea existentei unor activitati extraterestre , si nu
sunt singurul din moment ce radiotelescoapele terestre din reteaua ATA (Allen Telescope Array)
si-au orientat antenele spre acea stea si chiar NASA desi nu declara ,monitorizeaza atent steaua
prin Spitzer dupa ce telescopul Kepler si-a epuizat bateriile...
Ultima modificare efectuata de catre CAdi la 29 Noi 2015 14:03, modificat de 1 data in total
Creaza un subiect nou   Raspunde la subiect   Science Fiction Du-te la pagina 1, 2, 3, 4, 5, 6  Urmatoare
Pagina 1 din 6
