Numar total de mesaje in forum: 242998
Sequence Generator Pro
Soft pentru astronomie
iosif
Data inscrierii: 17 Oct 2012
Localitate: Sandra Timis
MesajTrimis: 29 Sep 2017 14:15 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v3.0.0.2
Sequence Generator Pro Beta v3.0.0.2 Released: 09/29/2017.
Release Notes.
- No code changes.
- Fixed an issue that irritated some AV software.
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8180
_________________________________________________
iosif
MesajTrimis: 14 Dec 2017 20:12 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v3.0.0.4
Released: 12/14/2017
Release Notes
- Support for Canon Digic 6 and 7 cameras
- Native support for ZWO cameras (will hopefully avoid issues our users see with the ZWO ASCOM driver.. VERY BETA)
- Initial support for Optec Focus Lock (a post with more detail / instructions to follow)!
- Docking module added to convey FocusLock status directly inside SGPro
- Open, connect gear, start and stop your lock all from within SGPro
- Block integration start until Focus Lock reports good focus
- Ask SGPro to restart your current frame if Focus Lock reports that focus is lost
- Ask SGPro to ensure FocusLock does not move your focuser during integration
- Removed "AtHome" check from observatory slaving
- Removing "AtPark" check for dome slaving
- Fixed the AstroBin target importer
- Added camera gain to the file namer (%cg)
- Planner errors (anything that causes a blank graph) are now visible even if the target is not using start / end times
Download
http://mainsequencesoftware.com/Releases/DownloadFile?id=8184
______________________________________________________________
 Marime fisier:  397.52 kb
 Vizualizat:  de 16709 ori
iosif
MesajTrimis: 26 Ian 2018 22:37 Download mesaj
Titlul subiectului: Sequence Generator Pro v3.0.0.7
Released: 01/26/2018
--- Release Notes ---
- Planning tools
- Show target rise and set on an easy to read graph
- Easily identify when it is “safe” to start imaging (twilight, etc)
- Choose start and end times quickly by clicking on the graph
- See an itemized list of errors and warnings to help you plan the capture sequence
- Define your own custom horizon to reflect your environment
- Check the status of the moon
- New features for start and end times
- Define times by altitude (or by time of day)
- Lock time or altitude
- When time is locked, the time will remain static from day to day and the altitude will vary
- When altitude is locked, it will remain static and the time will vary
- Integration with FocusLock (still beta)
- See FocusLock status without needing the FocusLock application
- Perform basic operations direct from SGPro
- Restart the current frame if FocusLock reports you are out of focus m (will block until focus is re-acquired)
- Prevent FocusLock from altering the focuser position during image integration
- Update manager overhaul, managing SGPro versions is now easier than ever
- Receive notifications that your SGPro is out of date
- Snooze these notifications for 7 days (more time intervals soon)
- View release notes in a new, rich text formatted, area
- Download and upgrade without ever going to the MSS web site
- Opt-in to the beta-track directly from the update manager to get notifications of new betas (or new releases… whichever is the latest)
- Support for Gemini SnapCap FlatBox device
- Native support for ZWO ASI (beta)
- SBIG RBI Implementation
- Addition of “per event” gain control
- A sequence can now import targets from other SGPro sequences
- Updated CTYPEn FITS headers to report projection as gnomonic (instead of default)
- SGPro will now more accurately detect the need to auto connect with a flats box
- Recovery mode stabilization
--- Download ---
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8187
 Marime fisier:  356.69 kb
 Vizualizat:  de 16650 ori
iosif
MesajTrimis: 23 Feb 2018 20:51 Download mesaj
Titlul subiectului: Sequence Generator Pro v3.0.1.0
Sequence Generator Pro v3.0.1.0 Released: 02/20/2018
Release Notes
- Fixing Update Manager Issues
- Fixing temperature compensation to take sequence start temperature into account.
- Fixing UI lag caused by FocusLock API calls
- Disabling settings dialog when camera has no settings
- Fixing crash for Windows 7 Font Scaling.
- Updating ZWO libraries to 1.3.1.12
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8188
iosif
MesajTrimis: 02 Mai 2018 09:19 Download mesaj
Titlul subiectului: Sequence Generator Pro v3.0.2.81
Sequence Generator Pro v3.0.2.81 Released: 05/02/2018
Release Notes.
- Added per event offsets
- Added ZWO settings dialog
- Fixing bug in Dome polling frequency
- Fixing temp compensation bug to reset when auto focus is ran
- Larger values for focus points in filter setup
- More update checker fixes
- Logging fixes
- Actually updating ZWO libraries
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8190
________________________________________________________________
 Marime fisier:  420.82 kb
 Vizualizat:  de 16474 ori
iosif
MesajTrimis: 08 Iun 2018 20:04 Download mesaj
Titlul subiectului: Sequence Generator Pro v3.0.2.91
Sequence Generator Pro v3.0.2.91.
Released: 06/08/2018.
Release Notes.
- Fixing exception being logged after telescope disconnects
- Saving camera selection for ZWO when multiple cams are present
- Safety monitor now active when waiting for a target (only while a sequence is running)
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8191
__________________________________________________________________
iosif
MesajTrimis: 26 Oct 2018 19:59 Download mesaj
Titlul subiectului: SGP 3.0.3.140
SGP 3.0.3.140
New Features:
- Last sequence opened will now open when SGP starts (this can be disabled under Tools>>Options if you prefer the “Default Profile with empty sequence” behavior)
- Better dithering options for the DirectMountGuider
- Observatory slaving can now be toggled from the Observatory Dock Module
- Updating GNS binaries
- Read-only Observatory API end point
- Starting TEC Cooldown “cooldown minutes” prior to sequence start for delayed start sequences
Bug fixes:
- Fixing double “End of Sequence” running on unsafe
- Flatbox now remains closed after auto flats calibration
- Fixing a couple issues with the Gemini SnapCap not completing opening before an image was started
- Fixed Starry Night importer to use J2000 coordinates rather than JNow
- Removing rotator sync from start of sequence (caused poorly placed plate solve)
- Auto Center will not attempt to move the rotator if the rotator has not been synced, this will result in an additional iteration of auto center, but prevents an invalid rotation.
Download.
https://www.mainsequencesoftware.com/Releases
iosif
MesajTrimis: 01 Dec 2018 10:43 Download mesaj
Titlul subiectului: Sequence Generator Pro 3.0.3.151
Released: 12/01/2018
This release is primarily a bugfix release which addresses the following issues:
- Fixing Always/180 Bug in Rotator
- Fixing PHD2 graph display being flipped in Dec
- Fix for Direct Mount Guider options in Equipment Profile
- Fixing RA Bounding issues resulting in exceptions when invalid RA values are sent in
- Fixing Gemini SnapCap coming on at startup.
Download.
https://www.mainsequencesoftware.com/Relea...le?id=8198
iosif
MesajTrimis: 15 Sep 2019 16:20 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v3.1.0.232
Released: 09/08/2019
- Change: Docking modules inherit title bar color from Control.DarkDark (this is for the Windows 10 dark theme by Shane aka @Kor) -> Win10 Dark Theme for SGP
- Change: MFW Fetch now checks to see if an internet connection is available. If not, it displays an appropriate message.
- Change: demoting local DSO location database in favor of SIMBAD (reports of local being less accurate)
- Fix: Restart on safe will no longer show TEC not at temperature dialog for cameras that cool on connect.
- Fix: ZWO Cameras will no longer disconnect when a new sequence is opened
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8214
iosif
MesajTrimis: 23 Ian 2020 11:58 Download mesaj
Titlul subiectului: Sequence Generator Pro v3.1.0.447 Released: 01/23/2020
Pentru cine foloseste Sequence Generator Pro, s-a adus in ultima vreme foarte multe imbunatatiri.
Odata instalat si achizitionat licienta, se instaleaza automat urmatorul update.
Download. Sequence Generator Pro v3.1.0.447 Released: 01/23/2020
https://www.mainsequencesoftware.com/Relea...le?id=8304
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina Anterioara  1, 2, 3
Pagina 3 din 3
