› Numar total de mesaje in forum: 244066
PHD ver 2
Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7
Soft pentru astronomie
iosif
Data inscrierii: 17 Oct 2012
Localitate: Sandra Timis
MesajTrimis: 21 Ian 2023 00:47 Download mesaj
Titlul subiectului: PHD2 Development
PHD2 Development v2.6.11dev4
15 January 2023
-Improved alert messages for camera geometry mismatches
-Fix problem launching PHD2 on some Windows computers (missing vcomp140.dll)
-Updated Czech translation from Stanislav
-Updated Japanese translation from nabePla
-Updated Simplified Chinese translation from Linkage
Download
https://openphdguiding.org/phd2-2.6.11dev4-installer.exe
iosif
MesajTrimis: 25 Noi 2023 22:27 Download mesaj
PHD2 v2.6.12
20 November 2023
-New Calibration Assistant tool
-Multi-star guiding improvements: better tolerance to passing clouds or loss of stars after a large dither
-Various enhancements for mounts with high precision encoders
-Reduced CPU utilization when rendering the camera image on the screen
-The star profile can now be viewed without interpolation
-Improved help content and error messages
-Updated camera libraries: ZWO ASI, Moravian, Svbony, QHY, Touptek, Altair
-New/updated translations: Simplified Chinese, Traditional Chinese, Portuguese (Brazilian), Czech, Japanese, Spanish
Download.
https://openphdguiding.org/phd2-2.6.12-installer.exe
iosif
MesajTrimis: 25 Mar 2024 01:17 Download mesaj
Titlul subiectului: PHD2 v2.6.13dev2
PHD2 v2.6.13dev2
23 March 2024
- Mac: Fix crash on Sonoma when a status alert message is displayed
- Windows installer: add missing required dll msvcp140.dll
- Star profile window: improved layout, better font size, and more accurate display of crosshairs
- Performance improvement displaying camera images
- Prevent resizing of rows and columns in stats window grids
- Touptek cameras: update to SDK version 55.24621.20240204
- INDI: Rotator support added
- INDI: Wait for Indi devices to be ready when connecting
- INDI: Better error message for RGB FITS file
- Updated Czech and Spanish translations
Download
https://openphdguiding.org/phd2-2.6.13dev2-installer.exe
MesajTrimis: 11 Aug 2024 11:43 Download mesaj
A incercat cineva PHD2 Log Viewer pe win 10 64 bit si i-a mers? Exista alternative?
https://openphdguiding.org/phd2-log-viewer/
Ma intereseaza de ex. sa imi recomande in ce directie sa misc montura pentru o aliniere polara mai buna, pe baza analizei corectiilor ce le face.
Multumesc.
 Marime fisier:  24.54 kb
 Vizualizat:  de 15804 ori
MesajTrimis: 11 Aug 2024 12:00 Download mesaj
La mine merge pe win8.1 (unu mai vechi).
Daca vrei incerc si pe win11 pro, poate ii trebuie drepturi mai speciale de admin.
MesajTrimis: 11 Aug 2024 12:07 Download mesaj
Win 10 pro, 64 bit. De schimbat nu schimb sistemul doar pt softul respectiv.
Ce drepturi sa ii mai dau? Poate alta e problema, cauta ceva si nu gaseste, de ex PHD-ul care epe E: nu pe C:. PHD-ul merge fara probleme.
MesajTrimis: 11 Aug 2024 12:34 Download mesaj
N-a zis nimeni sa-ti schimbi sistemul. Am incercat si pe win11pro, mi-a cerut permisiune din UAC la 'elevated privileges' si ... merge, se vede un pic mai urat, dar merge. N-ar trebui sa aiba legatura cu PHD, pe asta mai nou nici nu am PHD instalat.
La instalare iti da eroarea ?
MesajTrimis: 11 Aug 2024 12:56 Download mesaj
Da, la rularea setpului, probabil vreo dependenta de-a installerului. I-am dat si cu run as admin Smile
 Marime fisier:  61.67 kb
 Vizualizat:  de 15758 ori
MesajTrimis: 11 Aug 2024 13:12 Download mesaj
LOL ... vezi si pe github, poate-ti lipsesc ceva dll-uri de Visual C++ Runtime mai vechi:
https://github.com/agalasso/phdlogview/tree/master/3rdparty
MesajTrimis: 11 Aug 2024 23:30 Download mesaj
Am un milion de runtimeuri, si acele dll-uri par a fi, as paria ca sunt dar sunt pentru bitii diferiti decat le vrea el, nu le inlocuiesc ca stric alte chestii.
Multumesc.
iosif
MesajTrimis: 15 Noi 2025 20:00 Download mesaj
PHD2 v2.6.13dev8
9 November 2025
-Comet tool: disable multi-star guiding when comet tracking is enabled
-Fix behavior when MultiStar guiding is enabled with guiding off
-Equipment Profile Wizard improved and updated
-Calibration Assistant improvements for encoder mounts and SB mounts
-Prevent multiple PHD2 instances from sharing the same log files
-Event Server: capture_single_frame method added
-Fix message when user asks for details in old, no longer relevant calibration alert
-ToupTek/OGMA cameras: display sensor temperature in stats window
-ToupTek cameras: update SDK library to version 59.29465.20250907
-ToupTek cameras: from ToupTek: enable camera's Conversion Gain mode when available
-ZWO ASI cameras: update SDK library to version 1.38
-INDI: Update INDI client to v2.1.5
-Updated Czech translation, added Czech help file
Download
https://openphdguiding.org/phd2-2.6.13dev8-installer.exe
iosif
MesajTrimis: 12 Dec 2025 23:24 Download mesaj
Titlul subiectului: PHD2 2.6.14
PHD2 2.6.14 10 December 2025
-Altair cameras: update to SDK 59.30004.20251116
-ZWO ASI cameras: update SDK library to V1.40
-INDI client: update to version 2.1.6
-Updates to the Traditional Chinese translation
Download.
https://openphdguiding.org/phd2-2.6.14-installer.exe
iosif
MesajTrimis: 07 Sep 2026 00:11 Download mesaj
Titlul subiectului: PHD2 2.6.14dev1 29 August 2026
- Additional binning options: PHD2 can now do binning in software in addition to camera hardware binning
- Guiding assistant: improved recommandations for binning
- Calibration assistant can now start mount tracking if needed
- Alpaca camera and mount support added
- CameraFrames diagnostic folders are now removed automatically after 30 days
- New profile wizard: improved messages regarding rotators
- Debug logging improvements
- ZWO ASI cameras: better handling of subframes when subframe size changes
- OGMA and ToupTek cameras: fix bug where data is not pulled from the camera correctly in 8-bit mode
- ZWO ASI cameras: update SDK to V1.41
- Touptek cameras Update Touptek lib to version 60.32226.20260808
- QHY Cameras: Update SDK libraries to version 25.09.29
- PlayerOne cameras: update to SDK v3.10.0
Download.
https://openphdguiding.org/phd2-2.6.14dev1-installer.exe
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7
Pagina 7 din 7
