Vand oculare, reducere SCT, luneta Omegon, binoclu Bresser
gpaunescu
Data inscrierii: 01 Sep 2020
MesajTrimis: 19 Dec 2025 14:26 Download mesaj
Titlul subiectului: Vand oculare, reducere SCT, luneta Omegon, binoclu Bresser
Preturi
Ocular Omegon Flatfield 19mm = 200 RON
Ocular Omegon SWA 10mm = 200 RON
Ocular Lacerta Premium Flat Field 5.5mm = 120 RON
Tecnosky HD 7.2mm - 21.5mm = 350 RON
Reducator/corector Celestron f/6,3 = 350 RON
Reducator/corector Antares f/6,3 = 200 RON
Pachet Refractor + 3 Oculare + Filtru Semi APO + diagonala = 900
Binoclu BRESSER Pirsch ED 15x56 = 900
Tot ce se vinde e in stare buna, eventuale urme de folosire.
Preturile nu includ transportul (daca e cazul). Livrarea va fi agreata cu cumparatorul.
Informatii/fotografii suplimentare, la cerere.
Ocular Omegon Flatfield 19mm 1,25"
https://www.astroshop.ro/oculare/omegon-oc...5-/p,43851
Distanta focala (mm): 19
Conexiune (spre telescop): 1,25"
Camp vizual propriu (°): 65
Eye relief (mm): 9
Number of lenses 6
Acoperirea sistemului optic: Acoperire multipla (FMC)
Ocular Omegon SWA 10mm 1,25"
https://www.astroshop.ro/oculare/omegon-oc...5-/p,14642
Distanta focala (mm): 10
Camp vizual propriu (°): 70
Acoperirea sistemului optic: multipla
Numar de lentile: 5
Parfocal: da
https://astromagazin.ro/accesorii-telescop...html?_gl=1*zum2ra*_up*MQ..*_ga*MjAwMDkzOTEyOC4xNzY2MTM4NTc3*_ga_YDL4LWHWLK*czE3NjYxMzg1NzYkbzEkZzAkdDE3NjYxMzg1NzYkajYwJGwwJGg1NjIxNjEzOTI.
Greutate: 91 g
Tip ocular: Flat-field
Diametru conexiune: 1,25”
Câmp vizual: 60 grade
Distanță de vizualizare: 16 mm
Distanță focală ocular: 5,5 mm
https://astromagazin.ro/oculare/11952-ocul...15-mm.html
Distanta focala (mm): 7.2-21.5mm
Camp vizual propriu (°): 40 la 21.5
Camp vizual propriu (°): 60 la 7.2
Numar de lentile: 7, 4 grupuri
Distața de vizualizare: 15mm
https://astromagazin.ro/corectoare-reducat...html?_gl=1*9x52rr*_up*MQ..*_ga*MjM2NjczODQ0LjE3NjYxNDE2MTg.*_ga_YDL4LWHWLK*czE3NjYxNDE2MTckbzEkZzAkdDE3NjYxNDE2MTckajYwJGwwJGg4NTc5MTcyNDA.
Acoperire antireflex: completă, multiplă
Număr lentile: 4
Factor de mărire: 0,63x
Tip constructiv: reducator focala
Conexiune spre ocular: filet SC
Conexiune spre telescop: filet SC
https://astromagazin.ro/corectoare-reducat...-f63-.html
Număr lentile: 4
Distance from camera chip to the front part of the optical component is 85mm
Pachet
Telescop Omegon AC 90/500 OTA
https://www.astroshop.ro/telescoape/omegon...ifications
Tip: Refractor
Tip constructiv: Achromat
Apertura (mm): 90
Distanta focala (mm): 500
Raport focal (f/): 5,5
Putere de separatie: 1,15 (Rayleigh)
Magnitudine limita (mag): 12,2
Putere de marire utila maxima: 80 (empfohlen)
Greutate tub (kg): 2,2
- Ocular Sky Watcher LEW GoldLine 6mm, (CV 66 grade), eye relief 14mm, FMC, Type WA
- Ocular Sky Watcher LEW GoldLine 9mm, (CV 66 grade), eye relief 14mm, FMC, Type WA
- Ocular Sky Watcher LEW GoldLine 20mm, (CV 66 grade), eye relief 14mm, FMC, Type WA
Diagonala 1.25"
Filtru 1,25" Semi APO (planoptic)
https://www.astroshop.ro/alte-produse/baad...c-/p,10901
Binoclu
BRESSER Pirsch ED 15x56 Binoculars with Phase Coating
https://www.bresser.com/p/bresser-pirsch-e...ng-1721557
Accurate colour imaging thanks to high-performance ED glass
Waterproof and filled with argon gas
A brighter image thanks to dielectric coating
Dimensions: 161 x 147 x 66 mm; Weight: 981 g
Very high contrast image thanks to phase coating
 Marime fisier:  334.28 kb
 Vizualizat:  de 4000 ori
 Marime fisier:  177.41 kb
 Marime fisier:  156.03 kb
 Marime fisier:  157.17 kb
 Marime fisier:  172.85 kb
 Marime fisier:  173.79 kb
 Marime fisier:  207.98 kb
 Marime fisier:  189.59 kb
 Marime fisier:  206.35 kb
 Marime fisier:  194.79 kb
 Marime fisier:  151.66 kb
 Marime fisier:  166.37 kb
 Marime fisier:  192.13 kb
 Marime fisier:  315.36 kb
 Marime fisier:  146.85 kb
 Marime fisier:  215.05 kb
 Marime fisier:  235.98 kb
 Marime fisier:  292.08 kb
 Marime fisier:  254.42 kb
 Marime fisier:  296.76 kb
 Marime fisier:  155.95 kb
 Marime fisier:  180.66 kb
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 19 Dec 2025 22:29 Download mesaj
Reducer Celestron rezervat
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 19 Dec 2025 23:51 Download mesaj
binoclu rezervat
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 20 Dec 2025 16:02 Download mesaj
*** Reducer Antares vandut
Recapiturare la ceea ce mai este de vandut:
O completare la pachetul cu luneta: nu vand separat, pentru ca asa cum l-am facut este un pachet bun pentru vizual. A facut cineva pe youtube poze cu aceasta luneta si nu erau rele rezultatele, dar departe de un ED sau APO; dar cand nu ai altceva, folosesti ce ai.
Chiar daca ma repet este o luneta acromata, pentru vizual. Un RFT foarte bun.
Filtrul Semi APO reduce semnificativ aberatiile cromatice. Luna vazuta prin aceasta luneta este superba; are foarte putin CA pe margine, nederanjant.
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 23 Dec 2025 10:05 Download mesaj
Actualizare:
Binoclu BRESSER Pirsch ED 15x56 === vandut ===
Reducator/corector Celestron f/6,3 === rezervat ===
Reducator/corector Antares f/6,3 === vandut ===
Inca la vanzare:
Pachet Refractor 90/500 + 3 Oculare + Filtru Semi APO + diagonala = 900
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 29 Dec 2025 20:21 Download mesaj
Reduceri de pret:
Ocular Omegon Flatfield 19mm = 190 RON
Ocular Omegon SWA 10mm = 190 RON
Ocular Lacerta Premium Flat Field 5.5mm = 110 RON
Tecnosky HD 7.2mm - 21.5mm = 340 RON
Pachet Refractor 90/500 + 3 Oculare + Filtru Semi APO + diagonala = 850 RON
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 05 Ian 2026 10:29 Download mesaj
valabile.
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 13 Ian 2026 10:13 Download mesaj
pachet rezervat
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 23 Ian 2026 09:20 Download mesaj
Pachetul a fost vandut.
Au mai ramas (cu o actualizare de preturi):
Ocular Omegon Flatfield 19mm = 150 RON
Ocular Omegon SWA 10mm = 150 RON
Ocular Lacerta Premium Flat Field 5.5mm = 100 RON
Tecnosky HD 7.2mm - 21.5mm = 300 RON
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 02 Feb 2026 09:36 Download mesaj
valabile
Tecnosky HD 7.2mm - 21.5mm = 290 RON
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 10 Feb 2026 14:16 Download mesaj
valabile
SAGA ED 15x56
SAGA ED 10x42
gpaunescu
MesajTrimis: 10 Feb 2026 19:36 Download mesaj
Se poate inchide si va multumesc pentru gazduire.
O sa deschid un nou topic cu ocularele ramase, deoarece, titlul nu prea mai corespunde.
SAGA ED 15x56
SAGA ED 10x42
