Numar total de mesaje in forum: 242336
Schimb procesor ATHLON 64 AM2
Schimba
Mihai F. Dinu
Data inscrierii: 20 Iul 2008
MesajTrimis: 07 Mai 2010 18:55 Download mesaj
Titlul subiectului: Schimb procesor ATHLON 64 AM2
Salut. Schimb preocesor AMD Athlon 64 3200+ AM2 pe ocular pentru un newtonian cu distanta focala de 1100mm, F/D= 7,5, sau luneta cautatoare. Mentionz ca dau si radiatorul cu cooler la el.Aici datele procesorului:
Type CPU / Microprocessor
Family AMD Athlon 64
Model number ? 3200+
CPU part number ADA3200IAA4CW
Box part number ADA3200CWBOX
Stepping codes LDB4F LDBFF LEDBF NDBDF
Frequency (MHz) ? 3200+ (rated)
2000 (real)
Package 940-pin organic micro-PGA
Socket Socket AM2
Introduction date May 23, 2006
Architecture / Microarchitecture
Processor core Orleans
Core stepping F2
Manufacturing process 0.09 micron SOI
164 million transistors
Die size 103.1 mm2
Data width 64 bit
Number of cores 1
Floating Point Unit Integrated
Level 1 cache size ? 64 KB 2-way associative instruction cache
64 KB 2-way associative data cache
Level 2 cache size ? 512 KB exclusive 16-way associative cache
Physical memory 1 TB
Virtual memory (TB) 256
Features MMX technology
3DNow!
SSE
SSE2
SSE3
AMD 64 technology
Enhanced Virus Protection ?
Low power features Halt state
Stop Grant state ?
Cool'n'Quiet technology
On-chip peripherals Dual-channel DDR2 SDRAM memory controller
HyperTransport link
Electrical/Thermal parameters
V core (V) ? 1.25 / 1.35 / 1.4
Maximum operating temperature (°C) ? 55 - 69
Thermal Design Power (W) ? 59
Notes on AMD ADA3200IAA4CW
In the minimum performance state (P-state) the processor runs at 1000 MHz and 1.1 Volt core voltage. Thermal Design Power in the minimum P-state is 29.8 Watt
Il dau cu tot cu radiator si cooler. Merge brici. Vara nu sare mai mult de 45 grade full load.
 Marime fisier:  50.57 kb
 Vizualizat:  de 1986 ori
Creaza un subiect nou   Acest subiect este inchis, nu se pot crea sau raspunde la mesaje   Schimba
