metalgibson Membru
Data inscrierii: 20 Sep 2012 Mesaje: 211
Motto: iubiti cerul! acolo se ascunde viitorul nostru Localitate: Stefan Voda
Trimis: 10 Iun 2016 15:59 Download mesaj |
| Titlul subiectului: Transformare oglinda sferica in parabolica fara slefuire |
Dragi colegi!
Precum Kit-urile de oglinzi sferice sunt mai ieftine decit cele parabolice , pe net:
200mm/F800mm spherica la 99-120$
150mm/F750mm spheric la 40-60$
114mm/F900mm spheric la 30-50$
3" 76mm f/11.8 la 11-20$
pentru incepatori ar fi un avantaj
am gasit o informatie ,nu stiu cit e de practica , o pun la discutie /dezbateri
Spherical mirrors can be pulled into a parabolic curve by a method known as flexing. The result is often better than a polished parabolic mirror if done properly as parabolic mirror generally have a rough surface and spherical mirrors generally have a smooth surface. Here is a link about mirror flexing to answer any questions about it:
http://www.skyandtelescope.com/wp-content/...orFlex.pdf
Spor la cercetare ! _________________ Meade DS2114 cu montura dobson home made;refractor 70/1200mm homemade;Celestrone Astromaster 130 homemade.cctv LN300,goto Celestron GT,Sakura zoom 20x70,Datyson 10x50 |
Herr_Alien Moderator
Data inscrierii: 11 Noi 2010 Mesaje: 1081
metalgibson Membru
Trimis: 10 Iun 2016 16:22 Download mesaj |
iata de softuri n-am dat ,,multumesc Herr_Alien !
Alex ai incercat si practic ? ceva rezultate? sau doar ca lectura _________________ Meade DS2114 cu montura dobson home made;refractor 70/1200mm homemade;Celestrone Astromaster 130 homemade.cctv LN300,goto Celestron GT,Sakura zoom 20x70,Datyson 10x50 |
Trimis: 10 Iun 2016 16:23 Download mesaj |
| Titlul subiectului: Re: Oglinda Sferice in Parabolica fara slefuire |
| metalgibson a scris: | | .. mirror flexing.. |
Hmm, dar dece nu o flexeaza ei, o slefuiesc sferic, iari cand ii dau drumul devine parabolica si ramane sa fie utilizata asa. |
Stanescu Octavian Membru
Data inscrierii: 02 Apr 2006 Mesaje: 3747
Trimis: 10 Iun 2016 16:53 Download mesaj |
| Nu e asa simplu spre margine tot mai tare trebuie indoita , se poate flexa ceva destul de aproximativ nu cred atingi la 10 30 nm suprafata ideala |
metalgibson Membru
Trimis: 10 Iun 2016 19:58 Download mesaj |
| valy a scris: | | metalgibson a scris: | | .. mirror flexing.. |
Hmm, dar dece nu o flexeaza ei, o slefuiesc sferic, iari cand ii dau drumul devine parabolica si ramane sa fie utilizata asa. | .
Pai vezi în articol se spune că cele sferice au un avantaj suprafață e mai neteda decit la parabolice,si dacă o flexezi poți obține parametri mai buni de reflecție decit la cele parabolic șlefuite. Si cum adică so flexeze si să-i daie drumul? Ei mereu o țin flexata în acel dispozitiv,suport pentru oglinda? Ia va reveni la sfericitate dacă sa dezsurubezi ,nu ? _________________ Meade DS2114 cu montura dobson home made;refractor 70/1200mm homemade;Celestrone Astromaster 130 homemade.cctv LN300,goto Celestron GT,Sakura zoom 20x70,Datyson 10x50 |
Trimis: 10 Iun 2016 20:05 Download mesaj |
| Eu ziceam ca o flexeaza, ei o slefuiesc ca fiind sferica, iese bine si toate avantajele, dupa care ii dau drumul si revine la forma initiala, iar sferica se va deforma si va deveni parabolica. |
metalgibson Membru
| Stanescu Octavian a scris: | | Nu e asa simplu spre margine tot mai tare trebuie indoita , se poate flexa ceva destul de aproximativ nu cred atingi la 10 30 nm suprafata ideala |
Pai lu acei doi neni din articol ,li se reușește, da au si tehnologii corespunzătoare să obțină ceva bun,cu precizie
Si cu bani putini poți avea un telescop de 20cm ,,,,de exemplu la meadul meu e oglinda sferică, nu văd că stelele după forma sa se alungeasca spre margine _________________ Meade DS2114 cu montura dobson home made;refractor 70/1200mm homemade;Celestrone Astromaster 130 homemade.cctv LN300,goto Celestron GT,Sakura zoom 20x70,Datyson 10x50 |
Trimis: 10 Iun 2016 20:17 Download mesaj |
O mare prostie dupa cum vad din ochi din prima imagine de sus cu lipirea cu rubber si adeziv si tragerea cu surub cu arc totul e complet gresit este doar joaca unor pensionari zgarciti sa nu aiba bani de o oglinda de 8 " parabolica  |
tavi 84 Membru
Data inscrierii: 28 Iun 2013 Mesaje: 563
Localitate: Roman
Trimis: 10 Iun 2016 22:09 Download mesaj |
Fata de pretul unui focuser mai bun,corector de coma,niste oculare decente pentru rapoarte focale mici,diferenta de pret de la oglinda parabolica la cea sferica devine nesemnificativa.De vreme ce solutia asta nu s-a impus pe nicaieri,inseamna ca sunt motive bune. _________________ Pentax SP 20X60 WP |
Trimis: 10 Iun 2016 23:33 Download mesaj |
| metalgibson a scris: | | Alex ai incercat si practic ? ceva rezultate? sau doar ca lectura |
Doar lectura . _________________ Alex
Astronomical Ephemerides |
Trimis: 11 Iun 2016 08:39 Download mesaj |
Principalul inamic al obținerii unei forme corecte sunt omogenitatea și tensiunile interne ale sticlei pe care n-ai cum să le controlezi, depinde de procesul de turnare și tratamentul termic ulterior de normalizare. Ori sticla este de fapt un lichid care curge extrem de lent, nu un solid. Suprafața va avea diferite defecte față de parabolă în funcție de aceste tensiuni interne. _________________ bino: 8x22, 7x42, 10x50, 10x80, spotting: 10x46, 20x60
Data inscrierii: 12 Feb 2008 Mesaje: 10109
Trimis: 11 Iun 2016 12:24 Download mesaj |
Trebuie sa-l intelegeti insa pe metalgibson si motivul pentru care intreaba.
Nu are la indemana pe cineva care sa-i parabolizeze o asemenea oglinda.
De aceea cauta solutii alternative.
Solutia alternativa in folosirea oglinzilor sferice exista si aceea este oglinda sferica cu raport F/D mare.
O oglinda de 114mm la 1.5 metri focal de pilda.
Sau 15 cm diametru si 1.8 metri focal.
La acestea diferenta dintre foram sferica -daca este buna , evident- si parabola este atat de mica incat practic nu incomodeaza.
Si scapi de hamuri si deformari si reglaje interminabile.
metalgibson Membru
Trimis: 13 Iun 2016 08:55 Download mesaj |
Dar solutia cu lentila Barlow? doar la multe telescoape cu oglinzi sferice in focuser sint instalate lentile barlow? Cum spui Mircea pentru a avea focala lunga "Si scapi de hamuri si deformari si reglaje interminabile."...dar se pierde din luminozitate? _________________ Meade DS2114 cu montura dobson home made;refractor 70/1200mm homemade;Celestrone Astromaster 130 homemade.cctv LN300,goto Celestron GT,Sakura zoom 20x70,Datyson 10x50 |
Trimis: 13 Iun 2016 13:52 Download mesaj |
| Pai cu banii de barlow platesti si o faci parabolica din prima. |
