Data inscrierii: 12 Feb 2008 Mesaje: 10015
Trimis: 08 Feb 2012 01:28 Download mesaj |
| Titlul subiectului: Donatie telescop 508 mm |
Prin amabilitatea doamnei Trudy E. Bell,via ''Antique Telescope Society'' Forum,aflam ca acest telescop tip Cassegrain-Gregory- Ritchey- Cretien ,construit de catre Grubb Parsons pentru Observatorul Regal din Edinburgh,este oferit ca donatie vreunei societati/asociatii de astronomi interesate.
Nu sunt subiect al donatiei montura ecuatoriala si cupola.
The Royal Observatory Edinburgh (ROE)
will be decommissioning a telescope as
part of a refurbishment project. If an astronomical
society is interested in taking this
off their hands, they should make contact
as soon as possible. The contact at the
ROE is Mark Collins. See below for contact
details.
For time scales, the work on the refurbishment
should start in early April 2012.
The dome will be retained by the ROE; also
the pillar, obviously. The was apparently
built by Grubb Parsons in 1967. It
comprises of the optical tube assembly, the
equatorial mount with counterweight, and
several large racks of 1960's electronics
and electrics. The counterweight is situated
low above the dome floor, rather
than at telescope level on the declination
axis.
The telescope is a reflecting telescope, a
Cassegrain, Gregory or Ritchey-Crétien
design. (I have not seen the secondary
without its dust cover.) The aperture is
20 inch (50 cm). I am not sure of the fratio.
For a length estimate, the telescope
is currently in a dome of about 5 metre
diameter. The dome is not included. To extract the telescope, the dome will be lifted off
the building, the telescope craned out in one piece into a palletised container, and the
dome put back in place. This should happen some time this spring.
Contact:
Mark Collins
Blackford Hill
Edinburgh, EH9 3HJ
<mark>
22.13 kb |
de 9216 ori |
Herr_Alien Moderator
Data inscrierii: 11 Noi 2010 Mesaje: 1081
Trimis: 08 Feb 2012 09:39 Download mesaj |
... cui trimitem PM ?
---------- edited ------------
Lasand gluma la o parte, mai rar vede omul asemenea anunt.
_________________ Alex
Astronomical Ephemerides |
Jabba the Hutt Membru
Data inscrierii: 22 Aug 2011 Mesaje: 145
Motto: Lex et ordo Localitate: Constanta
Trimis: 08 Feb 2012 10:20 Download mesaj |
| Cred ca Observatorul de la CMSN Constanta s-ar bucura sa il primeasca.
MikeC Membru
Data inscrierii: 08 Mai 2010 Mesaje: 262
Localitate: Bucharest
Trimis: 08 Feb 2012 12:42 Download mesaj |
Cred ca orice observator din romania s-ar bucura sa il primeasca... problema e cine s-ar bucura sa il folosesca la MAXIM... ptr ca la noi si echipamentul actual e tinut inchis undeva intr-o camera prafuita...
Frumos instrument, mai mult ca sigur nu va ajunge undeva la noi, pentru ca doar costul de transport pus un cost al unei monturi destul de sanatoasa, ar linsa orice demers in sensul asta.
_________________ Cer senin si negru tuci!
Equipment: Vixen 60mm f/15 refractor, Astrotrac TT320X-AG |
UniversTheory Membru
Data inscrierii: 24 Mar 2011 Mesaje: 51
Motto: Daca nu ai un instrument , fa-ti unul . Localitate: Galati
Trimis: 10 Feb 2012 12:25 Download mesaj |
Buna Ziua !
Sunt initiatorul astroclubului Cassiopea si demult ne dorim un telescop
Suntem din jud.Galati com. Schela
_________________ Membru al Astroclubului Calin Popovici
Presedinte al Astroclubului Cassiopea
SKW 60/900 EQ1 , SKW 60/700 AZGT , HM 200degres Camera , Canon EOS 500D |
Stanescu Octavian Membru
Data inscrierii: 02 Apr 2006 Mesaje: 3741
Trimis: 10 Feb 2012 12:58 Download mesaj |
daca ati vorbi cu directorii de pe la observatoare nimeni nu ar putea primi acest instrument . odata hartoagele si aprobarile apoi banii alocati pentru transport montura si modificari la montura.
instrumentul probabil are peste 200kg cat ar costa montura pe masura lui ???
ursamajor Membru exclus
Trimis: 10 Feb 2012 13:13 Download mesaj |
achy1978 Membru
Trimis: 10 Feb 2012 14:29 Download mesaj |
Cred ca problema se pune doar pentru transport..... Montura este si ea dontata impreuna cu instrumentul!
Ne batea si pe noi gandul sa trimitem o scrisoare de intentie insa ........
SRCSTV - www.srcstv.ro
SARM - www.sarm.ro |
Trimis: 10 Feb 2012 17:25 Download mesaj |
| Domnule Pteancu, cunoasteti date de contact ale lui Mark Collins?
Doru Dragan Membru
Trimis: 10 Feb 2012 21:20 Download mesaj |
Toata lumea s-ar bucura "sa primeasca" telescopul asta "moka". Lucrurile se schimba daca se citeste textul cu atentie. Montura se da impreuna cu telescopul. Ce nu se da e pilonul si cladirea observatorului cu cupola. Costurile implicate sunt de transport dar si de demontare (ridicarea cupolei, extragerea telescopului si montarea cupolei la loc). Dupa aia mai intervin costurile de remontare si noua cladire cu pilon cu tot. Nu va faceti nici un fel de iluzii, exista cluburi serioase in Anglia, Franta, Germania, Italia sau Spania. Sau Polonia, Cehia sau Croatia. Iar celor care intentioneaza sa ma acuze de tot felul de lucruri (lipsa de patriotism, lipsa de entuziasm etc.) le sugerez sa puna 1000 de euro langa cei pe care ii pun eu ca sa rezolvam treaba asta.
Astia de pe malul Dunarii (Galati, Braila) viseaza la instrumente babane pe banii statului sau ai Uniunii Europene sau pe banii dnei Udrea sau ... orice in afara de banii lor pusi jos
horatius Membru
Trimis: 10 Feb 2012 22:31 Download mesaj |
Operatiunea de extragere si demontare profesionista pe care o implica acest telescop, astfel incat sa poata si fi reinstalat inapoi in alt loc si sa fie la fel de functional pe cat era inainte de extragere costa destul de mult, mai ales in Anglia. Nu poti veni cu macara, mana de lucru si scule de acasa, ci vor trebui platite la fata locului la preturi englezesti. Iar o asa operatiune costa. Si apoi daca tot l-ai adus in ograda proprie dupa eforturi de toate tipurile, urmeaza dilema majora: pe ce si cu ce construiesti o cupola si un pilon de mai multe tone pentru noua jucarie? Vreo 50 de insi care s-ar intelege intre ei, fiecare cu 1000 euro ar rezolva insa dilemele. Sa nu ne gandim si la renovarea lui, cel mai probabil are nevoie de reparatii mai mult sau mai putin capitale. Dar ma indoiesc ca va ajunge pe aici un asemenea telescop sau macar asemanator. Si mai cred ca prioritate au cluburile englezesti, care s-ar putea sa dispuna si de finante mai serioase, mai multe decat (nu) au cluburile (sau familiile) autohtone.
_________________ Horatius
STARMAX Astronomie
www.skywatcher.ro
www.starmax.ro |
Data inscrierii: 02 Apr 2010 Mesaje: 5270
Trimis: 10 Feb 2012 22:39 Download mesaj |
Mai bine spus, telescopul nu se da, ci trebuie luat de acolo cu tot ce tine de el.
Asta presupune un pic de logistica la 3000 de km de fotoliul cald de director bugetar.
La ce dimensiuni are cred ca vorbim de tone.
Nu reiese clar cine il scoate si nu se cunoaste exact starea lui.
Si daca nu se cere nimic pe el, nu tu licitatie, de unde bani de spaga ?
Este in garantie ? Ce donatie mai e si asta ?
Iara vor capitalistii de europeni sa ne bage pe gat toate secon-handurile lor si sa polueze aerul si pamantul stramosesc.
@Doru Dragan
Hai sa zicem ca, prin puterea gandului, acel telescop ar aparea in Romania, frumos impachetat.
Ce crezi ca s-ar intampla cu el ?
Ultima modificare efectuata de catre nobody la 10 Feb 2012 22:58, modificat de 1 data in total |
mflorian Membru
Localitate: Tg Mures
Trimis: 10 Feb 2012 22:44 Download mesaj |
Cît e kilu de fier vechi?
_________________ Celestron C8 SGT XLT Advanced GOTO
Nikon D7000 |
Doru Dragan Membru
Trimis: 10 Feb 2012 22:50 Download mesaj |
@nobody: raspunsul ti l-a dat mflorian [/b]
Trimis: 11 Feb 2012 18:22 Download mesaj |
In mesajul postat pe ATS Forum,adresa lui Mark Collins este incompleta,fiind data doar pana la ''@".
Nu am informatii in plus si nici nu am ''sapat'' mai departe deoarece nu ma intereseaza personal un telescop de 50cm.
Societatile de amatori din UK nu cred sa reprezinta o concurenta foarte viguroasa,acest telescop nu are GoTo,nu are accesorii digitale fitoase ,partea electronica este de nivel ''1960 toamna,pe inserate'',in trusa de oculare (m-as mira sa existe) precis nu exista ethos-urile dupa care lesina lumea buna acuma,este foarte masiv deci greu de demontat....
Deci este vorba de un instrument prea putin atractiv.
Englezii sunt maestrii in arta comunicarii si socializarii.
Inainte ca acest mesaj sa fi luat un aspect oficial,va garantez ca multe societati de amatori au fost imbiate dar au refuzat oferta.
Donatiile de acest gen costa chiar daca par a fi gratis.
Urez succes celor care-l doresc.
Ar fi pacat ca o asemenea bijuterie sa ajunga la retopit.Sunt sigur ca este ''o bijuterie de instrument'' deoarece Grubb Parsons au construit telescoape pentru observatoarele profesioniste si pentru sistemul de educatie.
