Numar total de mesaje in forum: 243827 |
Data inscrierii: 12 Feb 2008 Mesaje: 10339
Trimis: 04 Ian 2013 19:23 Download mesaj |
mersi de raspuns,deci mai bine raman la ocular Galilei simplu +lentila Barlow,nu castig nimic in varianta ,,singlet pairs''...decat aberatii in plus .
cum ar zice snobu' :,,go for it''
Succes,un ortoscopic Abbe pe un Maksutov ,trebuie sa fie o combinatie castigatoare.
Data inscrierii: 31 Mar 2006 Mesaje: 6259
Trimis: 05 Ian 2013 19:18 Download mesaj |
| Mircea Pteancu a scris: | | ... mai bine raman la ocular Galilei simplu +lentila Barlow ... |
Daca-mi aduc bine aminte, in urma cu vreo doi ani ne propusesem ca in 2012 sa construim niste oculare Galilei cu focale mici. Se pare ca n-a fost sa fie dar poate reusim anul asta.
Doamne ajuta!
Trimis: 12 Ian 2013 19:48 Download mesaj |
stiu ca ai intrebat despre ocularele ortoscopice Kasai dar poate ca te intereseaza raspunsul de mai jos dat de catre karlfabian lui Chris Trask pe ,,60mmtelescopeclub''.
Oarecum si ocularele Orbinar ,recent aparute pe piata,sunt legate de topicul ,,Oculare extreme'' deoarece sunt oculare Plossl care ofera o calitate buna,camp mediu de 43 grade la f=40mm pana la 48 grade la focale mai scurte,constructie 100% metalica ,cu filet pt filtre,la un pret extrem sub 20 dolari/buc.Poate-l intereseaza pe nobody sau pe altii.Scuze de off-topic.
[60mmtelescopeclub] Re: 1.25" Eyepieces
Show Details
Hi. I have accumulated a pretty large collection of eyepieces over the last 35 years including some of the classics like Meade Research Series and University Orthoscopics, Edmund RKEs, UO Konigs etc, so I know a decent eyepiece when I see one. I need more eyepieces like a hole in the head but those Seben Orbinars you mentioned got me interested because of their incredibly low price with free shipping. I could not resist so took a chance and ordered a 40mm and 25mm a few months ago. I was not expecting much at that price, but when they arrived I was pleasantly surprised with the quality for the price. They are nicely constructed all metal with chromed barrels threaded for filters and fold down eye cups. The optics are coated 4 element and compare to most decent 4 element Symmetric Plossls delivering well corrected images. The 40 mm has nice big eye and field lenses limited only by the inside diameter of the barrel and gives the widest field possible (43 degrees)with the 1.25 inch format. The 25 mm has a comfortable 45 degree field. Both eyepieces are very comfortable to use with just the right eye relief for their focal length. I was so impressed with the quality for the price I ordered a 15, 10, 6.5 and 4mm. They are all decent eyepieces worth far more than what they are going for especially the medium and short focal lengths that cost about the same or less than those cheaply made plastic body Kellners or MAs that abound on Ebay. The fields are not huge ranging from 41 to maximum of 48 degrees but the optical correction and sharpness are good even in my F5 Schmidt Newtonian. For your Meade 90mm 395 which has a 1000mm focal length a 10mm would provide a nice crisp medium high power view of Jupiter at 100x. A 25mm would be a good low power. I owned a Meade 395 in the past and it provided very decent planetary images up to at least 150X with 200x useful for close double Stars, Moon detail or Mars (Mars needs high power due to the small disk). You might want to start with the 25 and 10mm and perhaps add a good 2X barlow for 40, 80, 100, 200x. Or perhaps a 25mm and 15 mm with a 3x barlow for 40x, 67x, 120x, 200x.
Clear Skies,
Karl
Trimis: 02 Feb 2013 23:00 Download mesaj |
Dupa cum am semnalat,am primit de vreo trei saptamani ocularul Solid Simetric de 12.8mm de la tine.
Chiar in seara in care a sosit am facut primele teste pe mica mea luneta D=45mm F/6.6 cu obiectiv militar , la G=aprox. 12x si am constatat, comparativ cu ocularul Zeiss Kellner f=16.7mm ,o tenta mai rece a imaginii si o protectie incomparabil mai buna fata de lumina parazita decat la SR.
Saptamanile au trecut dar capacul plumburiu de cavou trantit peste capetele noastre nu s-a mai dat la o parte.
In aceasta saptamana am avut totusi parte, Miercuri seara ,timp de vreo 20-30 de minute, de cateva petece de cer vizibil printre nori.Am vrut sa incerc ocularul SS 12.8mm dar turbulenta a fost groaznica,nici urma de inele de difractie,stelele pareau a fi fiecare o papadie de lumina,sa fi fost un seeing de 2 sau 3 pe scara Pickering.
Dar chiar si asa pot sa iti spun ca pe dobsonianul de 125mm la F/14 / SS 12.8mm +Barlow 2x,la 135x,in ocularul SS se zareau cinci benzi pe Jupiter.Iar acest ocular a rezolvat Lambda Ori cu o separatie de 4 secunde de arc deja la 68x,fara Barlow si dand cele mai mici discuri Airy,per ansamblu cele mai clare,curate imagini.
Iar pe cand am ajuns la Castor,deja acesta incepuse sa fie acoperit de nori subtiri dar totusi am vazut una dintre cele mai frumoase imagini ale acestei duble superbe.Am privit pana ce norii l-au ascuns pe Castor definitiv privirii.
Deci semne bune...ocularul are!
In asteptarea unor vremuri mai bune,Mircea
Trimis: 03 Feb 2013 09:46 Download mesaj |
Mircea, multumesc pentru feedback!
Pentru mine este intotdeauna util deoarece o suma de perceptii duce la o evaluare mai corecta a potentialului real al ocularului.
Si conditiile diferite de seeing si transparenta dintre cerurile vazute de observatori situati in locatii diferite pot scoate uneori la iveala informatii utile.
Tonul cromatic al ocularului este intradevar mai rece pentru ca atunci cand l-am proiectat am abordat o acromatizare in stil Zeiss. A fost un experiment care vroia sa-mi confirme acest lucru si iata ca rezultatul final nu s-a lasat mult asteptat.
Trimis: 14 Apr 2013 09:50 Download mesaj |
Pe vremea cand faceam cercetari asupra ocularului Wollaston mi-a venit ideea sa fac rocada intre lentilele ocularului, sa pun isprava in proiect si sa vad daca iese ceva ...
Am ajuns la un caz particular de ocular Ramsden in care lentilele sunt semisfere.
Dupa cum era de asteptat, pentru noul ocular nu mai sunt valabile relatiile de calcul ale unui Ramsden obisnuit (calcul ce se efectueaza pe baza formulelor valabile pentru lentile subtiri) in schimb prezinta unele proprieteti care mi s-au parut interesante:
- vestitul cromatism transversal caracteristic Ramsdenului cu lentile subtiri nu mai variaza intre pozitiile extreme pe care le pot lua lentilele ocularului (pozitia de contact si pozitia pentru care planul focal vine in coincidenta cu suprafata plana a lentilei de camp). Valoarea lui ramane cvasiconstanta si la un nivel tolerabil (daca limitam campul ocularului la 40-44 grade) pentru toata plaja de variatie a spatierii lentilelor. Aceasta situatie ne da libertatea de a cauta alte proprietati utile/interesante pe care le urmarim de regula la un ocular. Astfel:
-exista o distanta intre lentile pentru care planul focal devine perfect plat (am setat in program curbura imaginii pe infinit) si din fericire situatia asta nu mai are loc pentru coincidenta lui cu suprafata plana a lentilei de camp. Influenta particulelor depuse pe aceasta lentila vor avea in situatia data un impact semnificativ mai mic asupra imaginii.
- tot pentru distanta dintre lentile setata mai sus apare si minimizarea componentei tangentiale a astigmatismului, aberatia ramanand in continuare pe raspunsul ocularului doar prin componenta ei sagitala.
Ceilalti parametri ai ocularului (cromatismul longitudinal, sfericitatea, distorsiile) raman in limite normale pentru un ocular obisnuit.
In imaginile de mai jos analiza unui Ramsden cu lentile semisferice, focala de 4,4 mm si un camp limitat la 40 grade:
<a href="https://picasaweb.google.com/lh/photo/kC0kBXwS4Mt3i0Cbh9pCYtMTjNZETYmyPJy0liipFm0?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-nWz38RKDqGE/UWmjExRA3FI/AAAAAAAAAaU/XRkairT8Z_k/s800/Ramsden%25204%252C4%2520mm%2520ra.jpg" height="391" width="590"></a>
<a href="https://picasaweb.google.com/lh/photo/iYrViWNDZTFJPwL0UFQOd9MTjNZETYmyPJy0liipFm0?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-Mpulb-88F0U/UWmjL7ftU9I/AAAAAAAAAac/cfjGSpqC_38/s800/Ramsden%25204%252C4%2520mm%2520sd.jpg" height="390" width="596"></a>
Si aici un detaliu al planului focal:
<a href="https://picasaweb.google.com/lh/photo/zCI_N5H6RG6I3-QVsrrCfdMTjNZETYmyPJy0liipFm0?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-ocKA_EvrS7c/UWmjPwpYB6I/AAAAAAAAAao/Z8hfExhSZKk/s640/R%25204%252C4%2520mm%2520detaliu%2520plan%2520focal.jpg" height="613" width="640"></a>
Trimis: 14 Apr 2013 13:50 Download mesaj |
O modificare/imbunatatire recenta aplicata acestui ocular a permis cresterea gradului de corectie pentru sfericitate (in special axiala dar si extra axiala), o micsorare cam de doua ori a cromatismului longitudinal si eliminarea in totalitate a astigmatismului tangential cu pastrarea planului focal perfect plat.
Modificarea consta in adaugarea unei lentile corectoare menisc situata inaintea planului focal.
Noul ocular cu o focala de 3,5 mm si un camp de 40 grade sper sa fie numai bun pentru testarea opticii pe stea (aberatia de sfericitate a ocularului fiind corectata la un nivel egal cu L/427) pentru cei foarte pretentiosi dar sa fie bun si pentru duble sau detalii planetare (ramane de vazut ...).
In imaginile de mai jos sunt graficele noului ocular:
<a href="https://picasaweb.google.com/lh/photo/g-tlAgMaxU1Bvujw8nxz2NMTjNZETYmyPJy0liipFm0?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-E0YZ_0TYzqY/UWp5SXr9wjI/AAAAAAAAAa4/HKoGhNKmiUs/s800/Ramsden%25203%252C5%2520mm%2520ra.jpg" height="391" width="590"></a>
<a href="https://picasaweb.google.com/lh/photo/4W7NLksRzmz_UW199PKfX9MTjNZETYmyPJy0liipFm0?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-v9zA9hAOPlQ/UWp5XcO7QVI/AAAAAAAAAbA/PK8x3sVFUMI/s800/Ramsden%25203%252C5%2520mm%2520sd.jpg" height="390" width="596"></a>
PS. Metoda de corectie cu lentila menisc situata inaintea planului focal nu este noua si nici gaselnita personala, in imaginea de mai jos o puteti vedea aplicata de japonezii de la Pentax la ocularul XO 5 mm, un ocular extrem de scump dar si bun:
20.21 kb |
de 15034 ori |
Trimis: 14 Apr 2013 15:25 Download mesaj |
OMG!!! adica OH,MY GOD!!!
Surprizele placute se tin lant pe acest topic,felicitari zoth!
Daca o tii tot asa (si castig eu la Loto ca sa avem capital ) atunci concurenta lui Tele Vue va veni din Romania.
Acuma vorbind serios,experimentele si constructiile tale sunt extraordinar de interesante.
Abia astept continuarea.
Cu toata stima,Mircea
PS:si cand am glumit ,am glumit doar pe jumatate.Radianul ''Tele Vue'' de 6mm este cel mai bun ocular dintre toate celelalte.Dar pe axa, si in jurul ei, a fost depasit la contrast si rezolutie de Solid Ramsden-ul de 8 mm ,chiar daca ultimul avea focalul cu 33% mai lung ca primul ,deci si grosismentul tot cu atat mai mic.
Data inscrierii: 02 Aug 2008 Mesaje: 9971
Trimis: 15 Apr 2013 09:19 Download mesaj |
Felicitări, Silviu!
Întrebare: meniscul nu poate fi adăugat și la ocularele SS pentru a obține un câmp plan? Imaginea lor este ultrasharp la duble și planete și ar fi la fel de bună și la Lună dacă la margine câmpul ar fi plan. Confirmarea celor spuse mai sus am avut-o din nou aseară la mica sesiune de observații împreună cu Mircea.
catalin dumitru Membru
Data inscrierii: 22 Iul 2010 Mesaje: 3020
Trimis: 15 Apr 2013 15:10 Download mesaj |
| Erwin a scris: | Felicitări, Silviu!
Întrebare: meniscul nu poate fi adăugat și la ocularele SS pentru a obține un câmp plan ? |
Eu as paria pe o plan-concava sau un menisc aproape plan-concav, preferabil acromatizat , montat bineinteles cu fatza concava spre obiectiv.
Se poate experimenta cu asa-zisul barlow de la intrarea unora dintre binocularele de microscop.
catalin.
Trimis: 17 Apr 2013 21:42 Download mesaj |
| Erwin a scris: | | Întrebare: meniscul nu poate fi adăugat și la ocularele SS pentru a obține un câmp plan? |
Teoretic ar fi posibil insa nu trebuie sa uitam ca orice element optic introdus intr-un sistem modifica toti parametrii caracteristici ai acelui sistem. In cazul nostru ocularul SS a fost acromatizat si corectat ca un ansamblu de sine statator. Daca vom introduce lentila menisc vom putea relaxa curbura planului focal dar in acelasi timp vom strica acromatizarea ocularului si foarte probabil si alti parametri ce fusesera deja optimizati.
Adaugarea lentilei menisc (in fapt o lentila Smyth in forma ei cea mai simpla) este bine venita in general la ocularele neacromatizate sau in stadiul de proiectare al unui ocular, mai tarziu ar putea face mai mult rau decat bine.
Multumesc de interes
Ultima modificare efectuata de catre zoth la 17 Apr 2013 21:47, modificat de 1 data in total |
Trimis: 17 Apr 2013 21:47 Download mesaj |
Am înțeles.
Atunci trebuie luată ca temă de viitor: proiectarea unui hibrid solid cu corecția aberației de sfericitate. Poate se obține și un câmp un picuț mai mare?
Trimis: 18 Apr 2013 08:35 Download mesaj |
Fiind unul care se pare ca m-am jucat cel mai mult cu ocularele Solid Ramsden si Simetric Solid de pe aici,dupa autorul lor fireste,as vrea doar sa subliniez ca ,desi inteleg cererile spre imbunatatirea parametrilor gen camp vizual aparent sau planeitate plan focal,acestea ar deteriora iremediabil caracteristica principala a ocularelor extreme:parametrii maximizati pentru un numar minim de suprafete aer-sticla.
Sa nu credem cumva ca dupa adaugarea de n+ lentile,se vor mai pastra rezolutia si contrastul fantastic pe care aceste oculare le au acum.
Lucrez in Marketing de peste un an si ranjesc cu gura pana la urechi de cate ori citesc declaratii admirative la adresa unui ocular deoarece ...are greutatea de un kil...sau ca iti da... senzatia de grenada.
Dom'le,unii stiu multe despre sufletul omenesc...iar cine stie,cunoaste!
Trimis: 01 Mai 2013 16:38 Download mesaj |
Azi am reusit sa finalizez inca un ocular extrem. Initial voiam sa renunt la proiectele ocularelor Galilei dar la insistentele lui Mircea am demarat lucrarile pentru focala de -9mm.
Ce a iesit vedeti in imaginea de mai jos:
Dedesubt este lentila ce echipeaza acest ocular in faza ei initiala si apoi inegrita pe margine.
La probele terestre pe acromatul de 60mm f/14, ocularul arata un contrast asemanator cu cel al ocularelor din seria SS. Campul este extrem de mic ~ 8 grade, apare firesc senzatia de tunelare dar imaginea este frumoasa.
130.01 kb |
de 14784 ori |
