Numar total de mesaje in forum: 238037
Numar de utilizatori inregistrati: 2901
Cel mai nou utilizator inregistrat: crx
Filtru pentru observarea galaxiilor?
Michel Ardan
Data inscrierii: 19 Apr 2013
Motto: Sunt răspunzător pentru ceea ce scriu și nu pentru ceea ce înțelegi tu.
Localitate: bucuresci
MesajTrimis: 04 Iun 2013 09:08 Download mesaj
Khristiansen
Data inscrierii: 14 Mar 2012
Localitate: in this Universe
MesajTrimis: 04 Iun 2013 09:18 Download mesaj
Michel Ardan a scris:
Ideea unui binoclu gigant este interesantă, însă cât în plus ar aduce față de folosirea unui binocular la un telescop ?
uite ce zice Chriske de pe Cloudy Nights
"I've build a few binos myself so far, one 6' two 10".
This very moment busy building two other binos(at the same time.). One 10" f/25 DK and a 20" f/5 Newt.
The views or more than pleasing, that I can assure you. You will be glad you've done it once you look through one. When I looked through one the very first time myself I new I would never build a single scope (for personal observing) ever again. Care must be taken the focal lenght of the scopes are identical (or almost). The longer the focal lenghts of the scope the more critical this problem becomes. In the process of building a bino, while grinding polishing, you completely have the process in your owne hand. In case of my 10" DK project I polish 4 sets of mirrors simultaneously. This will be done using the same pitch for all mirrors. At the end of the process I'll choose the best matching sets of mirrors to have the two scopes identical, no problem there.
In your case using two commercial scopes, hope for the best. Maybe, just maybe, both the focal lenght of the two scopes are identical, or near. For a 'short' Newt an error of (about) 0.5 % is allowed. The brain will not allow larger errors. I don't know the exact figure for a long focus bino (21')....yet..
In the past I've compared the views, real bino (two scope) with binoviewers side by side. NO way you can compare these two at all..! With two scopes there's a gain in all aspects of observing : light, color, contrast, resolving power. You even get a 3D effect as a bonus. It's really stunning to see this effect. This so called 3D is nothing more than the result of the two sepparate air-tunnels you're looking through. Very nice btw.
To be clear on the matter using a binoviewer observing will become relaxed compared with single-eye observing, very true. But nothing will ever beat real binos...!
Just do it...!"
pentru cine e interesat sa citeasca tot:
http://www.cloudynights.com/ubbthreads/sho...t/#2729354
MesajTrimis: 04 Iun 2013 10:23 Download mesaj
Da e minunat sa ai binoclu din 2 telescoape sunt convins ca se vede grozav.
Sa vedem Atemisti romani cati sunt ? foarte putini ... si mai putini ar incepe lucrari pentru un super binoclu. Un rezultat bun este si prin adaptor binocular chiar daca cele ieftine nu ofera camp prea larg si necesita barlow la intrare .
totusi sa ramanem la topicul deschis pentru filtru pentru galaxii la care spera colegul nostru .
tsa
Data inscrierii: 03 Iun 2011
Localitate: Cluj
MesajTrimis: 04 Iun 2013 10:44 Download mesaj
MrMxyzptlk a scris:
tsa a scris:
E totusi ciudat ca nu exista un filtru care sa ajute la galaxii si roiuri.
Nu este ciudat. Pana cand nebuloasele au emisii bine definite, galaxiile si roiurile nu au. Aceste obiecte sunt full spectrum, deci vezi ceva in cam toate spectrele de culori. In momentul in care adaugi un filtru si tai ceva din spectru in acel moment ai si pierdut ceva detalii din galaxia sau roirul respectiv. Cu cat este adugat mai multe spectre taiate cu atat pierzi mai multe detalii din galaxii. Daca folosesi narrow band in acel moment ai taiat prea mult. De aceea filtrele de galaxii dedicate nu exista: pur si simplu nu este posibil.
Da, asa este. E infinit mai usor sa izolezi numai OIII (oxiden dublu ionizat emitand in 500.7 nm si 495. 9 nm) care domina nebuloasele difuze si planetare si sa ai deja cele mai multe obiecte de acest gen, decat sa produci filtre combinate in asa fel incat sa-ti dea imagini la diferite aspecte ale galaxiillor. La o adica m-as multumi sa vad cu un filtru anume bratele spirale, cu altul sa zicem zona de nucleu, etc. al galaxiilor. Dar e cam greu.
Totusi sper ca o sa apara ceva pe piata, ca nu degeaba se chinuie producatorii cu diferite combinatii de filtre broadband. Smile
reflector: Dobson 254 mm, Sky-Watcher
Filtre: Astronomik UHC, Lumicon OIII, Lumicon H-Beta.
tsa
Localitate: Cluj
MesajTrimis: 04 Iun 2013 11:45 Download mesaj
Khristiansen a scris:
Nu stiu cat de multa lumina poate aduce in plus un 10" fata de 8". Dar tind sa cred ca un binoclu cu lentile de 100mm poate bate un dob. de 10".
Daca iti poti permite si ai putin sange de ATM-ist in tine ia-ti doua mak-uri de 127mm si fa-ti un superbinoclu. Sau doua refractoare...
Buna idee. Dar daca e sa fac un superbinoclu, o sa fac din doua tuburi newton de 10" Smile
StarChild
Data inscrierii: 29 Mar 2011
MesajTrimis: 04 Iun 2013 12:59 Download mesaj
tsa a scris:
Nu stiu cat de multa lumina poate aduce in plus un 10" fata de 8". Dar tind sa cred ca un binoclu cu lentile de 100mm poate bate un dob. de 10"....
10" fata de 8" aduna 56.25% mai multa lumina (raportul ariilor celor 2 oglinzi) Mr. Green
@Khristiansen: sper sa nu deschid o polemica refractor vs reflector, dar in majoritatea cazurilor, nu intotdeanua (depinde de calitatea suprafetelor, tratamente antireflex, sortul de sticla al lentilelor, etc...) o oglinda cu diametru de 10" va reflecta mai multa lumina decat va refracta o lentila cu diametru de 10" ... acuma nu contesc ca la un reflector mai exista obstructia centrala datorata oglinzii secundare, si pierderile datorate acesteia... sunt altii mai batrani p'aci care stiu mai bine chestiile astea...
Khristiansen
MesajTrimis: 04 Iun 2013 14:35 Download mesaj
StarChild a scris:
StarChild, nu contest acest lucru. Evident ca in termeni absoluti vom avea mai multi fotoni dintr-o oglinda de 10" decat dintr-un binoclu cu lentile de 10 cm.
Eu ma refeream ca privind cu ambii ochi vezi mai mult si mai bine decat cu un singur ochi. Asta era tot.
theogon
Membru de onoare
Membru de onoare
Data inscrierii: 20 Mar 2009
Localitate: cluj
MesajTrimis: 04 Iun 2013 15:29 Download mesaj
Sub raportul ariilor un binoclu de 100X25 este echivalent cu un instrument (cu același grosisment) de apertură 14,1 cm (10 cm x 1,41 - radical din 2)
Un substitut al filtrului căutat ar fi intensificatorul de imagine. Prețul, după cum îi spune și numele, este intensificat binișor și trece de 2000 $, fiind comercializat după știința mea doar în US.
mihai
tsa
Localitate: Cluj
MesajTrimis: 04 Iun 2013 15:42 Download mesaj
theogon a scris:
Deci exista ceva si pentru galaxii. Daca nu e filtru, pe ce principiu functioneaza acest intensificator de imagine?
Multumesc.
theogon
Membru de onoare
Membru de onoare
Localitate: cluj
MesajTrimis: 04 Iun 2013 16:31 Download mesaj
Subiectul a mai fost discutat pe forum. Vezi aici www.astronomy.ro/forum/viewtopic.php?p=26239
mihai
tsa
Localitate: Cluj
MesajTrimis: 04 Iun 2013 17:08 Download mesaj
Da, interesant. Deocamdata e scump, dar poate firmele de specialitate o sa reuseasca in viitor sa produca la un pret mai accesibil.
Creaza un subiect nou   Raspunde la subiect   Observatii astronomice - incepatori Du-te la pagina Anterioara  1, 2
Pagina 2 din 2
