Numar total de mesaje in forum: 241874
2014 SGAC Find an Asteroid Search Campaign
MesajTrimis: 11 Iun 2014 11:21 Download mesaj
vstoica - Stoica George Valentin.
MesajTrimis: 12 Iun 2014 13:50 Download mesaj
Abandoman constructia? Nici n-a inceput Smile
MesajTrimis: 12 Iun 2014 14:19 Download mesaj
pai trebuie sa se mai inscrie cel putin un individ.
eu astept.
iqarmy
Data inscrierii: 25 Apr 2014
MesajTrimis: 12 Iun 2014 15:52 Download mesaj
User: iqarmy
Smile.
Skywatcher - 10" F/4 newtoinan reflector, 9x50 right angle finder
Canon 450Da, Nikon d3100
Procyon
Data inscrierii: 25 Ian 2013
Localitate: Galati
MesajTrimis: 12 Iun 2014 16:51 Download mesaj
Username: procyonro
Name: Stoian Andrei-Marian.
MesajTrimis: 12 Iun 2014 22:12 Download mesaj
OK, am trimis aplicatia, asteptam rezultatele.
MesajTrimis: 12 Iun 2014 22:15 Download mesaj
Multumim Smile
MesajTrimis: 09 Iul 2014 10:05 Download mesaj
Titlul subiectului: suntem rezerve
"Thank you for applying to SGAC's 2014 Find An Asteroid Search Campaign.
We had over 110 applications and selecting the teams was not easy.
This email is to inform you that you made it to the backup list.
That means if people from the selected teams drop out for whatever reason before or during the campaign (as has happened last year), you might still get a chance to join a group and participate in the search.
I will keep you informed about any possibilities for you."
ovidiuv
Data inscrierii: 30 Mai 2013
Localitate: Santa Cruz de La Palma
MesajTrimis: 09 Iul 2014 10:35 Download mesaj
Cate campuri PS1 (cate CCDs si cate grade patrate) se aloca fiecarei echipe din asta?
E vorba de imagini Pan-STARRS 1 (PS1 - primul telescop 1.8m din cele 4 proiectate), da? Ca idee, nu cred ca PS are nevoie de amatori ca sa descopere NEOs, ci doar de si mai multa vizibilitate, ei fiind deja nr. 1 in lume cu doar 15% fosta alocare (pana in martie) pentru NEA survey, proportie care a crescut din martie la 100% thankis to noile fonduri NASA/Obama pt NEO surveys pana pe la 150m diam, accesibili unui 2m).
Insa si ei cunosc foarte bine ca un om poate detecta mai multi/foarte putin vizibili NEAs (pe un volum mic de date) decat o masina/computerele, pana pe la S/N~1.5 fata de masina PS care merge doar pana la S/N~5 (parca), deci este foarte probabil ca in fiecare camp sa se mai descopere cate un NEA cu amatorii/studentii, prin aceasta initiativa pompoasa sub marca ONU..
Deci PS1 si in curand si PS2 vor detine suprematia pe multi ani de aici inainte (min vreo 10 cred, pana va apare LSST-ul 8m), dupa ce vreme de doua decenii tot americanii au fost singurii care au pus osul la treaba cu cele 5 surveys care-au descoperit cca 98% din toti cei ~10.000 de NEAs accesibili cu telescoape din clasa 1m. In vreme ce europenii raman zero taiat in patru la capitolul NEO surveys! Sad
EURONEAR nu-si propune surveys ci doar follow-up si recovery de importanti si mai slabi V>22 NEAs (pe care surveyurile nu le pot face) in limita extrem de putinului timp primit de la time allocation committees pe INT (din care pana acum doar cel spaniol s-a dovedit ceva mai prietenos, in vreme ce cele englez si oladez mereu mi-au respins proposalurile), si cu un telescop vechi de 5 decenii si-o camera lenta de peste doua decenii... Deci aceasta descoperire 2014LU14 am facut-o intamplator, dar desigur ne bucuram foarte mult pentru ea! (iata c-am reusit sa divaghez subiectul! Smile
In fine, va rog sa ne tineti la curent cu proiectul asta de search in arhivele PS1, as fi foarte curios cam care-i statistica om versus computer (descoperiri NEAs) per square degree PS1!
Ovidiu
MesajTrimis: 09 Iul 2014 12:11 Download mesaj
Asta ma interesa si pe mine, cum arata campurile PS1. Pe cele de la CSS (Schmidt 0.68m) cu camp deocamdata de 8.2 grade patrate (va creste in curand) le-am vazut, sunt luate la 2.5 arcsec/pixel cu mag. limita 19.7 si foarte greu de identificat vizual asteroizi pe el - se pot vedea pe asteroidzoo.org .
Pipeline-ul lor functioneaza cred excelent fiind greu de batut de oameni (sextractor cu limita de detectie foarte jos + con4 (soft de detectie a miscarii liniare) + identificare surse cunoscute/astrometrie + inspectare manuala de operator a celor mai interesanti). Vor sa scape de ultimul pas prin scrierea unui algoritm AsteroidRejector (challenge pe topcoder) deoarece deocamdata outputul unui telescop se poate verifica de un operator dar in curand acest output se va mari cu un factor de 2-4.
Deci CSS isi va mari in curand mult productivitatea, au acum 3 telescoape (0.68, 1.5, 1m) fata de doar 1.8m PS-1, mai au si in plan 3 telescoape de 1m in Chile (CLASS: the Catalina LCOGT Asteroid Southern Survey), este interesant de vazut daca vor reusi sa se mentina la nivelul lui PS-1.
Competitia asta ii cam face pe amatori inutili.
ovidiuv
MesajTrimis: 19 Oct 2014 10:27 Download mesaj
Pacat ca nu ati castigat (dreptul sa munciti pe gratis Smile si nu inteleg ce atata scremere (scuzati expresia) din partea proiectului asta sa imparta mai multe astfel de campuri!?
Eu sunt convins ca amatorii pot descoperi obiecte la S/N mai mic si in cazuri mai dificile decat toate MOPS-urile din lume, inclusiv cel al Pan STARRS asta. Si de la Amy Mainzer (WISE si NEO-WISE) stiu ca ce trece de S/N<5 incepe sa devina bataie de cap pt softuri (si mai ales oameni care sa valideze detectiile). Si din experienta mea (cu IRAF/daofind, pe stele din campuri de galaxii, e drept pe imags unice si nu serii de cate 4-5 ca la surveys), nu prea puteam cobora detectia automata sub 4! Pe cand din experienta noastra cu amatorii, am ajuns uneori sa detectam surse si la S/N=2 ba chiar mai jos (dupa track and stack sau alte metode). Deci eu cred ca inca mai este loc pentru amatori, problema principala fiind VOLUMUL crescand datelor/imaginilor.
Vom vedea daca Catalina va merge inainte cu proiectele lor, nu stiam ca vor sa-si mai faca alte telescoape! Interesant de remarcat cum doua proiecte americane (Pan-STARRS 1 a fost pt 3 ani majoritar american desi si englezii si altii au avut ceva contributii, iar din martie 2014 cred ca-i doar american finantat de NASA pt NEAs) continua sa faca survey de NEAs (plus alte descoperiri importante, cum ar fi main belt comets sau activated asteroids, comete, si alte corpuri din Sistemul SOlar), pe cand euriopenii (ex time allocation committees care analizeaza mici observing proposals de-ale mele, sau boardul INT care-a analizat prin 2010 un proposal de timp ceva mai mare ~50n/an pe INT) considera ca "ce sens are sa mai descoperim noi asteroizi, cand americanii o fac atat de bine"?! Pe mine cioncepttile astea infantile europene ma CALCA RAU DE TOT PE NERVI spre disperarea eforturilor mele cu EURONEAR..
Pana una-alta eu astept cu interes dupa 29 Oct (si mai mult in 3+4 Nov) urmatoarele sanse sa recuperam cativa one-opposition NEAs cunoscuti si eventual sa mai descoperim vreun NEA! Desi am mai acceptat 5 oameni noi in acest proiect INT (incl 2 studenti noi ING foarte de curand) oferta mea ramane oricand deschisa pentru alti amatori din Romania sa se alature proiectelor noastre EURONEAR (INT dar si altele, dezvoltare de soft, etc - voi scrie in curand o lista cu proiecte posbile)...
Ovidiu
Creaza un subiect nou   Raspunde la subiect   Comete, Asteroizi, Meteoriti si Meteori Du-te la pagina Anterioara  1, 2
Pagina 2 din 2
