Numar total de mesaje in forum: 241988
Sequence Generator Pro
Soft pentru astronomie
iosif
Data inscrierii: 17 Oct 2012
Localitate: Sandra Timis
MesajTrimis: 15 Ian 2017 17:27 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.8
Released: 01/15/2017
Release Notes
- Removed "Offset2" telescope sync option, but kept the logic for it and assigned it to the "Offset" selection. The behavior that was used with "Offset" has been removed. If you have sequences or profiles that were using "Offset2", "Offset" should automatically be selected for you. We realize that there are still known issues with this method (should work for most), but releasing this way is still preferable to a pretty nasty bug in 2.5.1.17.
- Updated help file to include descriptions of mount sync behavior options.
- Added web-based location lookup services to MFW for DSO-Browser
- Fixed DSO-Browser location lookup services for HTTPS
- Fixed a bug where SGPro would erroneously indicate that some mounts are not capable of meridian flip (when they actually are).
- Disabled vertical resizing of sequencer window until we can figure out why it does not work properly with Windows scaling.
Download:
http://mainsequencesoftware.com/Releases/DownloadFile?id=8162
_______________________________________________________
iosif
MesajTrimis: 23 Ian 2017 22:26 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.10
Released: 01/23/2017
Release Notes
- Restored original "Offset" behavior that some users had working. If you are using / testing this feature, you should make sure that the proper value is set in your sequences and profiles! The back and forth will probably have the wrong option selected. Further, to help distinguish the methods, the sync behavior that was "Offset" is now "Target Offset" and the seemingly broken sync behavior that was "Offset2" is now "Scope Offset". No need to tell us this is silly... we are fully aware of this and once we have time to troubleshoot why "Scope Offset" is busted we will probably collapse them again. Summary: ("Offset" = "Target Offset"; "Offset2" = "Scope Offset").
- Fully removed the Sequencing Window vertical sizing feature until we can figure out why scaled Windows UIs sometimes clip the right side.
- Fully reverted the Canon SDK until we can figure out why the newest SDK does not appear to be backward compatible with our code.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8164
_________________________________________________________
iosif
MesajTrimis: 01 Feb 2017 13:55 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.11
Released: 02/01/2017
Release Notes
- Reimplemented vertical sizing for the sequencer window (it probably still has a few small issues). Attempting to revert it still showed the same issues so we figured why not have the sizing feature? Please let us know if you spot sizing weirdness and try to note the steps you took to produce it. Thx!
- Added pier side (%ps) to the file naming tokens (as sop-east or sop-west).
- Implemented minimum star size in equipment profiles.
- Added sequence level notifications when SGPro fails to start a sequence due to guider startup failure.
- API Change: Removed IsoMode from the Image Capture API
- API Change: Canon will now use whatever ISO is set on the camera if 0, Null or Empty string is passed in for ISO on the Image Capture API.
- Explicitly disabled DTR for Alnitak (don't believe this is actually needed, but worth a shot).
- Added code to validate that a log is actually created.
- Fixed a bug that would not allow decrementing the captured frame count when marking the last image taken as bad.
- Fixed a bug that would not mark the sequence as needing save when changing the auto guider.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8165
_____________________________________________________________
iosif
MesajTrimis: 15 Feb 2017 14:18 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.12
Released: 02/15/2017
Release Notes
- Implemented "gain" settings for ASCOM cameras. Important note: If your camera supports gain via the ASCOM interface, it must be set for each binning mode or the first gain entry in the list will be used for all images (probably not desired). It should also be noted that, in terms of profiles and sequences, SGPro cannot know your camera's gain options until the camera is selected. If SGPro needs a connection to interrogate the camera's gain options, the dropdown lists will read "Link camera".
- Fixed a bug that would cause an error when some sequences were loaded ('Value' is out of range).
- Fixed a bug that would cause HFR values not to recalculate for new images within the same window.
- Made changes to address several compatibility issues in order to ensure a focuser is positively done moving before SGPro continues.
- Reduced the position and temperature polling frequency for ASCOM focusers.
- Added GAIN and EGAIN (Electrons per ADU) to FITS headers for ASCOM cameras.
- Logs now have sub-second precision for better correlation with ASCOM device logs.
- Removed 60 second timeout for backlash compensation to fix an issue with long running focuser moves.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8166
iosif
MesajTrimis: 20 Feb 2017 17:49 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.6.0.13
Released: 02/20/2017
Release Notes
- Icon / image refresh and theming.
- Added an Observatory floating control module.
- Added a Flat Box floating control module.
- Image history detail now places most recent images at the top of the list.
- Added account management links to the help menu and registration dialog.
- Added vertical sizing to the sequencing window. It's not smart... it doesn't attempt to auto adjust, it does not remember how it was set, but it does allow you to resize the event table for better visibility.
- Connecting to the camera no longer flags the sequence as needing to be saved.
- Added the user profile name to the sequencer title bar (after the equipment profile).
- When the call to set the override filter fails, but the user has requested to use one, SGPro will automatically try and find the LUM filter in order to continue with the sequence.
- Implemented foundation for smart dither decision engine.
- SGPro no longer performs a dither on the first frame (will still settle though).
- Users will now be prompted to unpark or start tracking if, upon sequence start, the mount is not in a valid state for imaging.
- When attempting to start a sequence with the TEC temperature out of band, the warning dialog will now display the TEC's current temperature and state (Idle, cooling, warming).
- SGPro will now detect if a sync is required and automatically perform a solve and sync at the beginning of a sequence (one time).
- Added a warning notification to let the user know if the camera was unable to attain the target temperature prior to starting the sequence.
- The "delay sequence on camera temperature" dialog now contains a better description of what the "Delay Start" option actually does.
- Added target import functionality for DSO-Browser (including an early version of suggested target start and end times based on visibility information provided by DSO-Browser).
- Better user facing error messaging for target centering and many slew related errors.
- SGPro targets now remember any reference URL used to populate its location parameters.
- SGPro now remembers your event suffixes and automatically populates the suffix drop down. There is no interface to create suffixes. If the suffix list becomes too long, you can clear it by using the new "clear" functionality in the SGPro options dialog.
- Rounded camera temperature to a whole number for insertion into file names.
- The target centering routine will now skip the "pre-slew" solve and sync step. While this will make centering faster and compatible with a wider range of mounts, it will also place more onus on the user to ensure that the mount is properly synced prior to starting a sequence.
- The meridian flip routine will now skip the "pre-flip" solve and sync step.
- The Auto Focus validation frame warning will now present itself if the HFR is greater than 15% above the low HFR value in the run (up from 10%).
- Rounded HFR metrics prior to the AF validation "out of tolerance check" (prevents erroneous warning about AF out of tolerance in some cases).
- Implemented the auto focus minimum star size property in equipment profiles.
- Added PlateSolve2 search region increments 1000 through 3000 (was previously capped at 999).
- Added a warning to notify the user if the sequence uses a plate solver and the image scale is 0.
- Added support for fetching the MFW canvas location from DSO-Browser http://dso-browser.com/.
- The Mosaic and Framing Wizard can now populate the canvas location using the mount's location (new menu option at top... Other->Fetch location from mount...).
- SGPro now remembers the last MFW FoV used to fetch the working canvas.
- The MFW is now more tolerant of corrupt cache files.
- Added some watchdog timers for certain aspects of SBIG camera operation (to better detect timeout).
- ASCOM and QSI cameras now attempt to identify when a camera is downloading an image to support pause guider during download.
- Implemented "gain" settings for ASCOM cameras. Important note: If your camera supports gain via the ASCOM interface, it must be set for each binning mode or the first gain entry in the list will be used for all images (probably not desired). It should also be noted that, in terms of profiles and sequences, SGPro cannot know your camera's gain options until the camera is selected. If SGPro needs a connection to interrogate the camera's gain options, the drop-down lists will read "Link camera".
- Refactoring "Reverse Focuser" logic. Everything now resides in two places: the "Move" and the "GetCurrentPosition". Focuser position should almost never be called outside of these two places. This refactor effectively masks the real focuser position when Reversed. For instance if the focuser has 10,000 steps and is currently at position 2000 then when reversed SGP will report 8000 steps. Backlash compensation is in terms of "SGP Reported" steps not the actual steps of the focuser. So "IN" will always trigger backlash when the focuser moves from Low to High in SGP Reported Steps not Focuser Reported Steps. The main benefit of this is to have Auto Focus and backlash both work transparently when reversed. More info here: http://forum.mainsequencesoftware.com/t/ri...us/4544/10
- Added the concept of "Sync Behavior" to the telescope (mount). The "Sync" and "None" options are fully supported. For information on the others, please see "Known Issues" below.
- Added the "GainValues" array to the /cameraprops endpoint in order to provide a list of allowable "Gain" values for the /image endpoint.
- Added logging for API requests (must turn this on via the help menu).
- Added API calls to enumerate, connect and disconnect devices to the public API.
- Added flip delay API calls http://forum.mainsequencesoftware.com/t/2-...em/4651/9.
- The plate solve API now honors the plate solver's chosen search method (in the control panel).
- Removed IsoMode from the Image Capture API.
- Canon will now use whatever ISO is set on the camera if 0, Null or Empty string is passed in for ISO on the Image Capture API.
- SGPro now attempts to detect external device disconnections (and provide a notification to fix it).
- For users that experience an issue with SGPro not starting, we are now providing a much better recovery for SGPro when its settings file becomes corrupted (cmd: "sequence generator.exe " /recover). With this method you are even far less likely to lose old settings.
- Image history now supports a fast star finding algorithm. You don't need to worry about this setting unless you are using an older (or slower) laptop with very large frames. This method essentially uses the older, but much faster star analysis routines. It can be found in the SGPro options dialog under "Find stars method". This is a beta feature and is not yet documented. Changing it does not affect the routine for auto focus.
- Better user feedback for mount park failures (more specific errors logged in the sequence alerts dialog box).
- SGPro will now show an error if the user attempts to rotate to a target position and the rotator does not have a sync.
- Added a warning dialog if the user attempts to open a new sequence while the camera is cooling or warming.
- Independent movement of the observatory shutter / roof or rotation now provides a warning if it is slaved to the telescope.
- Fixed an issue where centering (and meridian flips) might hang SGPro and report that the camera has timed out.
- Fixed an issue where some users could see erratic behavior with frame restarts when the telescope is on the east side of the pier.
- Fixed a bug where the auto centering validation step could fail on camera rotation if the primary solver failed.
- Fixed an issue where SGPro could attempt to take an image without having sufficient time to finish before meridian flip.
- Fixed a bug that would cause SGPro to crash when a Nikon bulb exposure failed.
- Fixed a bug that would cause SGPro to crash if a file in the image history was renamed outside of SGPro.
- Fixed a bug that could cause rotator movement to never finish if the requested angle (not PA) was 0.
- Fixed a bug where end of sequence options might run twice when shutting down due to unsafe conditions.
- Fixed a bug that could cause an error in SBIG cameras if the driver was "opened" multiple times.
- Fixed a bug that, for certain types of flat boxes, the flat box light would not turn off properly when the sequence was done with flat frames.
- Fixed a bug that would prevent end of sequence options from running when conditions are unsafe.
- Converting X,Y pixel locations to RA,DEC no longer allows values greater than 24 hrs (to be populated in the target's location).
- Fixed a bug where API camera status no longer worked properly (affected PEMPro integration).
- Fixed an issue where the image capture API would not allow for high speed download (on supported cameras).
- Fixed an issue where images would always be analyzed for HFR, regardless of Image History status (on or off).
- Fixed a bug where end of sequence scripts would disappear from the UI after being set.
- Fixed an issue where some FLI filter wheels would refuse to respond to commands despite being connected.
- Fixed a bug where the guider could sometimes fail to settle even though the error is well below the requested value.
- Fixed a bug that could allow an end of sequence script to run between normal sequence end and the beginning of calibration-only frame capture.
- Fixed a bug where DSLR ISO settings did not work properly when using the SGPro REST API.
- Fixed a bug where aborting during target wait might force end of sequence options to execute.
- Fixed a bug that would automatically turn ASCOM focuser temp compensation off when it connects.
- Fixed a bug, that in rare circumstances, might "roll" the number of captured events from 9 back to 1. No loss of data occurs, but event frames would be recaptured.
- SGPro now properly handles the PHD2 message indicating failure to settle.
- Fixed a bug where FLI cameras would immediately disconnect after connecting.
- Fixed a bug that might not allow some focusers to accept temperature override from the environment device.
- Fixed a bug that would cause SGPro to crash if the Image History dialog was invoked while already visible.
- Fixed a bug where navigating image history would fail to update the HFR and star count metrics in the image stats module.
- Fixed a bug where a sequence failure due to lost guide star would not allow for end-sequence capture of calibration frames.
- Fixed a bug where several popup windows attached to the sequencing window would not close properly when the sequencer closed.
- The "Sync Behavior" option found in the Control Panel's Telescope tab will eventually provide a means to allow for users to perform closed loop targeting operations without a need to sync the mount's position to a location provided by the plate solver. This is useful only if performing a direct mount sync via SGPro is likely to fail or create other issues by inadvertently fight with a model maintained by the mount's driver. The "known issue" in the SGPro 2.6 release is specific to the selections that are intended to perform said "syncless centering". For now, the only Sync Behaviors that are supported are "Sync" and "None". The "Target Offset" and "Scope Offset" options are available for use, but remain in a "not quite working" beta state.
- The addition of a vertically re-sizable sequencer window might have created some odd rendering issues in which the events and other controls no longer fit the bounds of the window. We have not been able to recreate these issues, but if you see it, please try to note your steps and let us know what value you have Windows Scaling set to (no logs necessary).
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8167
iosif
MesajTrimis: 01 Mar 2017 18:34 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.6.0.16
Sequence Generator Pro v2.6.0.16 Released: 03/01/2017
O scurta descriere a programului SGPro.
Programul are perioada de incercare 45 de zile. Are foarte multe functii pentru achizitie imagini cu camere DSLR, CCD. Se poate importa tinte pentru fotografie din DSO Browser, Astrobin, cat si din planere pentru observatii de ex. AstroPlanner, Deep-Sky Planner, Starry Nights, DSO-Browser List. AstroPlaner are integrat un link integrat in program catre 7Timer Chart care da cu acuratete buna acoperirea cu nori a locului de observatii. Am pus si o poza cu programul in discutie. Sequence Generator Pro are integrat un program pentru achzitie de mozaicuri, nu l-am testat, dar vara asta o sa-l incerc. Va doresc cer senin si sa facem poze astro cat mai bune, cu stima Iosif.
Release Notes.
- Addressing ocx registration
- Fixing broken default profile
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8170
 Marime fisier:  331.16 kb
 Vizualizat:  de 17518 ori
 Marime fisier:  396.68 kb
iosif
MesajTrimis: 03 Mar 2017 15:50 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.6.0.17
Sequence Generator Pro v2.6.0.17 Released: 03/03/2017
Release Notes
- Fixing large address issue.
- Fixed a bug where SGPro might indicate a plate solver is required when it's not.
- Fixing focuser not waiting when backlash is enabled.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8171
iosif
MesajTrimis: 11 Mar 2017 01:54 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.18
Sequence Generator Pro Beta v2.6.0.18 Released: 03/10/2017
Release Notes
- Reintroduced the initial solve process to the front of the auto-meridian flip routine (notice there is no attempt to sync here) to get a proper post-flip reference. This should address a problem that could cause subsequent centering routines to be "off"
- Fixed a bug that, in some cases, could cause the "Pause Sequence" button to become permanently disabled.
- Another random attempt at trying to correct the odd sequencer window scaling issues. This attempt completely disables the vertical sizing feature just to see if it makes any noticeable difference in how the problem presents itself. Just looking for clues at this point...
- Added Nikon NEF files to the supported image "drag & drop" list.
- Additional logging to get more details on random DSO-Browser list import failures.
- Additional logging for MFW canvas fetch that might fail (maybe due to regional formatting changes... not sure)
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8172
iosif
MesajTrimis: 14 Mar 2017 23:11 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.20
Sequence Generator Pro Beta v2.6.0.20 Released: 03/14/2017
Release Notes
- More changes to help address issues that render the sequencer window controls as "too large" for the containing window.
- Restored the sequencer window vertical sizing feature.
- Increased the DSO Browser list import call timeout to 60 seconds (up from 15).
- Fixed a bug where the error message for auto observatory slaving was in the title bar.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8173
iosif
MesajTrimis: 25 Mar 2017 16:59 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.21
Sequence Generator Pro Beta v2.6.0.21 Released: 03/25/2017
Release Notes
- Implemented "Disconnect all equipment at sequence end" option (found in sequence settings)
- Increased DSO-Browser timeout to 120 seconds.
- Added import status for DSO-Browser to let you know if SGPro is waiting on DSO-Browser to respond.
- Fixed a bug that, when using cut and paste for target location from Stellarium, it would match "Apparent Sidereal Time" as RA and "Size" as Dec.
- Fixed a bug that could indicate an observatory is required even if the "Slave to Telescope" checkbox is not checked.
- Fixed a bug that wrote the SET-TEMP FITS header as the current temperature of the TEC (instead of the TEC target temp).
- Fixed a bug that would allow the filter list to contain user filters with no names (and provide bad exposure length info while running AF).
- Fixed a bug that would allow for selection of an AF override filter and then allow "None" to be selected as the filter.
- Provision to allow users to toggle ASCOM focuser temp comp via the SGPro API (in most cases this should be slightly easier to use than the ASCOM scripting since SGPro manages errors and connections for you). Endpoint: /focuser/tempcomp, see API docs for more details.
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8174
iosif
MesajTrimis: 15 Mai 2017 10:27 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.6.0.22
Sequence Generator Pro v2.6.0.22 Released: 05/13/2017
Release Notes
- Change: SGPro now supports controlling ASCOM camera gain by binning (your driver must support this). If it is not set, SGPro will defer control of it to the ASCOM driver itself.
- Change: Clicking the Auto Focus "Run" button while a sequence is running will now force AF to run before the next frame starts integration.
- Change: Added a sequence level option to disconnect all gear on sequence end.
- Change: Increased the DSO Browser list import call timeout to 60 seconds (up from 15).
- Change: Reintroduced the initial solve process to the front of the auto-meridian flip routine (notice there is no attempt to sync here) to get a proper post-flip reference. This should address a problem that could cause subsequent centering routines to be "off".
- Change: Added Nikon NEF files to the supported image "drag & drop" list.
- Change: Additional logging for MFW canvas fetch that might fail (maybe due to regional formatting changes... not sure)
- Change: PHD2 settle timeout has been increased to 10 minutes.
- Change: Added GAIN and EGAIN (Electrons per ADU) to FITS headers for ASCOM cameras.
- Change: Logs now have sub-second precision for better correlation with ASCOM device logs.
- Change: Removed 60 second timeout for backlash compensation. Should fix long running focuser moves.
- Change: Provision to allow users to toggle ASCOM focuser temp comp via scripts (in most cases this should be slightly easier to use than the ASCOM scripting... since SGPro manages errors and connections for you).
- Change: Added the SGPro profile name to the FITS headers.
- Change: Parking the telescope no longer waits for the auto guider to report it is stopped.
- Change: More resilient exposure abort for ASCOM cameras.
- Change: Refactored PlateSolve logging to improve user troubleshooting.
- Change: Recovery mode now checks for target end time while it is waiting to start the next attempt.
- Change: Converting FLI pixel size to um prior to entry as a FITS header (from meters)
- Bug: Fixed a bug that would cause a sequence to stop without a clear reason when a sequence was asked to auto center with filter "None".
- Bug: Fixed a bug where the error message for auto observatory slaving was in the title bar.
- Bug: Fixed a bug that, in some cases, could cause the "Pause Sequence" button to become permanently disabled.
- Bug: Fixed a bug that would cause HFR values not to recalculate for new images within the same window.
- Bug: Fixed a bug that would cause an error when importing targets with start / end times using the year 0001.
- Bug: Fixed copy / paste bug that, for Stellarium, would match "Apparent Sidereal Time" as RA and "Size" as Dec.
- Bug: Fixed a bug that could indicate an observatory is required even if the "Slave to Telescope" checkbox is not checked.
- Bug: Fixed a bug that set the SET-TEMP FITS header to the current temperature of the TEC.
- Bug: Fixed a bug that would allow the filter list to contain user filters with no names (and provide bad exposure length info while running AF).
- Bug: Fixed a bug that would allow for selection of an AF override filter and then allow "None" to be selected as the filter.
- Bug: Fixed a bug where SGPro's internal temp comp was broken if using an external device to read ambient temperature.
- Bug: Fixed a bug that required the "Salve dome" option to be checked in order to auto connect.
- Bug: Better checking for illegal characters in the file naming pattern.
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8175
_______________________________________________________________________
 Marime fisier:  330.17 kb
 Vizualizat:  de 17136 ori
iosif
MesajTrimis: 31 Mai 2017 00:13 Download mesaj
Titlul subiectului: Focus cu SGPro
Buna.
Autofocus SGPro, cu controler si motor Seletek.
 Marime fisier:  689.24 kb
 Vizualizat:  de 17024 ori
iosif
MesajTrimis: 25 Iun 2017 23:21 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.24
Released: 06/24/2017
- Implemented "per-event" gain control for ASCOM cameras.
- A sequence can now import targets from other SGPro sequences.
- Initial implementation of Gemini SnapCap FlatBox device.
- Restored old TEC cooling code that was, by chance, allowing the QHY driver to work properly (the real fix for this must come from QHY as the rate of reading temperature should be independent of the rate at which the TEC cools).
- Any park command issued through SGPro will now be followed by a stop tracking command.
- Fixed a bug where SGPro's internal temp comp was broken if using an external device to read ambient temperature.
- Updated CTYPEn FITS headers to report projection as gnomonic (instead of default).
- SGPro will now more accurately detect the need to auto connect with a flats box.
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8177
iosif
MesajTrimis: 22 Sep 2017 20:38 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v3.0.0.0
Released: 09/21/2017
- Beta implementation of the SGPro "Planning Assistant" (more here: http://forum.mainsequencesoftware.com/t/pl...idate/5941). There are likely issues where the graph feature does not work properly for all latitudes (needs testing for southern latitudes).
- SBIG RBI Implementation
- User profile selection now contains an option to open the user profile manager (shortcut). Known issue: selecting this option will deselect the user profile so that you will need to select it again after closing the user profile manager.
- SGPro addons (MFW and Notification Wizard) are no longer licensed individually (they are part of the main SGPro license now)
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8178
 Marime fisier:  165.1 kb
 Vizualizat:  de 16563 ori
iosif
MesajTrimis: 27 Sep 2017 14:42 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v3.0.0.1
Sequence Generator Pro Beta v3.0.0.1 Released: 09/26/2017
Release Notes
- Fixed an issue where the SGPro installer might be flagged as malware (it never was though).
- Various bugs fixed for the target planning tool graph.
- Fixed bug where opening a target with no user profile would throw an exception.
- Fixed a bug that could prevent end of sequence options on guider failure.
Download.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8179
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina Anterioara  1, 2, 3  Urmatoare
Pagina 2 din 3
