Numar total de mesaje in forum: 243500 |
Cel mai nou utilizator inregistrat: RaduMarinescu |
Trimis: 20 Dec 2015 00:08 Download mesaj |
In articolul cu structura hexagonala (ce este mai mult un experiment "proof of concept") nu se pomeneste de recoacere, ci doar o racire controlata de la 1050 la 90°F ( adica de la 565 °C la 32 °C) pe timp de 3 zile. Chiar si asa raman problemele descrise mai jos:
The two strange artifacts in the focogram are air bubbles just under the surface of the glass that broke through during grinding and polishing. This blank has a lot of air bubbles in it. I ground into a lot of them while grinding and polishing the mirror, probably making the finished mirror unusable.
Then there have been numerous problems encountered while figuring. I have fought a persistent turned down edge, holes in the center, peaks in the center, uncooperative zones, and a general refusal of the mirror to respond properly to normal figuring strokes on a full-size lap the same way a solid mirror does.
Trag concluzia ca nu-i chiar asa de simplu ... |
2SKY Membru
Stanescu Octavian Membru
Data inscrierii: 02 Apr 2006 Mesaje: 3779
Trimis: 20 Dec 2015 13:32 Download mesaj |
Probabil trebuie foarte bine amestecat lichidul cu sticla topita iar cuptorul sa ajunga la 1600gr in site de la firma producatoare de cuptoare ce a dat cineva am vazut ca sunt cam mici tem max 1300 .
apoi matrita trebuie facuta cu mare precizie probabil la zecime mm ca nervurile din structura sa aibe aceiasi grosime altfel se trage rezultand forma locala ridicata lasata . totul sa fie centrat si simetric. |
