› Numar total de mesaje in forum: 243362
Plannere de astronomie
Soft pentru astronomie
Ovidiu M.
Data inscrierii: 16 Sep 2007
Localitate: Buzau
MesajTrimis: 09 Dec 2015 03:01 Download mesaj
Ok, thanks.
Binoclu:Pentax XCF 10x50
Ovidiu M.
Localitate: Buzau
MesajTrimis: 09 Dec 2015 16:09 Download mesaj
M am jucat un pic si are si functia asta de stabilire a unuei separari minime la stelele duble. De fapt are toate criteriile posibile si imposibile si un night mod foarte bun. Cred ca o sa mi iau si eu varianta pro.
Emil
Data inscrierii: 30 Aug 2007
Localitate: Fuerstenfeld
MesajTrimis: 09 Dec 2015 16:24 Download mesaj
Atentie pentru versiunea pro
Before installation please make sure that you have at least 2 GB of free space on your internal SD card to download application databases! (Note: due to Google Play rules this data cannot be moved to your external SD card - you must have 2 GB free on your internal SD card!)
Ovidiu M.
Localitate: Buzau
MesajTrimis: 09 Dec 2015 16:30 Download mesaj
Mersi pt atentionare. Am vazut. Acum am 1,5 Gb liberi. Daca nu fac loc iau varianta Plus. Acelasi lucru numai ca sunt bazele de date un pic mai mici. In orice caz chiar si asa inepuizabile.
Ovidiu M.
Localitate: Buzau
MesajTrimis: 09 Dec 2015 18:55 Download mesaj
Skysafari 4 Pro a incercat cineva pe android?
Emil
MesajTrimis: 10 Dec 2015 17:18 Download mesaj
SkySafari utilizeaza Hubble Guide Star Catalog cunoscut in mod normal ca GSC 1.1 ACT
"The Hubble Guide Star Catalog – Astrographic Catalog/Tycho (GSC-ACT) is an astronomical catalog. It contains the twenty million stars of the Hubble GSC, version 1.1, recalibrated using the U.S. Naval Observatory's ACT (Astrographic Catalog/Tycho). By 2009 it was considered obsolete, superseded by such catalogues as GSC-2.2, B1.0, A2.0, and especially UCAC-3."
respectiv
"The HST GSC contains nearly 19 million objects brighter than sixteenth magnitude, of which more than 15 million are classified as stars. They are organized into 9537 regions on the sky. "
DSO Planner utilizeaza UCAC 4
"The fourth United States Naval Observatory (USNO) CCD Astrograph Catalog, UCAC4 was released in August 2012 (double-sided DVD and CDS data center Vizier catalog I/322). It is the final release in this series and contains over 113 million objects; over 105 million of them with proper motions. UCAC4 is an updated version of UCAC3 with about the same number of stars also covering all-sky."
Am folosit Stelarium si Starry Night 6, le-am abandonat datorita erorilor de pozitionare.
Pe de alta parte Safari costa aproape 50 euroi......
Doar ca idee, nu vreau sa influentez pe nimeni.
Numai bine
Emil
Ovidiu M.
Localitate: Buzau
MesajTrimis: 10 Dec 2015 18:52 Download mesaj
Intre timp am mai studiat si am trecut si eu la dso planner 3. Este exact ce am nevoie. Am ramas siderat cand dand zoom pe harta m am lovit de un zid de galaxii in toate directiile, bimeinteles de magnitutdini f mari. Sunt incantat ca sunt atat de multe stele duble abordabile. Pentru oras este excelent.
Emil
MesajTrimis: 10 Dec 2015 21:41 Download mesaj
Imi pare bine ca ai gasit o solutie optima pentru TINE.
N.B. Sunt in lucru cu traducerea DSO Planner-ului in romana, sper ca la inceputul anului (ianuarie) sa poti comuta in romana.
Numai bine
Emil
Ovidiu M.
Localitate: Buzau
MesajTrimis: 10 Dec 2015 22:05 Download mesaj
Si eu ma gandeam sa-mi ofer ajutorul pentru traducerea in limba romana:) Felicitari pentru initiativa!
Ovidiu M.
Localitate: Buzau
MesajTrimis: 14 Ian 2016 15:11 Download mesaj
DSO planner are acum si baza de date de stele variabile, GCVS cu aproape 48000 de stele. Deocamdata se introduce manual, nu este greu. Pe viitor va fi integrata de devi si disponibila ca update.
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina Anterioara  1, 2, 3
Pagina 3 din 3
