› Numar total de mesaje in forum: 244009
radiotelescop
Radioastronomie
MesajTrimis: 21 Apr 2018 23:53 Download mesaj
Daca-i doar de ascultat, cam asa "suna" (MP3): http://www.radiosky.com/92000bigburst.mp3
Sursa: http://www.radiosky.com/solarburst092000.html
P.S.
Uite si niste explicatii tot de acolo: http://www.radiosky.com/faq.html
What is a radiotelescope?
A radiotelescope is basically a very sensitive radio receiver. Whereas communications receivers are designed to extract information which has been intentionally modulated onto a radio wave, radiotelescope receivers are designed to measure the intensity of the radio wave over some band of frequencies. A radiotelescope is essentially an energy measuring device.
What do radio astronomers listen for?
Actually, radio astronomers very seldom "listen" with their ears to the signals they are receiving. If you do listen to some of the radio telescope output that has been translated to an audio signal you can hear, it sounds just like the static you hear when your television is tuned to a channel where no station is present. It is this broad noise signal that is of interest to radio astronomers who measure it in many ways, but only listen in perhaps to hear what kind of man-made interference is messing up their measurements.
Apropo, Callisto are urmatoarele specificatii:
Dynamic range -120 … -10 dBm
Observation bandwidth 300 KHz @ -3dB
Remus Boldis
Data inscrierii: 03 Iun 2014
Localitate: Buzias
MesajTrimis: 22 Apr 2018 07:35 Download mesaj
Aveti aici acces la un SDR de buna calitate. Antena e de mici dimensiuni si omnidirectionala, dar exploziile solare mari pot fi probabil auzite si vazute pe waterfall. In fereastra de frecventa scrieti 20100. Bifati FM sau AM.
http://websdr.ewi.utwente.nl:8901/
La Waterfall settings puteti alege view spectrum sau waterfall si la Filter puteti largi s-au ingusta banda de receptie. La Advanced puteti pune Gain control pe manual si mari amplificarea. Aveti evident si Volume (pentru audio).
MesajTrimis: 22 Apr 2018 08:35 Download mesaj
Merci, Remus. Sigur că există pe net o mulțime de informație și am avea acces la o mulțime de echipamente complete construite de gata dar plăcerea e să le faci (asamblezi) cu mânuța ta și să înțelegi foarte bine ce rol are fiecare componentă apoi să îmbunătățești sistemul. E diferența dintre observatorul astro-amator și ATM-ist. Acum sunt ca atunci când am cumpărat primul obiectiv de lunetă astronomică și am construit restul în jurul lui. Very Happy
Remus Boldis
Localitate: Buzias
MesajTrimis: 22 Apr 2018 08:40 Download mesaj
Clar placerea construirii nu poate fi inlocuita de nimic.
MesajTrimis: 28 Apr 2018 22:08 Download mesaj
Din cate inteleg, frecventa de 20 MHz e potrivita mai mult pentru a prinde emisiile generate de Jupiter-Io decat a celor solare. Astea merg si ascultate pe radio normal, sub forma de paraituri. Apar si pe RTL-SDR.
Totusi e mai greu cu o antena din aia de 7-8 m ce trebuie urcata la 20m inaltime.
Surse:
https://radiojove.gsfc.nasa.gov/library/newsletters/2013Nov/
https://www.rtl-sdr.com/capturing-noise-bu...n-rtl-sdr/
 Marime fisier:  129.28 kb
 Vizualizat:  de 10185 ori
 Marime fisier:  128.16 kb
MesajTrimis: 29 Apr 2018 10:24 Download mesaj
Profit de ocazie sa pun aceeasi intrebare, de ce ati ales banda de 20Mhz pentru monitorizarea activitatii solare? Din ce imi aduc aminte de pe vremea incercarilor mele in domeniul radiotelescoapelor (sfarsitul anilor '80), emisia soarelui in banda de 20Mhz este foarte slaba.
MesajTrimis: 02 Mai 2018 15:19 Download mesaj
La mine n-a fost vorba de alegere, am primit antena gata făcută și am zis hai să vedem despre ce-i vorba. Smile De altfel Marco Paul a și observat cu ea o erupție anul trecut. Până se reia activitatea serioasă sper să am sistemul gata. A trebuit să amân achiziția Raspberry Pi pentru că am comandat 2 și am primit doar unul pe care l-am dat altcuiva... politica optimusdigital să dea numai unul să ajungă pt toată lumea... Am crezut că-i păcălesc dacă comand modele diferite, unul cu pini lipiți și celălalt fără pini. Very Happy
cristirimer
Data inscrierii: 02 Apr 2008
Motto: Un plus de cunoastere se plateste cu un plus de ignoranta! (Arthur Eddington)
MesajTrimis: 28 Mai 2018 18:53 Download mesaj
In atasament se poate vedea cum arata distributia spectrala a semnalelor radio emise de cele mai intense radiosurse cosmice, accesibile radiotelescoapelor cu antene de dimensiuni relativ mici.
Cu linii orizontale rosii este marcata limita de sensibilitate in cazul radiotelescoapelor cu antene de 1 m, respectiv 10 m diametru. Observatii radioastronomice se pot face si la frecvente mult mai mari, cum ar fi "banda de 12 GHz" folosita in transmisiunile Tv direct prin satelit, folosind pentru aceasta antenele parabolice si unitatile LNB destinate acestui domeniu, adaptand aparatele de masurare a intensitatii campului electromagnetic (cunoscute ca "Sat-finder") sau, pentru sensibilitati mai mari, se poate construi o aparatura dedicata acestui scop. Pentru usurarea "citirii" nivelelor de intensitate (in Jansky - Jy) in acele domenii de frecventa, pe diagrama sunt trasate acele linii verticale verzi.
Se observa ca majoritatea radiosurselor emit cu intensitati mai mari la frecvente joase, iar acestea scad la frecvente inalte. Aceasta este o caracteristica a radiatiei "non-termice", numita datorita mecanismului de generare si "radiatie de tip sincrotron" (sau "radiatie sincrotrona", cum era denumita, incorect, in urma cu multi ani). Radiatia de tip termic, emisa conform legii lui Planck de distributie a energiei corpului negru, are o distributie de forma "clopotului lui Gauss", cu un maxim la frecventa (sau lungimea de unda) determinata de legea deplasarii a lui Wien, functie de temperatura absoluta (in grade Kelvin) a corpului emitator. In domeniul radio distributia acesteia este cu amplitudini crescatoare cu frecventa, asa cum se observa in cazul Soarelui, a Lunii si a planetelor Venus si Marte pe aceasta diagrama. In cazul "eruptiilor radio" emise de Jupiter avem de-a face in mod evident cu o radiatie de tip sincrotron, la care se adauga si componenta radio a descarcarilor electrice din atmosfera deosebit de turbulenta a acestei planete.
Diagrama spectrului radio in cazul catorva radiosurse
 Marime fisier:  196.67 kb
 Vizualizat:  de 9786 ori
Ultima modificare efectuata cristirimer la 29 Mai 2018 10:18, modificat de 2 ori in total
Emil
Data inscrierii: 30 Aug 2007
Localitate: Fuerstenfeld
MesajTrimis: 28 Mai 2018 20:02 Download mesaj
Remus Boldis a scris:
Dupa cate stiu eu este cel mai performat SDR realizat pana acum.
Merci de link
Creaza un subiect nou   Raspunde la subiect   Radioastronomie Du-te la pagina Anterioara  1, 2, 3, 4
Pagina 4 din 4
