› Numar total de mesaje in forum: 243546
PHD ver 2
Soft pentru astronomie
iosif
Data inscrierii: 17 Oct 2012
Localitate: Sandra Timis
MesajTrimis: 29 Sep 2017 13:52 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev1
PHD2 v2.6.4dev1 27 September 2017
- New Static Polar Align tool that uses the center of rotation of a polar field to align on the pole.
Download.
http://openphdguiding.org/phd2-2.6.4dev1-installer.exe
________________________________________________
iosif
MesajTrimis: 05 Oct 2017 16:47 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev2
PHD2 v2.6.4dev2 3 October 2017
- Static Polar Align tool updates.
- Add Static Polar Align and Drift Align tutorials to the Help file.
- High resolution (4K) screen UI layout fixes.
- Updated Traditional Chinese translation.
Download.
http://openphdguiding.org/phd2-2.6.4dev2-installer.exe
_______________________________________________________
iosif
MesajTrimis: 08 Oct 2017 23:50 Download mesaj
Titlul subiectului: PHD2 Development Snapshot Builds
PHD2 v2.6.4dev3
8 October 2017
- Static Polar Alignment tool improvements
- Atik cameras: binning support added
- Server API: new methods for sensor temperature and cooler status
Download.
http://openphdguiding.org/phd2-2.6.4dev3-installer.exe
iosif
MesajTrimis: 21 Oct 2017 00:51 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev4
PHD2 v2.6.4dev4 20 Oct 2017
- Star auto-selection no longer has 40-pixel edge distance restriction
- More explicit labeling of pixels vs arc-seconds units in graph window and stats window
- Remove modal dialog boxes from most camera connect functions
- Updated French translation
- Static Polar Align tool improvements
- Add RA to guide log guide section heading
Download.
http://openphdguiding.org/phd2-2.6.4dev4-installer.exe
iosif
MesajTrimis: 30 Noi 2017 12:38 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev5
PHD2 v2.6.4dev5
30 Nov 2017
- New Polar drift tool - drift alignment using a star field near the pole
- Better detection and handling of changes to mount guide speed and camera binning
- Improvements to New Profile Wizard
- INDI fixes
- Updated French and Traditional Chinese translations
- Updated help file
Download.
http://openphdguiding.org/phd2-2.6.4dev5-installer.exe
__________________________________________________________________
iosif
MesajTrimis: 22 Dec 2017 04:51 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev6
PHD2 v2.6.4dev6
19 December 2017
- ZWO Cameras: update Windows SDK to V1.13.1.9
- SX Camera: fix pixel size value being reported incorrectly when square pixels option is enabled
- Updated German translation
- Dither settling now ignores dec distance when dec guide mode is None
- Show help info in status bar as menu items are highlighted
- Drift align tool: fix problem with alignment circle sometimes following the guide star in Adjust mode when it is supposed to remain stationary
- Fix bug when guiding is initiated at the pole.
Download.
http://openphdguiding.org/phd2-2.6.4dev6-installer.exe
iosif
MesajTrimis: 26 Ian 2018 22:50 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev7
PHD2 v2.6.4dev7 17 January 2018
- Fix bug introuced in 2.6.4dev6 causing a new equipment profile to replace an existing profile
- Updated help file
- Fixed spacing in polar drift align window
- Guiding Assistant: correct for dec drift and show an uncertainty estimate
--- Download ---
https://openphdguiding.org/phd2-2.6.4dev7-installer.exe
iosif
MesajTrimis: 13 Feb 2018 12:12 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev8
PHD2 v2.6.4dev8
12 February 2018
- New tool to upload log files to openphdguiding.org
- Guiding Assistant: improved backlash test
- Altair cameras: updated SDK to version 20_12_2017
- Updated Help
Download.
http://openphdguiding.org/phd2-2.6.4dev8-installer.exe
___________________PHD2 v2.6.4dev8_______________
iosif
MesajTrimis: 02 Mar 2018 14:00 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev9
PHD2 v2.6.4dev9
1 March 2018
- Add some new options for better control of backlash compensation.
- Fix a problem that prevented some cameras from automatically re-connecting after a disconnect.
- ZWO cameras: update SDK versions to V0.7.0118 (Linux/Mac) and V1.13.1.12 (Windows).
- Polar drift tool: re-enable guiding when done.
- Min motion controls allow changing with finer increments.
- Server: fix problem with receiving empty commands from some clients.
- Fix problem with graph sometimes displaying the correction incorrectly when the Predictive PEC guide algorithm is in use.
- Simulator minor improvements for changing settings on the fly.
Download.
http://openphdguiding.org/phd2-2.6.4dev9-installer.exe
iosif
MesajTrimis: 03 Apr 2018 19:23 Download mesaj
Titlul subiectului: PHD2 v2.6.4dev10
PHD2 v2.6.4dev10 31 March 2018
- Improved backlash compensation dynamic adjustment
- Add additional control options for backlash compensation
- Apply backlash comp for "fast recovery" moves after dithering
- Apply backlash comp for AO mount bumps in declination
- Simulator: fix lag in response to manual guide motions during long exposures
- Updated Russian translation
- Updated Russian help file
- Windows: fix problem with log file uploader not seeing the full contents of the current session's logs
- Log file uploader: fix layout of grid for non-English translations
- Polar drift tool: status line fix
- Polar drift tool: restore guiding on close
Download install.
https://openphdguiding.org/phd2-2.6.4dev10-installer.exe
Download manual ver. 2.6.4
https://openphdguiding.org/PHD2_User_Guide.pdf
Download PHD2 Best Practices.
https://openphdguiding.org/PHD2_BestPractices.pdf
iosif
MesajTrimis: 02 Mai 2018 09:31 Download mesaj
Titlul subiectului: PHD2 v2.6.5
PHD2 v2.6.5 30 April 2018
- New Static Polar Align tool and Polar Drift tool
- New tool to upload log files for review (Help > Upload Log Files)
- Improved Backlash compensation with additional controls and improved backlash measurement in the Guiding Assistant
- New Profile Wizard improved detection of properties of connected gear
- Improved handling of camera binning and mount guide speed changes
- Some minor UI tweaks like more explicitly labeling pixels vs arc-seconds units, showing help info in status bar as menu items are highlighted, and layout fixes for high resolution displays
- Remove modal dialog boxes from most camera connections
- Allow star auto-selection to select stars closer to the edge of the frame
- Altair Cameras: update SDK to version 20_12_2017
- Atik Cameras: binning support added
- ZWO Cameras: updated Windows SDK to V1.13.1.9
- Guide log enhancements (additional logging)
- INDI fixes
- Server API additional methods
- Updated translations - French, German, Russian, Traditional Chinese
Download.
https://openphdguiding.org/phd2-2.6.5-installer.exe
iosif
MesajTrimis: 24 Mai 2018 02:24 Download mesaj
Titlul subiectului: PHD2 v2.6.5dev1
PHD2 v2.6.5dev1
- More informative alert messages when runaway guiding is detected and for failed calibrations
- QHY cameras: update Windows SDK to V20180502_0 from QHY
- AO: remove irrelevant guide algo choices
- Fix layout bug in BLC controls
- Minor debug logging improvements
- Lots of INDI improvements
---INDI cameras: automatically de-bayer color cameras
---do not allow overlapping RA and Dec guide pulses (overlaps can trigger a bug in some INDI drivers)
---better logging including a verbose logging option
---display the selected INDI devices in the Connect Equipment window
---only show camera drivers in the camera selection list and mount drivers in the mount selection list
---much better resilience to dropped connections from the INDI server
---cancellable progress window for INDI device connection
---fix INDI GUI excessive window updates by displaying the GUI after properties have been received from the server
- A bunch of help file updates
- Various improved tool-tip messages
- Updated Korean and Russian translations
Download.
http://openphdguiding.org/phd2-2.6.5dev1-installer.exe
iosif
MesajTrimis: 03 Iul 2018 11:58 Download mesaj
Titlul subiectului: PHD2 v2.6.5dev2
PHD2 v2.6.5dev2
2 July 2018
- ZWO ASI Cameras: update SDK to v1.13.0523 (Windows) and v0.7.0503 (Linux & Mac)
- SBIG cameras: fix problem not recognizing multiple SBIG cameras
- SSAG cameras (Mac): fix possible crash after connecting camera and allow entering arbitrary USB VID/PID values for cameras with corrupted firmware
- PPEC: allow stopping/starting guiding without resetting the model
- Guiding Assistant: fix handling of very large backlash to always show recommendations
- Updated Traditional Chinese, French, and Russian translations
- Debug log improvements
Download.
https://openphdguiding.org/phd2-2.6.5dev2-installer.exe
iosif
MesajTrimis: 26 Iul 2018 12:10 Download mesaj
Titlul subiectului: PHD2 v2.6.5dev3
PHD2 v2.6.5dev3
23 July 2018
- Updated calibration settings window
- Calibration distance is now configurable
- New option to display mount corrections to scale on the graph
- New low-pass ZFilter guide algorithm (experimental)
- ZWO Cameras: use default gain setting reported by the driver (default gain was way too high)
- Guiding Assistant: fix problem with invalid min-move recommendations when GA is stopped and re-started
- Guiding Assistant: enforce minimum sampling time for making recommendations
- Remove unwanted check on guide rates when dec compensation is disabled
- Fix incorrect range checks on aggressiveness for Hysteresis and Resist Switch guide algorithms
- Log uploader: fix problem with log timestamps being garbled in some time zones
- Fix display of calibration graphs on Linux
- Fix problem with star profile not being displayed when search region is less than 15 pixels and star is close to the edge of the frame
- INDI: fix phd2 crash when another app sets the camera or mount Connected property to false
event server: remove excessive debug log output when client is calling get_star_image
- Help file updates
Download.
https://openphdguiding.org/phd2-2.6.5dev3-installer.exe
iosif
MesajTrimis: 07 Sep 2018 18:44 Download mesaj
Titlul subiectului: PHD2 v2.6.5dev4
PHD2 v2.6.5dev4
4 September 2018
- Simplified Z filter settings interface
- Bookmarks are now persistent across PHD2 sessions
- ZWO cameras: update SDK to version v1.13.0821 (Window, Linux, Mac)
- ZWO cameras: provide an option to operate camera in 8-bit or 16-bit mode
- ZWO cameras: use camera model name to decide which camera to connect to
- SBIG cameras: do not rely on camera name to distinguish color vs mono
- More detailed tooltip for status bar calibration indicator
- Update the Flip Calibration menu item and tooltip to make it more explicit that it flips the calibration immediately
- Server interface: return an error response for an invalid JSON RPC request
- Server interface: fix invalid JSON message output for alert messages with embedded newline characters
- Windows: better Windows version reporting in the debug log
- Better handling of errors that occur during application startup
- INDI Aux Mount selection no longer excludes mounts that do not have the GUIDER interface
- New Profile Wizard: use an 'on-camera' mount if camera = 'simulator'; add warning dialog if selected gear has no pointing info
- Remove the None guide algorithm (aka Identity guide algorithm) selection
Download.
https://openphdguiding.org/phd2-2.6.5dev4-installer.exe
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7  Urmatoare
Pagina 5 din 7
