Numar total de mesaje in forum: 243411 |
Cel mai nou utilizator inregistrat: forties |
skyhawk Membru
Data inscrierii: 09 Iun 2011 Mesaje: 80
Trimis: 04 Mar 2014 15:01 Download mesaj |
Da, nu am cum sa instalez CUDA.
Mai demult aveam un driver mai vechi si totul era bine, boinc recunostea GPU, acum de cand cu noile drivere s-a schimbat treaba.
Nu inteleg care e motivul. |
Trimis: 04 Mar 2014 19:50 Download mesaj |
Nu-ti trebuie CUDA Toolkit decat daca vrei sa scrii/compilezi tu un program care foloseste CUDA. Driverele standard de la Nvidia au suport. "Runtime library" trebuie sa vina cu BOINC.
Q: What do I need to distribute my CUDA application?
Applications that use the driver API only need the CUDA driver library ("nvcuda.dll" under Windows), which is included as part of the standard NVIDIA driver install.
Applications that use the runtime API also require the runtime library ("cudart.dll" under Windows), which is included in the CUDA Toolkit. It is permissible to distribute this library with your application under the terms of the End User License Agreement included with the CUDA Toolkit.
Vezi, poate te ajuta asta:
... then you very probably installed BOINC with "Protected application execution" (which disables GPU computing)
To remedy:
Uninstall BOINC (task/prefs will be preserved - do not delete anything manually)
Install BOINC again and on the "Advanced" Uncheck "Protected application execution"
http://setiathome.berkeley.edu/forum_thread.php?id=69452
Daca vrei sa verifici: http://cuda-z.sourceforge.net/
Eventual vezi si ce-ti scrie prin loguri ... |
skyhawk Membru
Trimis: 04 Mar 2014 19:54 Download mesaj |
Protected application execution nu este bifata, pentru siguranta am dezinstalat Boinc si am instalat din nou. Din pacate tot asa se prezinta...Cred ca e ceva in neregula cu driverul nVidia.
Singura sansa e sa astept urmatorul update. |
Trimis: 04 Mar 2014 22:19 Download mesaj |
| Daca zici ca asta e singura sansa, da ... succes la asteptare. |
Data inscrierii: 02 Aug 2008 Mesaje: 9963
Trimis: 05 Mar 2014 02:16 Download mesaj |
Pune driverul vechi care mergea. Uneori update-urile sunt "a pain in the ass".  _________________ bino: 8x22, 7x42, 10x50, 10x80, spotting: 10x46, 20x60
skyhawk Membru
Trimis: 07 Mar 2014 00:23 Download mesaj |
Daca tot am facut valva pe aici in legatura cu boinc-ul, tin sa va anunt ca am descoperit problema dupa fel de fel de incercari.
Nu driverul placii video era problema, versiunea boinc era. Am facut downgrade de la ultima versiune la versiunea 7.0.6. Dupa toate astea programul primeste date compatibile GPU si analiza merge ok, sper sa nu existe alte probleme.
Revin cu date noi. |
