Numar total de mesaje in forum: 242472
vand starlight xpress sxv-h9c color
piskota
Data inscrierii: 01 Ian 2009
MesajTrimis: 12 Feb 2015 22:04 Download mesaj
Titlul subiectului: vand starlight xpress sxv-h9c color
Starlight Xpress sxv-h9C. Sunt al doilea proprietar.
merge perfect.
CCD Sony ICX285AL Exview HAD CCD
Resolution 1392 x 1040 pixels
Pixel size 6.45µM x 6.45µM
Chip size 8.98mm (Horizontal) x 6.7mm (Vertical)
CCD Quality Grade 1 or better - No bad columns, no dead pixels
Spectral Response QE max at 540nM (~65%), 50% roll-off at 400nM and 750nM
Readout noise Less than 12 electrons RMS - typically ONLY 7 electrons!
Full-well capacity Greater than 27,000 e- (unbinned)
Anti-blooming Overload margin greater than 800x
Data format 16-bits
System gain 0.45 electrons per ADU
Computer Interface USB 2.0 compatible interface
Image download time Typically 3.5 - 4 seconds at full resolution
Power requirements 115VAC / 240VAC @ 12VA, or 12VDC @ 750mA max
Cooling system Regulated constant current cooling supply with two stage
thermoelectric cooler to give a CCD temperature of approximately -30°C below ambient
Weight Approx. 350g
vine cu adaptor. pret 3500ron. detalii in pm. poza facuta cu telefonul-scuze.
 Marime fisier:  74.37 kb
 Vizualizat:  de 1072 ori
Nullius in verba.
piskota
MesajTrimis: 01 Mar 2015 10:59 Download mesaj
Titlul subiectului: buna ziua
se retrage de la vanzare. multumesc
Nullius in verba.
