› Numar total de mesaje in forum: 243614
afecteaza rezolutia?
marcel jinca
Data inscrierii: 16 Apr 2009
Localitate: Bumbesti-Jiu
MesajTrimis: 30 Mai 2010 20:41 Download mesaj
Titlul subiectului: afecteaza rezolutia?
Am discutat cu un prieten vis-a-vis de diametrul optim din capacul telescopului, pentru a monta acolo filtrul solar.
Intrebare: afecteaza rezolutia, diametrul respectivului orificiu? Daca cel facut de producator are 55 mm, iar in capacul telescopului meu l-am facut eu, de 35 mm, afecteaza? Intreb strict de rezolutie? Nu de luminozitate, etc.
Mutumesc.
MesajTrimis: 30 Mai 2010 20:58 Download mesaj
Da, afecteaza rezolutia.
Pentru minime detalii:
http://www.astronomy.ro/forum/viewtopic.php?t=760&start=0
MesajTrimis: 30 Mai 2010 21:22 Download mesaj
Teoretic, la o diafragma mai mica, vei avea un airy disc mai mare.
In cazul Soarelui (luminozitate mare in background) treburile se schimba.
For other image forms, resolution limit also can and does deviate significantly, both, above and below the conventional limit. One example is a dark line on light background, whose diffraction image is defined with the images of the two bright edges enclosing it. These images are defined with the Edge Spread Function (ESF), whose configuration differs significantly from the PSF (FIG. 10). With its intensity drop within the main sequence being, on the other hand, quite similar to that of the PSF, resolution of this kind of detail is more likely to be limited by detector sensitivity, than by diffraction (in the sense that the intensity differential for the mid point between Gaussian images of the edges vs. intensity peaks, forms a non-zero contrast differential for any finite edge separation).
Pe de alta parte: Image of a point source on the surface of extended objects in general - with the exception of Sun - is not detectable in amateur telescopes.
http://www.telescope-optics.net/telescope_resolution.htm
MesajTrimis: 30 Mai 2010 21:42 Download mesaj
In acest caz, prin micsorarea diafragmei, sunt de parere ca afecteaza mai mult contrastul la detalii fine, nu atat rezolutia.
