Numar total de mesaje in forum: 235226
Lecturi utile pentru lunetisti
Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7, 8  Urmatoare
MesajTrimis: 14 Feb 2013 15:05 Download mesaj
De data asta nu am sa mai pun o lectura ci imaginea unui instrument care mi-a placut in mod deosebit.
Luneta din imaginea de mai jos e construita de un amator din Michigan si este echipata cu un obiectiv acromat Jaegers de 50mm si raport focal 20.
Constructorul ei spune ca a investit 300 de ore de munca in aceasta bijuterie:
PS. Se vede ca mai avem multe de invatat! ...
 Marime fisier:  157.08 kb
 Vizualizat:  de 22629 ori
Teo
Data inscrierii: 23 Aug 2009
MesajTrimis: 19 Feb 2013 00:40 Download mesaj
O luneta de 6 inch cu f/15 construita de la zero.
Obiectivul este facut de un amator ( daca se mai poate numi amator un astfel de om... )
Are toata admiratia mea ! Smile
Va dau mai jos linkul. Sunt de urmarit toate paginile pana la final unde se arata si luneta finalizata.
Iata linkul :
http://www.cloudynights.com/ubbthreads/sho...art/8/vc/1
MesajTrimis: 20 Feb 2013 00:25 Download mesaj
Cum sa zic...unii l-ar putea lua de model Very Happy
Teo
MesajTrimis: 28 Feb 2013 00:23 Download mesaj
Ceva util si instructiv :
http://www.rfroyce.com/refractor%20spots.htm
si aici :
http://www.rfroyce.com/refobs.htm
" Without getting into details, secondary spectrum increases both as the focal ratio decreases and aperture increases. An 8" f/15 will make more secondary spectrum than a 6" f/15. In fact, an 8" refractor will have to work at f/18 to be as achromatic as the 6" f/15. "
" We do not recommend the construction of refractor objectives for serious planetary or lunar astronomical work in ratios less than f/15. This has been considered the nominal standard for acceptable performance since the mid 1800s when the Clarks began making virtually all of their refractors in focal length to aperture ratios of 15 to 1. However, the use of the BaK1 glass does allow for f/12 focal ratios in 6" sizes if customers insist - though f/15 is still preferred. I am occasionally asked to make refractors of 6" and 8" at f/10. I avoid the production of these refractors inasmuch as they will invariably produce a rather strong secondary color spectrum. The ability to recognize secondary color is interesting in that while some people do not see it at first, progressive use of the instrument and an increasing skill and awareness will eventually result in dissatisfaction. The existence of secondary color is nothing more than a defocused blur in the red and blue and a loss of contrast and information. "
Se pare ca la lunete acromate cu apertura de 6 inch, cel putin un raport f/15 ar fi de dorit pentru observatiile planetare si selenare, iar la cele cu apertura de 8 inch, un minim de f/18 ar fi ideal .
Desigur, pana la urma pentru corectarea cromatismului mai intervine si tipul de sticla utilizat.
Totusi, asta nu inseamna ca valorile de f/10- f/12 nu ar fi bune pentru lunetele acromate cu aperturi mai mici de 6 inch.
Totul consta pana la urma in a construi, a experimenta si a observa.
Satisfactia vine la final cand indrepti telescopul spre cer.
Ultima modificare efectuata de catre Teo la 28 Feb 2013 00:54, modificat de 1 data in total
MesajTrimis: 28 Feb 2013 00:45 Download mesaj
Azi am aflat de la Roger Ceragioli ca Schroeter a avut si folosit o luneta de 4 inch F/30.
Bessel a facut ,,scoala'' folosind aceasta luneta ecuatoriala -o raritate in acele vremuri-in scopuri astrometrice.
MesajTrimis: 03 Mar 2013 13:45 Download mesaj
Am gasit aseara inca un review, relativ "proaspat" pentru luneta acromata de 102/1100 fabricata de United Optics. Cred ca merita parcurs. Review-ul e semnat de Raphael Braga:
http://translate.googleusercontent.com/tra...ZfV6LqIA6w
MesajTrimis: 11 Mar 2013 23:15 Download mesaj
In alta parte a acestui forum a fost proclamata incapacitatea unei lunete de 50mm de a prezenta diviziunea Cassini.
Am sa las imaginile sa vorbeasca,spunand ca il pomenim aici pe Charles Grower si luneta sa de 50mm F=900mm deci F/18.
Evident,aceea a fost o excelenta luneta,dar ce avea Charles si ce au ,,...urmasii Romei'' e deja o alta poveste.
 Marime fisier:  56.68 kb
 Vizualizat:  de 22354 ori
 Marime fisier:  62.84 kb
 Marime fisier:  57.02 kb
 Marime fisier:  157.17 kb
MesajTrimis: 13 Mar 2013 22:06 Download mesaj
O afirmatie des repetata este aceea ca luneta este un instrument astronomic desuet.
Am sa va demonstrez ca aceasta idee este o idee indusa astronomilor amatori incepatori,dupa ce iau contact cu vreo comunitate astronomica mai mare sau mai mica,mai moderna sau mai desueta.
Daca ne uitam pe statistica unui blog oarecare (in mod ,,cu totul intamplator'' cel de mai jos imi apartine
Razz ,nu de alta dar nu prea am acces la statisticile altor bloguri ) vom vedea ca sase dintre primele zece cele mai cautate cuvinte cheie sunt diferite derivate ale cuvantului ,,luneta''.QED!
 Marime fisier:  101.77 kb
 Vizualizat:  de 22330 ori
MesajTrimis: 23 Iun 2013 22:02 Download mesaj
Cateva chestii despre justarea unei lunete:
http://philjay2000.tripod.com/usefulstuff/adventures.pdf
Lectura placuta!
MesajTrimis: 08 Sep 2013 20:50 Download mesaj
Pentru curiosi:
http://www.jdso.org/volume6/number4/binder47.pdf
Lectura placuta!
MesajTrimis: 14 Oct 2013 23:12 Download mesaj
''Noaptea lunetelor'' pe 10minuteastronomy:
http://10minuteastronomy.wordpress.com/201...efractors/
MesajTrimis: 26 Oct 2013 20:49 Download mesaj
Doua pagini interesante pentru lunetisti:
MesajTrimis: 02 Noi 2013 21:27 Download mesaj
Telescoape clasice,majoritatea lunete -dar nu numai-comentate pe situl si in cartile lui Neil English,la linkul de mai jos.
Apropiindu-se Craciunul,ma gandesc cam ce mi-ar place sa gasesc sub brad.
Ar fi cate ceva interesant intre acele telescoape.
Ma intereseaza insa mai putin ETX 90 RA ,am adaptat un Mak-Cass de 100mm F/14 la monturica mea aproape gata.
http://neilenglish.net/classic-scope-gallery-2/
Insa Zeiss Telemator-ul acela...
MesajTrimis: 21 Noi 2013 21:54 Download mesaj
Matt Wedel,despre noile sale aventuri de lunetist.
Paleontolg ziua si astronom amator pasionat noaptea,Matt ne descrie in acest articol metamorfozele unor lunete GalileoScope in mainile prietenului sau David DeLano:
http://10minuteastronomy.wordpress.com/201...ors-redux/
Cand te gandesti ca un GalileoScope a costat 15 $ +transport pentru ''cei de dincolo''...
Nu vreau sa starnesc zazanie dar mare dezamagire o fi produs multora Wedel asta.
Uite-l cum umbla acuma dupa lunete de 50mm ca Galileoscopu'.
Si pornise atat de promitator ,cum vedem in poza de mai jos.
 Marime fisier:  55.41 kb
 Vizualizat:  de 21733 ori
Alexandru Savin
Data inscrierii: 09 Mai 2011
MesajTrimis: 22 Noi 2013 11:42 Download mesaj
Chestia aia portocalie stie cineva ce e? Banui ca e un catadioptric ce seamana cu MTO-ul lui Erwin Smile
Mi-a starnit grav interesul !
O zi buna!
Alexandru
Creaza un subiect nou   Raspunde la subiect   Lunete/Telescoape Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7, 8  Urmatoare
Pagina 5 din 8
