Numar total de mesaje in forum: 242453
Super-microscopul lui Royal Raymond Rife
Optica
jimao22
Data inscrierii: 12 Apr 2010
Motto: [descopera lumina]
MesajTrimis: 08 Apr 2014 22:41 Download mesaj
valy a scris:
Nu ma pricep la biologie/virusologie/etc, dar chiar trebuie sa vezi bacteria cum da din coada ca s-o poti anihila? In film subliniau ca vad bacteria ca sa o radieze si sa vada ca a murit, dar ma gandesc ca poti face 100 de probe, radiezi fiecare cu alta unda si la sfarsit vezi care din ele a murit folosind si alte mijloace nu doar simpla vizualizare.
Sti cum ai explicat tu aici?
Cam asa: iei un mort, tragi in el cu pistolul, apoi il intepi cu cutitul si la urma ii dai in cap cu un topor si vezi daca a murit.
MesajTrimis: 08 Apr 2014 23:10 Download mesaj
Din pura placere , am studiat la microscop destul de multe din lumea vie si marunta .
In mod sigur , informatia colectata si inteleasa , depaseste cu mult pe cea din probele la care subiectul a dat mai intai ortul popii. Uneori nici disectia nu ofera mai multe informatii.
Categoric poti afla mai repede punctele slabe ale unei dihanii in miscare , fie ea si microscopica .
Hai noapte , hai !!
MesajTrimis: 09 Apr 2014 00:29 Download mesaj
Din referinta data de Erwin:
The Rife Microscope
By: Dr. Royal Raymond Rife
The source of illumination used on this instrument is a more predominating factor in identifying the filter passing form or cycle of micro-organisms than the high magnification. The color volume is intensified and the differentiating value greatly enhanced, if a magnification of 6,000 or 8,000 is used. It is to be understood that the source of illumination applied to this instrument is in no wise true polarized light (that is, no nickel prisms are used), but is a monochromatic beam of variable angles of incidence passed through the direct transmitted light, refracting different colors according to the chemical composition of the organism under observation. This principle of light control reveals the organism in its own particular color in a brilliantly illuminated field.
It should be understood that I have in no way made statements or claim to the effect that this microscope is superior in any way to the excellent instruments manufacture by our A-Grade Optical Companies. However, it has answered the purpose of others, as well as myself, in the special work we have called on it to perform.
Deci ??
MesajTrimis: 09 Apr 2014 01:07 Download mesaj
jimao22 a scris:
valy a scris:
Nu ma pricep ...
Sti cum ai explicat tu aici?...
Am zis eu ca nu ma pricep, deci am avut dreptate, macar aici Wink.
Ce ziceam eu era in contextul filmului: fara 60.000x optic nu putem salva lumea, conspiratia guvernului si a firmelor de medicamente, salvati microscopul optic, salvati RRR. Saracii astia cu bosomul sau cu stringurile, ar trebui sa se duca acasa ca n-au miscroscop sa le vada.
Nobody, e intr-adevar o diferenta de "nuanta" intre film si referinta postata, e un fel de efect "Tesla" in film.
MesajTrimis: 09 Apr 2014 02:01 Download mesaj
În acea parte de film autorul fabulează un pic, își imaginează că în celule sunt alte celule în care sunt alte celule și cine știe câte la infinit? De acord că în celule există organite celulare, dar azi se știe că acestea nu sunt celule în care se află alte celule. Nu putem trece peste ce se știe azi acceptând pe nemestecate ceea ce credeau acum 50 de ani oamenii de știință.
Deci acel 50.000 sau 60.000 e o simplă extrapolare a ceea ce a realizat efectiv, imaginându-și că se poate merge mai departe cu aceeași schemă. Pe acea vreme nu cred că se cunoșteau atât de bine limitele opticii pentru că nimeni nu le atacase încă.
jimao22
MesajTrimis: 09 Apr 2014 09:33 Download mesaj
Erwin a scris:
....dar azi se știe că acestea nu sunt celule în care se află alte celule. Nu putem trece peste ce se știe azi acceptând pe nemestecate ceea ce credeau acum 50 de ani oamenii de știință.
Sti ce nu inteleg eu?
Daca astazi se stie atat de mult ce se stie, de ce oare marea batalie impotriva cancerului, in care s-au bagat pana acum 50 de miliarde de dolari de cand a inceput, e un mare vax si numarul mortilor de cancer a crescut exponential? Si de ce oamenii de stiinta de acum 50 de ani, nestiind mare lucru, au reusit sa trateze 100% boala (asa cum a facut Rife), ca doar stiinta nu era asa de evoluata?
Daca vrei sa vezi ca un pom este bun, trebuie sa-i vezi roadele. E o vorba straveche, la fel de actuala azi. Si pe care trebuie sa o aveti in vedere intotdeauna cand faceti judecati de valoare.
MesajTrimis: 09 Apr 2014 10:41 Download mesaj
jimao22 a scris:
..Si de ce oamenii de stiinta de acum 50 de ani, nestiind mare lucru, au reusit sa trateze 100% boala (asa cum a facut Rife), ca doar stiinta nu era asa de evoluata?
Chiar a reusit sa o trateze?
jimao22
MesajTrimis: 09 Apr 2014 10:50 Download mesaj
Inteleg ca nu ai vazut filmul, din ce spui. Sau daca l-ai vazut, nu l-ai urmarit cu atentie.
Nu o spune el (ca e mort demult) ci cei care i-au descoperit munca si care vor sa i-o continuie. A fost un om de stiinta in adevaratul sens al cuvantului, vezi cum facea munca de cercetare - facea cate 10-14 teste pentru aceeasi procedura si daca avea rezultate identice, numai atunci o considera valida. Iar oamenii pe care i-a tratat el, pana sa intervina smecherii, au fost tratati in proportie de 100%. Fara esecuri.
Acuma daca nu crezi asta fiindca nu ai vazut cu ochii tai, e problema ta. Inseamna ca vrei sa crezi doar ce vrei tu in acest caz. Fiindca (de exemplu) nu cred ca ai vazut cu ochii tai vreun boson sau vreun atom, dar presupun ca esti sigur de existenta lor.
MesajTrimis: 09 Apr 2014 11:09 Download mesaj
Si acum se trateaza cancerul de exemplu prin radiatii, nu stiu daca e 100% rata de succes ca la RRR.
Am vazut filmul pana pe la jumate.
Cu bosonul e chestie de teorie si de potrivire a experimentului ca sa confirme teoria. Acum nu stiu ce sa zic, si eu cand mai faceam experimente, daca vroiam il puteam face sa iasa exact "cum trebuie".
Oricand exista sansa ca anumiti sa ignore sau sa ingroape o idee doar ca nu este a lor, ca sa nu isi piarda banii, faima, etc., lucrurile astea se intampla dincolo de teoria conspiratiei.
MesajTrimis: 09 Apr 2014 12:01 Download mesaj
Filmuletele astea "stiintifice" de pe NET sunt pt mine doar niste sarmane instrumente de manipulare deja tocite dar totusi sunt o multime de oameni chiar si cu studii ce savureaza toate prostiile .
jimao22
MesajTrimis: 09 Apr 2014 13:39 Download mesaj
Nu e mai putin stiintific decat un documentar de pe Discovery Channel sau National Geografic Channel la care belesc ochii 3/4 din oameni. Mai curand as zice ca astea sunt un instrument de manipulare puternic, tocmai prin prisma faptului ca au o audienta asa de mare.
Cand au aparut cele 2 canale, documentarele lor erau foarte interesante si obiective (acum e off-topi ce scriu, desigur). Dupa ce si-au capatat credibilitate, au inceput sa o ia razna prin balarii, prezentand documentare evident facute la comanda, ca sa influenteze opinia publica intr-un sens sau altul.
Acum, ca sa reveni la oile noastre, daca te-ai uitat la film, Tavi, ai vazut ca cei ce apar acolo sunt doctori si alti oameni de stiinta din zilele noastre, ce incearca sa recompuna din franturi ce a facut omul ala, frustrati fiind ca FDA si industria farmaceutica au facut front comun in a bloca orice efort in directia asta. Nu-ti trebuie multa minte sau studii superioare ca sa intelegi ca astia din urma nu au nevoie de "leacuri" pentru boli. Daca nu mai sunt boli, nu mai sunt bani de cheltuit cu medicamente. Iar industria farmaceutica este la fel de rentabila, cu marje de profit de zeci de ori intrarile, precum se intampla in traficul de droguri. Doar ca aste e ceva legal. Cine crezi ca da o mina de aur din mana?...
Ma rog, crede fiecare ce vrea. Ideea de la care am pornit totusi era legata de optica si am avut unul sau doua raspunsuri care sa ma mai lumineze un pic. Multam celor care au raspuns.
MesajTrimis: 09 Apr 2014 14:00 Download mesaj
1. Unde sunt bani lucrurile se complica, chiar si (mai ales) la discovery. Cum distingi intre cei onesti si cei pe interes? Dintr-un film, dintr-un interviu cu oameni de stiinta, doctori? Poate da, poate nu. Din experienta mea limitata am dedus ca nimic nu este ceea ce pare a fi, trebuie tot timpul sa fi in garda si sa citesti printre randuri.
2. Inteleg ca microscopul respectiv nu are nimic special, e 6000x + ceva jocuri de lumini, curent se foloseste 2000x, deci acei 3x in plus sa faca diferenta dintre a gasi leacul la cancer si a nu gasi? Daca lumina e problema, doar lumina sa faca diferrenta? Vad ca si cele curente folosesc lumina polarizata/monocrona.
LE: https://www.google.ro/search?q=most+powerf...ywOvnYGwCQ ~6.500x
MesajTrimis: 09 Apr 2014 23:26 Download mesaj
Da, se trateaza cancerul la modul ''tratamentul a avut succes si pacientul a murit''. Am vazut asta de cateva ori in apropierea mea, si chiar in urma cu cateva luni cu un cumnat al meu. Care, culmea, avea si mijloace.
Scuzati off-topicul. Dar am o intrebare. Ati vazut vreodata cum sufera un bolnav de cancer? Daca raspunsul ar fi pozitiv, sunt sigur ca a-ti considera ca orice metoda imaginabila trebuie incercata.
Eu unul am devenit sceptic. Sceptic referitor la scepticismul oamenilor. Cine a citit ceva scrieri antice, incepand cu Biblia, stie ca acest scepticism, principial justificat, e de cele mai multe ori exagerat, cu profunde legaturi in invidie, si in comoditatea de a gandi. Si e o boala foarte veche. Iar mai nou, a devenit o institutie, chiar o moda. Cine gandeste peste patul lui Procust, cine pune intrebari, e imediat etichetat ca adept al teoriei conspiratiei.
Da, nu pot sa cred pur si simplu tot ce vad pe net. Si de aceea, incerc sa ma documentez, si sa imi formez o parere argumentata inainte de a emite o opinie. Oricum, pe net lucrurile stau mult mai bine decat la TV, unde avem doar manipulare. Si cel putin pe net, pot sa-mi aleg sursele, si sa le coroborez.
E o vorba veche. Nu judeca o carte dupa coperta. Mai nou cred ca zicala a devenit - Nu judeca, nu gandi.
MesajTrimis: 10 Apr 2014 01:24 Download mesaj
Dacă există într-adevăr o conspirație a oamenilor de știință/medici și a concernelor farmaceutice cum de aceasta n-a fost dezvăluită concret până acum? Doar există wikileaks și oameni ca Snowden care au dezvăluit secrete mult mai bine păzite? La cât de mare este și cât de mult personal intră și iese din sistemul laboratoarelor farma nu s-au găsit unii care să îi dea în gât concret, cu date și dovezi?
Hai să revenim la optică. Cred că instrumentul în sine este demn de toată admirația! Ca ATM-ist nu pot decât să mă înclin la așa ceva, e o lucrătură de mecanică fină foarte interesantă. Mi-a plăcut că micro-focalizarea se face hidraulic, cu glicerină împinsă de un șurub micrometric. La așa măriri mari focalizarea clasică cu cremalieră nu mai ține, oricâte precauții s-ar lua pentru eliminarea jocurilor. Sunt sigur că și trenul optic de prisme și lentile este foarte sofisticat, nu e chiar la îndemâna oricui, mă gândesc în principal la câte precauții trebuie luate la colimare și cât de greu e să le aliniezi ca să nu ai probleme. În condițiile în care azi avem lasere poate e mult mai simplu, dar pe atunci laserul nu era încă inventat.
MesajTrimis: 10 Apr 2014 08:41 Download mesaj
Marile secrete de la wikileaks erau in general politice, si de importanta minora. Iar marea dezvaluire a lui Snowden, cea privind sistemele de interceptare, era cunoscuta de ''adeptii teoriei conspiratiei'' de mult. Sau facut chiar si filme despre asta inainte de Snowden. Eu am o revista de aviatie din Franta, din 1996, in care se vorbeste despre aceste sisteme. Dar nu existau inca documente clare, erau doar zvonuri.
Insa este una sa dezvalui secrete scrise in documente, conform regulilor statelor, si alta intelegeri intre marile corporatii, care nu sunt scrise, ca nu e nevoie, si sa te expui riscurilor, altele decat cele legale, daca vrei sa te lupti cu acestea. Si fara documente referitoare la o astfel de presupusa intelegere, ce poti sa faci?
Da, e greu sa crezi ca exista atata cinism. Dar discutia asta imi aduce aminte de filmul Elysium.
Creaza un subiect nou   Raspunde la subiect   Optica Du-te la pagina Anterioara  1, 2
Pagina 2 din 2
