› Numar total de mesaje in forum: 244066
Sequence Generator Pro
Soft pentru astronomie
sabin fota
Membru de onoare
Membru de onoare
Data inscrierii: 09 Iul 2008
Motto: Nihil Sine Deo
MesajTrimis: 23 Apr 2015 19:44 Download mesaj
Titlul subiectului: Sequence Generator Pro
Home:
http://www.mainsequencesoftware.com/
Sequence Generator Pro v2.4
Sequence Generator Lite - It's Free!
- Powerful Sequencing
- Equipment Profiles
- Auto Focus
- Automated Meridian Flip
- Flexible Focusing Patterns
- Target Framing Made Easy
- Center on Any Part of an Existing Image
- Create Complex Mosaic Sequences in Mere Minutes
- Flat Frames Made Easy
- Other Features:
=Dither between frames with your choice of three auto guiders (PHD, Astroart and MetaGuide)
=Easily perform frame and focus routines (with support for subframes and high speed cameras)
=Feel at home with our highly customizable user interface (drag, dock and float small modules for almost any action)
=Over a dozen configurable UI modules (PHD graphing, Image Pan and Zoom, TEC control)
=User defined TEC cool down and warm up routines (to minimize thermal stress on your camera’s sensitive components)
=Between-frame temperature compensation
=Easily create and run a “flats” sequences from your “lights” sequence
=Detailed documentation and instructional videos
=Near immediate customer support via email or our forum
=Hundreds of other features!
Forum:
http://forum.mainsequencesoftware.com/
Eu il folosesc de o perioada buna si vi-l recomand cu caldura, aveti 45 de ziele sa il testati iar la cate stie sa faca si ce suport excelent ai din partea producatorilor nici nu costa mult:
- 99 $ Sequence Generator Pro v2.4
- 39$ Framing and Mosaic wizard
- 19$ Notification system
http://sabinfota.ro
jimao22
Data inscrierii: 12 Apr 2010
Motto: [descopera lumina]
MesajTrimis: 27 Apr 2015 17:09 Download mesaj
Un hang-out de ieri, inregistrat pe youtube despre Sequence Generator Pro, prezentat de chair autorii sai.
https://www.youtube.com/watch?v=Dv_G7kWYbrM#t=13
sabin fota
Membru de onoare
Membru de onoare
MesajTrimis: 09 Aug 2015 18:30 Download mesaj
http://www.mainsequencesoftware.com/Releases
Sequence Generator Pro Beta v2.4.2.4
Released: 07/27/2015
Release notes:
Adding new feature that allows you to control the number of captured frames per event (helpful in order to compensate for bad frames and showing only what you have really captured)
Added option when marking a frame bad to also decrement the captured count on the event of origin. http://forum.mainsequencesoftware.com/t/re...ter/1007/2
Focuser temperature "smoothing". For the focuser, SGPro will now return the mean temperature over the last 5 minutes. This should help with "jittery" readouts and reduce the number of erroneous autop-focus triggers because the focuser decided to report a spontaneous one degree delta (or similar).
Added two backup systems for the mosaic and framing wizard target lookup system. One is the SIMBAD mirror hosted at Harvard and the other is local database (now installed with SGPro containing more than 10,000 targets (~1MB). SIMBAD in France seems to be down a lot lately so we added this to improve user experience.
Added support for the Nikon D810A
Hopefully fixed the "Right click to center" bug found when using the Astrometry.NET solver
Sequence recovery will now terminate prior to the 90 minute time limit if the scope passes the meridian.
Can now deselect or select all targets by right clicking (a new option in the target context menu)
Added the PIXSCALE FITS header
Added ability for FLI cameras to set readout speed
Note: FLI settings have radio buttons for RBI mitigation (this is not yet functional).
Fixed an issue where trying to blind solve 32 bit reference fits would crash SGPro.
SGPro will no longer attempt to sync scopes / mounts that don't want you to sync with them (Like TPoint in some cases).
Updated the type of high precision timer we use to time images (will hopefully help folks who have been seeing inconsistent wait times for exposures)
The "Direct Mount Guider" is now capable of performing meridian flips
Fixed a bug that would sometimes show an error when rendering the filter image icon
Added Nikon D4 to the bulb camera list
Auto focus pause now occurs prior to AF filter change
Fixed a bug where SGPro would crash if an empty ImageHistory cell was right clicked
http://sabinfota.ro
sabin fota
Membru de onoare
Membru de onoare
MesajTrimis: 13 Sep 2015 19:05 Download mesaj
Sequence Generator Pro Beta v2.4.3.2
Released: 09/13/2015
Stabilized communication between SGPro and PHD2 (for profile management). Not perfect yet, but way better than 2.4.3.1. This beta requires the use of PHD2 2.5.0dev3. If you are not comfortable with using PHD2 dev builds, you might want to stick with the SGPro 2.4.2 release. You can find it here: http://openphdguiding.org/development-snapshots/
Fixed a bug that could cause the dome to move in the wrong direction when imaging targets near the pole.
*Known Issue*: If you open PHD2 by clicking its "settings" button on the control panel, do not close this instance of PHD2 prior to starting your sequence. SGPro will get confused about which version of PHD2 it is supposed to talk to and error out. This will be fixed in the next beta.
http://sabinfota.ro
iosif
Data inscrierii: 17 Oct 2012
Localitate: Sandra Timis
MesajTrimis: 31 Mar 2016 17:35 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.5.0.23
Sequence Generator Pro v2.5.0.23.
Update nou, se poate vedea ce este nou, si proba 45 de zile.
Introduction of the SGPro "Environment Device". Use this device (like a BlueAstro Stick Station) to provide data about your imaging environment:
A new docking module displaying environmental data and trends
Warning when the temperature is approaching the dew point (requires notification add-on)
Warning when the temperature is approaching freezing (requires notification add-on)
Am conectat Blue Astro stik Station prin ascom si afiseaza bine temperatura, umiditate, presiune si punctul de aparitie la roua.
________________________________________
 Marime fisier:  292.56 kb
 Vizualizat:  de 25277 ori
iosif
MesajTrimis: 21 Mai 2016 16:09 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.5.1.14
Released: 05/18/2016
Ce e nou in versiunea v2.5.1.14
http://www.mainsequencesoftware.com/Releases#
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8141
Cer senin IOSIF.
iosif
MesajTrimis: 25 Iun 2016 14:29 Download mesaj
Titlul subiectului: Sequence Generator Pro v2.5.1.16
Released: 06/23/2016
- Fixing duplicated frames for SBIG
- Adding additional logging to track fast frame lockups
- Potentially fixed fast frame lock ups for all cameras
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8143
Emil
Data inscrierii: 30 Aug 2007
Localitate: Fuerstenfeld
MesajTrimis: 13 Sep 2016 20:24 Download mesaj
Sequence Generator Pro Beta v2.5.2.1
Released: 09/11/2016
Release Notes
Fixed a bug where some (probably most) old equipment profiles would not load correctly.
Fixed an issue where some users could see erratic behavior with frame restarts when the telescope is on the east side of the pier.
2.5.2.0 Notes:
Experimental: New behavior for the "Auto adjust focus per filter" option. When taking "light" frames, you can expect this to work as it always has in the past... no change here. When taking "flat" frames and this option is on, SGPro will automatically attempt to set your focuser to a suitable focus position. If you just finished imaging, you are already there... if you are taking flats on a different night, SGPro will set the focuser to focus position nearest your current temperature. If it can't find one, it will use the average focus position for that filter. If it can't find that, it will do nothing. Nobody asked for this (I don't think), but I wanted something like it so I added it in...
Sync behavior: Added functionality to the telescope tab to define "sync behavior". This also affects the process by which SGPro centers on a target. Choosing "Sync" will cause SGPro to function like it normally does. **This is what you should continue to use for this beta.** Choosing "Offset" will use a sort of "Syncless" centering algorithm and should be used with mounts that really don't want external applications trying to sync the mount's position. This option is complete, but **_has not been tested AT ALL. Use at your own risk... DO NOT USE THIS OPTION UNATTENDED!_**
MFW Image Fetching: MFW now queries from the DSS2 survey first (better quality images), then if that fails will default to the original DSS survey (current survey in use by MFW).
Dither Every N Frames: Added option to auto guider to dither every N frames.
Settling distance: Changed this from a drop down menu to a numeric control.
Bug fix: Fixed an issue where centering (and meridian flips) might hang SGPro and report that the camera has timed out.
Bug fix: Fixed a bug where the auto centering validation step could fail on camera rotation if the primary solver failed.
Bug fix: Fixed an issue where SGPro could attempt to take an image without having sufficient time to finish before meridian flip.
Misc: SGPro no longer performs a dither on the first frame (will still settle though)
Misc: Added account management links to the help menu and registration dialog.
http://mainsequencesoftware.com/Releases/DownloadFile?id=8146
iosif
MesajTrimis: 19 Dec 2016 01:03 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.0
Released: 12/18/2016
-The target centering routine will now skip the "pre-slew" solve and sync step. While this will make centering faster and compatible with a wider range of mounts, it will also place more onus on the user to ensure that the mount is properly synced prior to starting a sequence. This will also likely fix failure of the "Offset2" mount sync method.
-The meridian flip routine will now skip the "pre-flip" solve and sync step.
-Added an Observatory floating control module
-Added a Flat Box floating control module
-SGPro targets now remember any reference URL used to populate its location parameters.
-SGPro now remembers the last MFW FoV used to fetch the working canvas.
-SGPro now properly handles the PHD2 message indicating failure to settle
-More UI changes.
-Fixed a bug, that in rare circumstances, might "roll" the number of captured events from 9 back to 1. -No loss of data occurs, but event frames would be recaptured.
-Fixed a bug that would automatically turn ASCOM focuser temp compensation off when it connects.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8154
_______________________________________________________________
O imagine si cu programul, care are o multitudine de facilitati.
 Marime fisier:  357.62 kb
 Vizualizat:  de 24158 ori
iosif
MesajTrimis: 22 Dec 2016 15:25 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.1
Released: 12/22/2016
Release Notes.
- Refactoring "Reverse Focuser" logic. Everything now resides in two places: the "Move" and the "GetCurrentPosition". Focuser position should almost never be called outside of these two places. This refactor effectively masks the real focuser position when Reversed. For instance if the focuser has 10,000 steps and is currently at position 2000 then when reversed SGP will report 8000 steps. Backlash compensation is in terms of "SGP Reported" steps not the actual steps of the focuser. So "IN" will always trigger backlash when the focuser moves from Low to High in SGP Reported Steps not Focuser Reported Steps. The main benefit of this is to have Auto Focus and backlash both work transparently when reversed. More info here: http://forum.mainsequencesoftware.com/t/ri...us/4544/10
- SGPro now remembers your event suffixes and automatically populates the suffix drop down. There is no interface to create suffixes. If the suffix list becomes too long, you can clear it by using the new "clear" functionality in the SGPro options dialog.
- Added flip delay API calls (http://forum.mainsequencesoftware.com/t/2-6-0-0-meridian-flip-problem/4651/9).
- Fixed a bug where FLI cameras would immediately disconnect after connecting.
- Fixed a bug that might not allow some focusers to accept temperature override from the environment device.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8155
__________________________________________________________________
 Marime fisier:  379.55 kb
 Vizualizat:  de 24086 ori
iosif
MesajTrimis: 27 Dec 2016 18:32 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.2
Released: 06/26/2016
- Added vertical sizing to the sequencing window. It's not smart... it doesn't attempt to auto adjust, it does not remember how it was set, but it does allow you to resize the event table for better visibility.
- Fixed a major bug where auto centering after a meridian flip would fail.
- Fixed a bug with dealing with odd frame counting behavior.
- Fixed a bug that would cause SGPro to crash if the Image History dialog was invoked while already visible.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8156
______________
 Marime fisier:  301.65 kb
 Vizualizat:  de 24032 ori
iosif
MesajTrimis: 30 Dec 2016 20:45 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.4
Released: 12/30/2016
Release Notes
- SGPro will now show an error if the user attempts to rotate to a target position and the rotator does not have a sync.
- SGPro will now detect if a sync is required and automatically perform a solve and sync at the beginning of a sequence (one time).
- Added "slaved to telescope" indicator to the dome module.
- Added a warning dialog if the user attempts to open a new sequence while the camera is cooling or warming.
- Added a warning notification to let the user know if the camera was unable to attain the target temperature prior to starting the sequence.
- The delay sequence on camera temperature dialog now contains a better description of what the "Delay Start" option actually does.
- When attempting to start a sequence with the TEC temperature out of band, the warning dialog will now display the TEC's current temperature and state (Idle, cooling, warming).
- Fixed a bug where 2.6.0.3 could no longer open sequences.
- Fixed a bug where navigating image history would fail to update the HFR and star count metrics in the image stats module.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8158
____________________________________________________________________
iosif
MesajTrimis: 02 Ian 2017 17:28 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.5
Released: 01/02/2017
Release Notes.
- The Mosaic and Framing Wizard now allows users to cancel fetch requests for the working canvas (a bunch of code was refactored in order to do this properly... may need some more testing, but it's certainly functional).
- Fixed a bug that would clear progress (visually only) when a profile was applied to an existing sequence.
- Fixed a bug that did not properly flag a sequence as needing to be saved when some properties were changed.
- Fixed a bug that did not properly flag a profile as needing to be saved when some properties were changed.
- Fixed a bug that prevented the Profile Manager's status text from displaying properly.
- Fixed a bug that would cause the Profile Manager to assume that the initial profile (on load) was in need of save and prompt the user when switching profiles.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8159
iosif
MesajTrimis: 10 Ian 2017 20:25 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.6
Released: 01/10/2017
Release Notes
- Added target import functionality for DSO-Browser (including an early version of suggested target start and end times based on visibility information provided by DSO-Browser).
- The MFW is now more tolerant of corrupt cache files.
- Independent movement of the observatory shutter / roof or rotation now provides a warning if it is slaved to the telescope.
- Connecting to the camera no longer flags the sequence as needing to be saved.
- The plate solve API now honors the plate solver's chosen search method (in the control panel).
- Added PlateSolve2 search region increments 1000 through 3000 (was previously capped at 999).
- Added the user profile name to the sequencer title bar (after the equipment profile).
- Rounded camera temperature to a whole number for insertion into file names.
- Fixed a bug where the flat box module was not in sync with the control panel.
- Fixed a bug where a sequence failure due to lost guide star would not allow for end-sequence capture of calibration frames.
- Fixed a bug where several popup windows attached to the sequencing window would not close properly when the sequencer closed.
- Better Nikon logging.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8160
iosif
MesajTrimis: 14 Ian 2017 00:58 Download mesaj
Titlul subiectului: Sequence Generator Pro Beta v2.6.0.7
Released: 01/13/2017
Release Notes.
- Added a warning to notify the user if the sequence uses a plate solver and the image scale is 0.
- Fixed the DSO-Browser target import feature.
- Updated help file to include instructions for target import from DSO-Browser.
- Updated Canon SDK to version 3.4 (needs testing).
- Updated Windows icon for SGF files.
Download.
http://www.mainsequencesoftware.com/Releases/DownloadFile?id=8161
Camera ia o imagine, se analizeaza pozitia, si foarte usor se importa un targhet din https://dso-browser.com/ my list. Dupa importul tintei montura se duce pe tinta aleasa si se fac ajustarile necesare, focus, etc.
 Marime fisier:  351.05 kb
 Vizualizat:  de 23836 ori
 Marime fisier:  343.79 kb
 Marime fisier:  294.58 kb
 Vizualizat:  de 23835 ori
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina 1, 2, 3  Urmatoare
Pagina 1 din 3
