› Numar total de mesaje in forum: 243971
Luneta Bosma 102mm F/6.5 triplet fpl-53
Catalin Paduraru
Data inscrierii: 08 Mai 2006
MesajTrimis: 20 Mai 2024 07:03 Download mesaj
Titlul subiectului: Luneta Bosma 102mm F/6.5 triplet fpl-53
Vand luneta Bosma cu obiectivul de 102mm F/6.5 triplet cu elementul ED FPL-53.
Luneta nu este intr-o stare perfecta, are mici semne de folosire. Estimez varsta lunetei la 10 ani.
Este colimata, aberatiile cromatice sunt aproape inexistente, stelele sunt foarte mici.
Manufacturer: Bosma
Model: Omega ED 102
Diameter: 102 mm 4"
Focal length: 660 mm
Focal ratio: f/6.5
Resolution: 1"
Optical design: apochromatic refractor with ED element, triplet
Glass type: FPL53
Coating: fully multi-coated
Tube/optics weight: 4.4 kg
This refractor is sold under the brand names Maxvision and Astronomy Technologies (Astro-Tech), among others.
The Bosma Omega ED102 is a refractor with three lenses (triplet) with an air gap, with a lens made of the special glass material FPL-53 between the "normal" lenses. This means significantly better color correction and therefore higher image sharpness and higher contrast than a refractor without this element with the same aperture. This significantly increases the ability to perceive details, even with deep sky objects. The lens cell is adjustable, but is mechanically fixed by us after we have adjusted the telescope, so that misalignment is ruled out in the long term, even under heavy use.
The eyepiece focuser works according to the Crayford principle. This means smooth focus adjustment. This OAZ is more sensitive than a rack and pinion eyepiece focuser. It is supplied with a 1:10 reduction which makes fine adjustment easier.
The tube is made of high-quality aluminum with a very good paint finish, is provided with sufficient apertures and has a good internal blackening to avoid stray light. The dew cap can be inserted.
The lockable aluminum transport case supplied is very sturdy.
Ca sa nu existe dubii, pot da luneta la teste si daca nu va place o pot primi inapoi.
Ce se vinde:
- luneta
- cautatorul
- inelele de prindere
- sina vixen
- cutie de aluminiu
- filtru solar de sticla
- nu am reductie de la 2" la 1.25"
Pret: 6000 lei
 Marime fisier:  120.94 kb
 Vizualizat:  de 9636 ori
 Marime fisier:  92.43 kb
 Marime fisier:  82.28 kb
 Marime fisier:  137.36 kb
 Marime fisier:  73.75 kb
 Marime fisier:  86.04 kb
 Marime fisier:  82.75 kb
 Marime fisier:  152.68 kb
 Marime fisier:  119.74 kb
 Marime fisier:  90.6 kb
Catalin Paduraru
MesajTrimis: 25 Mai 2024 08:24 Download mesaj
Poate am gresit pretul, pret nou: 5500 lei.
Catalin Paduraru
MesajTrimis: 03 Iun 2024 12:20 Download mesaj
Preț nou: 5000 lei.
Catalin Paduraru
MesajTrimis: 10 Iun 2024 08:00 Download mesaj
Chiar nu vrea nimeni o luneta triplet cu FPL53 de 102mm pe testate la 4500 lei?
Ce magazin iti da optiunea sa testezi inainte sa cumperi?
Catalin Paduraru
MesajTrimis: 18 Iun 2024 07:53 Download mesaj
Pret nou 4000 lei.
Catalin Paduraru
MesajTrimis: 28 Iun 2024 07:46 Download mesaj
Pret nou 3900 lei.
Catalin Paduraru
MesajTrimis: 07 Iul 2024 09:23 Download mesaj
Pret nou 3800 lei
MesajTrimis: 12 Iul 2024 23:28 Download mesaj
Titlul subiectului: Bosma 102
Salut. Ma cam atrage aceasta luneta.
As dori sa stiu cateva lucruri. Lungimea lunetei cu parasolarul retras, si cu el extins, plus o diagomala de 2''. Ca sa stiu daca pot sa o folosesc din balcon. Ca am balcoanele cam mici, si newtonienele mele nu incap. Sau incap ele, dar eu nu.
Si cam cat ar trebui sa tina o montura pentru observatii vizuale, si eventual la foto planetar cu un DSLR. Deci nu pentru expuneri de timp lung. Cam la ce greutate ar trebui sa raspunda bine o montura.
Catalin Paduraru
MesajTrimis: 14 Iul 2024 10:23 Download mesaj
Revin cu informatiile cat de repede pot. Am luneta depozitata in alta locatie si cred ca maine ajung acolo.
Legat de greutate, pentru vizual din punctul meu de vedere este ca instrumentul sa cantareasca cam 1/3 din greutatea maxima pe care o poate duce montura. Iar pentru foto cel mult 1/3, ideal 1/2. Asta pentru monturile cu roata dintata si melc, pentru cele cu harmonic drive cred ca poti merge cam pe la 1/4 - 1/5 din greutatea recomandata.
Catalin Paduraru
MesajTrimis: 16 Iul 2024 21:51 Download mesaj
Revin cu info:
61cm cu parasolarul strans
71cm cu parasolarul extins
aproximativ 78-80cm cu tot cu prisma
MesajTrimis: 17 Iul 2024 02:24 Download mesaj
Multumesc pentru raspuns. Insa am fost pus in fata unei alegeri clasice. Utilul contra placutul. Respectiv un laptop nou contra o luneta APO. Castigatorul e usor de ghicit.
Iti urez spor la vanzare.
Catalin Paduraru
MesajTrimis: 19 Iul 2024 08:15 Download mesaj
Pret nou 3700 lei
Catalin Paduraru
MesajTrimis: 29 Iul 2024 11:43 Download mesaj
Ultima reducere, 3500 lei. Daca nu se vinde la pretul se retrage de la vanzare.
vaspaoul
Data inscrierii: 15 Iul 2020
MesajTrimis: 12 Aug 2024 10:07 Download mesaj
Foarte faina luneta, m-am intalnit cu Catalin si am testat-o si e impecabila din punct de vedere optic. Sharpness si contrast foarte bun, colimata bine, stele punctiforme, fara aberatii cromatice.
Se vede calitatea lentilei FPL53.
Si per total e o luneta compacta, usoara, fain designul si bine gandita (rotatia focuserului ajuta foarte mult la vizual daca ai montura EQ, sau la framing), vine intr-o geanta solida, unde incap toate accesoriile si o protejeaza. Si filtrul de soare e top. Nu am vazut niciodata soarele asa frumos cum se vede cu luneta asta, desi l-am vazut prin multe instrumente.
Ma tenta foarte tare sa o iau chiar eu, dar deja am prea multe instrumente, si nu mai am timp acum de iesit si vandut/cumparat. Dar pe viitor, daca o sa mai am timp - sigur o sa caut ceva cu FPL53/SD.
Catalin Paduraru
MesajTrimis: 05 Sep 2024 14:05 Download mesaj
Ultima actualizare la pretul acesta.
