› Numar total de mesaje in forum: 243451
Stellarium 0.11.2
Linkuri utile
bebe
Data inscrierii: 05 Noi 2010
Localitate: Bocsa
MesajTrimis: 25 Apr 2012 10:06 Download mesaj
Titlul subiectului: Stellarium 0.11.2
http://www.stellarium.org/
micrenda
Data inscrierii: 26 Mai 2011
MesajTrimis: 25 Apr 2012 13:18 Download mesaj
Release notes:
Stellarium 0.11.2 has been released. Stellarium is a photo-realistic, general-purpose astronomy software. http://stellarium.org
Stellarium 0.11.2 is a stable version that introduces some new features and closes 47 bug and wishlist reports. A lot of work has been done on making translatable text that wasn't localized before. This includes most of the text used by the default plug-ins, landscapes, countries, script names and descriptions. The Oculars plug-in now has an optional control panel with buttons for those affected by the "missing menu" bug, but it needs to be enabled in the Oculars configuration window. An feature for importing new satellites has been added to the Satellites plug-in, so be sure to reset its settings to get the new data sources. A more detailed change log follows below.
A huge thanks to the people who helped us a lot by reporting bugs!
Change log:
One of the main directions of this version is localization:
most of the text used by the default plug-ins is now translatable
landscape names are now translatable
country names are now translatable
scripts names and descriptions are now translatable
Oculars plug-in:
added an optional control panel displayed in the upper-right corner of the screen as an alternative to the pop-up menu that was used to control it in the previous version;
overhaul of the pop-up menu, the underlined letters in it can be used as keyboard shortcuts;
added the ability to rearrange the items in the lists of oculars, telescopes and sensors;
fixed the inappropriate flipping of the binoculars view;
Satellites plug-in:
fixed title bar of the Satellites config window not being resized with the rest of the window (LP: #900575)
catalog numbers are now used to identify satellites, preventing bugs with duplicate satellites and satellites renamed in the source lists
catalog number and international designator are now displayed for each satellite
a simple windows to add satellites has been added (LP: #898476)
Added:
Ctrl+C binding to copy selected object info text to clipboard.
to the Windows installer options to remove files left over from the previous installation.
windows no longer can be dragged to unreachable positions.
the "Save settings" button now saves the current main window position, too.
the language list is now sorted by language name, not language code.
the "Reload style" action has been removed, as the underlying feature no longer works. If you decide to design a new visual style for Stellarium, please contact us to give you a version where it works.
distance in km (if the distance is below 0.1 AU) to the information displayed about Solar System objects. (LP: #894472)
the StelGui::getSkyGui() method to allow plug-in developers to create their own toolbars and other GUI elements.
an option to show the galactic coordinates grid and the galactic plane.
several trans-Neptunian objects (TNOs): Sedna, Quaoar, Orcus, Haumea.
the Quasars plug-in.
the Pulsars plug-in.
more detailed information is now added to the log file for Mac OS X.
(experimental) modelling of atmospheric extinction for point objects.
changed the position of the text in the Text User Interface plug-in. (LP: #911594)
a checkbox allowing the SIMBAD on-line search to be enabled/disabled.
Fixed:
startup script crash (LP: #689657)
plugin names localization in the Configuration window (LP: #807402)
resizing of the tabs in Configuration and View windows on language change (LP: #821386)
sky lines' labels not translated on language change (LP: #811659)
"Get catalog" button not translated on language change (LP: #890608)
last star catalog not being offered for download (LP: #538291, LP: #890789)
proxy configuration without username/password
Telescope Control plug-in: mishandling of IP connections in the telescope configuration window (LP: #843837)
Pluto's moon Hydra preventing the constellation from being selected in Search and scripts (LP: #894780)
scripting code still being included despite ENABLE_SCRIPTING set to 0 (LP: #811505)
constellations lines and names not displayed (LP: #945146)
newly created location cannot be set as default (LP: #889931)
End!
mflorian
Data inscrierii: 01 Sep 2011
Localitate: Tg Mures
MesajTrimis: 25 Apr 2012 13:22 Download mesaj
Un link util ši aici: http://www.astronomy.ro/forum/viewtopic.php?p=90250#90250
Nikon D7000
Teo
Data inscrierii: 23 Aug 2009
MesajTrimis: 25 Apr 2012 14:45 Download mesaj
Scuze de dublarea acestui mesaj, dar deoarece il consider util, am decis sa il postez si aici poate va fi mai usor vizibil :
In urma erorilor constatate de colegii nostri si de mine la ultima versiune de Stellarium ( 0.11.2 ), am decis sa postez o versiune stabila de Stellarium, si anume 0.10.5 care arata corect fazele planetei Venus.
O puteti descarca de aici :
http://www.4shared.com/file/-1YcaEOl/stellarium-0105.html
Dupa ce apasati butonul albastru "Download now" asteptati numaratoarea inversa de 20 de secunde apoi salvati fisierul.
Sper sa va fie de folos . Smile
MesajTrimis: 25 Apr 2012 15:16 Download mesaj
Aveti aici toate variantele, sursa oficiala:
http://sourceforge.net/projects/stellarium/files/
Teo
MesajTrimis: 25 Apr 2012 15:18 Download mesaj
Varianta oficiala am postat si eu. Wink
E o versiune pe care am folosit-o mult timp cu succes, si constatand ca e foarte stabila si buna, am incarcat-o si pt. voi pe acel site.
Sigur, nu conteaza de unde le descarcati, important este sa mearga si sa indice corect .
Creaza un subiect nou   Raspunde la subiect   Linkuri utile
