ursamajor Membru exclus
Trimis: 13 Mai 2012 21:34 Download mesaj |
theogon Membru de onoare
Trimis: 14 Mai 2012 20:33 Download mesaj |
Data inscrierii: 02 Apr 2010 Mesaje: 5317
Trimis: 15 Mai 2012 02:03 Download mesaj |
La oculare conteaza mult raportul focal al instrumentului (si nu numai).
F/5 e cam pretentios.
Sper sa nu ma injuri:
11. TELESCOPE EYEPIECE
11.1. Eyepiece functions http://www.telescope-optics.net/eyepiece1.htm
11.2. Eyepiece aberrations I : spherical, coma, astigmatism, field curvature http://www.telescope-optics.net/eyepiece_aberrations_1.htm
11.3. Eyepiece aberrations II Eyepiece distortion http://www.telescope-optics.net/eyepiece_aberration_2.htm
Citez niste aspecte despre astigmatism:
However, it is eyepiece astigmatism that dominates. It also depends on the lens focal length and the cone width, being inversely proportional to the eyepiece f.l. and in proportion to the square of the cone width. In effect, for given field angle it is, as coma, proportional to the eyepiece f.l. but, unlike coma, it changes in proportion to the square (not third power) of the telescope focal ratio (note that the geometric blur size changes in proportion to the focal ratio, but also with the square relative to the Airy disc). In other words, the wavefront error of astigmatism is four times larger at ƒ/5 than at ƒ/10. Unlike coma, eyepiece astigmatism increases with the square of apparent angle.
Also, unlike either spherical aberration or coma, lens astigmatism - with the stop at the surface - is independent of all three - refractive index, lens position factor and shape factor; it only depends on the lens focal length. The means of controlling it with a set of positive lenses and lens groups can be more limited, but the main reason why is it typically strong in conventional eyepieces is that it is the third at the list of priorities, after spherical aberration and coma. It is significantly more complicated to have all three corrected to a similar degree in a given lens configuration. |
Trimis: 16 Mai 2012 09:57 Download mesaj |
Trimis: 17 Mai 2012 12:13 Download mesaj |
Marius Laza Membru
Data inscrierii: 07 Dec 2008 Mesaje: 79
Localitate: Alesd
Trimis: 18 Mai 2012 00:01 Download mesaj |
Horatiu a spus:
| Citat: | | “ Ca si transmisie de lumina Hyperion are cea mai buna transmisie din toate ocularele de camp larg testate pana acum (inclusiv naglere, panoptic, ethos, uwan, axiom lx). Doar Pentax XW este mai bun la transmisie …” |
Cum ai facut aceste teste ?
Ocularele cu suprafete aer-sticla putine ( ortoscopice, plossl etc.) sunt considerate foarte bune in ceea ce priveste transmisia luminii. Daca luam in considerare evolutia materialelor si tehnologiilor, in domeniul acoperirilor antireflex, mai au aceste oculare un avantaj net (din punct de vedere al transmisiei de lumina), fata de cele cu un numar mai mare de suprafete aer-sticla ? _________________ Marius. |
horatius Membru
Trimis: 18 Mai 2012 09:48 Download mesaj |
"ocularele de camp larg testate " - sintagma cheie, deci nu ortoscopice, ci oculare cu sticle nenumarate
Sunt multe teste facute: reflexie de cer pentru antireflex, pe suprafata alba, pe stele slabe, pe Luna pentru cromatica, pe stele stralucitoare pentru reflexii parazite. Unul langa altul, diferentele sunt evidente.
Ortoscopicele bune au transmisie mai buna si in practica. Se poate calcula si teoretic. _________________ Horatius
STARMAX Astronomie
www.skywatcher.ro
www.starmax.ro |
Trimis: 19 Mai 2012 15:14 Download mesaj |
Trimis: 21 Mai 2012 16:02 Download mesaj |
Trimis: 21 Mai 2012 17:44 Download mesaj |
Sa le folosesti cu placere. Asteptam raportul primei lumini . |
Trimis: 21 Mai 2012 17:53 Download mesaj |
