Numar total de mesaje in forum: 242824
NGC 6992 H-alfa
Emil
Data inscrierii: 30 Aug 2007
Localitate: Fuerstenfeld
MesajTrimis: 25 Aug 2012 21:59 Download mesaj
Titlul subiectului: NGC 6992 H-alfa
Echipament:
Montura: EQ-6 SkyScan Pro prin EQMOD
Foto: TS ED-APO 90/500 mm cu QHY9M @ -15°C
Ghidaj: Celestron 102SLT 102/660mm cu Atik 16IC
Expuneri - filtru H-alfa 6 nm Astrodon:
42 x 900 sec.
Stackare DeepSkyStacker, postprocesare PS.
Mozaicul e lesinat rau, nu iasa cum vreau eu si pana la urma m-am lasat pagubas si am mers pe zona centrala dar pana la urma la stack am bagat toate cadrele.
 Marime fisier:  1012.65 kb
 Vizualizat:  de 2638 ori
alex1209
Data inscrierii: 03 Feb 2012
MesajTrimis: 25 Aug 2012 23:12 Download mesaj
frumooos!!! Smile sigur nu erau niste nori prin preajma? Mr. Green
MesajTrimis: 25 Aug 2012 23:35 Download mesaj
Hai Emil. nu te mai scuza, ca oricat incerci s-o dai in bara, tot cu detalii incredibile iesi Laughing
Ar trebui scoase gradientele si normalizat background-ul intre imagini.
Se mai poate merge si pe metoda fotometrica.
Also, if the images there taken under varying conditions (variable integration time, variable atmpospheric transmission, etc), it may be necessary to balance the backgounds and dynamic range of each images prior building the mosaic. The commands OFFSET, MULT, NOFFSET (offset normalization of the background to a given value), NGAIN (gain normalization ot the background) are the basics tools for balance operations. This require also measuring the levels of background and/or stars in the overlapping regions. Use the cursor information, or statistics function (contextual menu or STAT console command).
http://www.astrosurf.com/buil/iris/tutorial6/doc19_us.htm
http://www.astrosurf.com/buil/iris/tutorial2/doc11_us.htm
Catalin Paduraru
Data inscrierii: 08 Mai 2006
MesajTrimis: 26 Aug 2012 19:47 Download mesaj
Superba imaginea.
psemil
Data inscrierii: 16 Aug 2010
MesajTrimis: 27 Aug 2012 12:54 Download mesaj
Frumos...
sabin fota
Membru de onoare
Membru de onoare
Data inscrierii: 09 Iul 2008
Motto: Nihil Sine Deo
MesajTrimis: 27 Aug 2012 17:30 Download mesaj
ca de obicei, jos palaria
http://sabinfota.ro
Vlad
Data inscrierii: 10 Sep 2008
Localitate: Alicante
MesajTrimis: 27 Aug 2012 21:53 Download mesaj
Sehr schön, intr-adevar! Very Happy
Inevitabil imi amintesc ca am vazut nebuloasa asta acum o saptamana printr-n un tub de 50cm
Se vedea aproape la fel...
MesajTrimis: 29 Aug 2012 05:13 Download mesaj
Vlad a scris:
@vlad, presupun ca doar zona centrala sau si filamentele exterioare? cu/fara filtre?
Vlad
MesajTrimis: 29 Aug 2012 11:13 Download mesaj
Si filamentele, cu un filtru - nu-mi amintesc exact ce filtru, cred ca ceva gen UHC sau alt filtru asemanator de nebuloase.
cu un binoviewer, a fost o adevarata excursie prin tot valul, care nu se mai termina..
Cand te uiti printr-un asemenea monstru la un obiect cum este valul, incepi sa urmaresti unul din filamente si pana la urma te pierzi Smile
