Emil Membru
Localitate: Fuerstenfeld
Trimis: 07 Dec 2013 19:39 Download mesaj |
| Titlul subiectului: Anunt update MaximDL 6 |
Preiau o infomatie referitoare la upgrade-ul planuit pentru MaximDL 6. Am sa mentin topicul actualizat pe masura ce primesc informatii suplimentare
Emil
On 12/3/2013 11:32 AM, Douglas B. George wrote:
> This is a *preliminary* summary of V6 feature improvements:
> Quick Color
> - See Raw RGB Bayer-encoded images in color instead of monochrome
> - Uses nearest-neighbour decode for speed
> - Does not degrade dark subtraction, etc., since image is not actually modified
> - User must still perform Convert Color prior to image processing and for
> optimum quality
> Narrowband image blending tool
> - Stack arbitrary number of images planes
> - Choose wavelength match for each filter band
> - Can insert same filter multiple times for multiple wavelength blending
> Major upgrade to Photometry command
> - Group-based analysis similar to Stack tool
> - Multispectral analysis
> - Unlimited input files
> - Reject images based on quality
> - Astrometric or auto star match star identification
> Support for PinPoint V6
> - Astrometry.net integration for all-sky solving
> - UCAC4 support
> - Hot pixel detection and removal for more robust solving
> - Improved point-spread function fitter
> - Deprecated support for obsolete catalogs GSC (non-corrected) and USNO SA 2.0
> - Now "modeless", allowing the PinPoint dialog box to remain open when
> switching images, using other commands, etc.
> ASCOM Switch control
> - Control hardware switches such as power, lights, reboot equipment, etc.
> Observatory webcam integration
> - Live view of inside of observatory via webcam
> - Switch control panel (handy for operating lights etc.)
> Built-in Davis weather station support
> - Display current weather status
> - Add weather information to image FITS headers
> Built-in Boltwood Cloud Sensor support
> Automated equipment shutdown capability
> - Triggers include:
> - Sunrise
> - Civil, nautical, or astronomical twilight
> - Target low
> - Loss of autoguiding (clouds etc.)
> - Cloud sensor warning
> - Perform shutdown sequence:
> - Shutdown cameras
> - Park telescope
> - Park and close dome
> Multi-star autoguiding
> - Average measurements of multiple stars to reduce effect of seeing
> Support for SBIG Differential Guider accessory
> - Flexure-free autoguiding with separate guide scope
> Single or dual axis dither operation
> - Avoid triggering mount stiction cycles
> Automatic script execution on Expose command
> - Option to save image prior to modifications or after modifications
> - Handy for running "quick look" filters on faint images, etc.
> Automatic pointing refinement using PinPoint
> - Takes pointing exposure to verify telescope position
> - Resynchronizes automatically
> - Centers target precisely
> Automated pier flipping
> - Detect telescope approaching limit
> - Pause imaging sequence
> - Flip telescope over pier
> - Automatic pointing refinement
> - Relocate guide star
> - Continue image sequence
> Bookmark locations on the sky
> - Right Ascension and Declination
> - Rotator angle
> - Save current telescope position
> - Load current solved position
> - Goto bookmark
> - Load and save bookmarks
> User can hide unused Observatory Window tabs
> - Only see tabs for equipment that you are actually using
> Simulated Telescope Park
> - Slew telescope to park position
> - Turn off sidereal tracking
> ASCOM device threading
> - All telescope, dome, focuser, and rotator interfaces are now fully threaded
> - Keeps the user interface more responsive
> - Prevents user interface lockup if device driver locks up
> Enhanced camera interfaces
> - Camera downloads are now threaded
> - Eliminates user interface delays during download
> More image processing filter options
> - Save fit profiles in Flatten Background
> - Gaussian Blur option added Unsharp Mask and Digital Development
> Redesigned Calibration Wizard for quick and easy calibration frame setup
> Many other minor enhancements and "under-the-hood" improvements
> Doug
Procyon Membru
Data inscrierii: 25 Ian 2013 Mesaje: 285
Localitate: Galati
Trimis: 07 Dec 2013 22:33 Download mesaj |
Mistooo...
Cand e data de lansare ? _________________ Stoian Andrei-Marian |
Emil Membru
Trimis: 08 Dec 2013 18:30 Download mesaj |
Dupa cate am inteles sfarsitul lunii Dec. insa nu sunt sigur daca o sa reuseasca.
EDIT: alte surse specifica luna Februarie.
Ultima modificare efectuata de catre Emil la 08 Dec 2013 20:57, modificat de 1 data in total |
jimao22 Moderator
Trimis: 08 Dec 2013 19:45 Download mesaj |
Wow.
O multime de chestii tari si noi. Era timpul fiindca o multime de alte programele ultraspecializate (si free in plus) faceau treaba mai buna decat Maxim pe anumite segmente.
Sa vedem si cat costa. |
Procyon Membru
Localitate: Galati
Trimis: 08 Mar 2014 02:42 Download mesaj |
Informatii noi, ceva ? _________________ Stoian Andrei-Marian |
Emil Membru
Trimis: 11 Mar 2014 07:39 Download mesaj |
Nu,
pana acum nu, nu am dat nicaieri de ceva nou. |
Emil Membru
Trimis: 24 Apr 2014 20:02 Download mesaj |
It will be released when it's ready. It's in beta testing. Still working
through a few issues.
Doug
Doug George
dgeorge@cyanogen.com |
auriga Membru
Data inscrierii: 22 Dec 2008 Mesaje: 2184
Emil Membru
Trimis: 05 Iun 2014 12:49 Download mesaj |
OK multumesc frumos pentru update.
L-am bagat in download insa sunt cu "jucariile" stranse asa ca nu am cum sa il testez, decat eventual pe "uscat"
Numai bine
Emil |
