Emil Membru
Localitate: Fuerstenfeld
Trimis: 25 Aug 2012 21:59 Download mesaj |
| Titlul subiectului: NGC 6992 H-alfa |
Echipament:
Montura: EQ-6 SkyScan Pro prin EQMOD
Foto: TS ED-APO 90/500 mm cu QHY9M @ -15°C
Ghidaj: Celestron 102SLT 102/660mm cu Atik 16IC
Expuneri - filtru H-alfa 6 nm Astrodon:
42 x 900 sec.
Stackare DeepSkyStacker, postprocesare PS.
Mozaicul e lesinat rau, nu iasa cum vreau eu si pana la urma m-am lasat pagubas si am mers pe zona centrala dar pana la urma la stack am bagat toate cadrele.
1012.65 kb |
de 2639 ori |
alex1209 Membru
Data inscrierii: 03 Feb 2012 Mesaje: 617
Trimis: 25 Aug 2012 23:12 Download mesaj |
frumooos!!! sigur nu erau niste nori prin preajma?
Trimis: 25 Aug 2012 23:35 Download mesaj |
Hai Emil. nu te mai scuza, ca oricat incerci s-o dai in bara, tot cu detalii incredibile iesi
Ar trebui scoase gradientele si normalizat background-ul intre imagini.
Se mai poate merge si pe metoda fotometrica.
Also, if the images there taken under varying conditions (variable integration time, variable atmpospheric transmission, etc), it may be necessary to balance the backgounds and dynamic range of each images prior building the mosaic. The commands OFFSET, MULT, NOFFSET (offset normalization of the background to a given value), NGAIN (gain normalization ot the background) are the basics tools for balance operations. This require also measuring the levels of background and/or stars in the overlapping regions. Use the cursor information, or statistics function (contextual menu or STAT console command).
http://www.astrosurf.com/buil/iris/tutorial6/doc19_us.htm
http://www.astrosurf.com/buil/iris/tutorial2/doc11_us.htm
Catalin Paduraru Membru
Trimis: 26 Aug 2012 19:47 Download mesaj |
| Superba imaginea.
psemil Membru
Trimis: 27 Aug 2012 12:54 Download mesaj |
| Frumos...
sabin fota Membru de onoare
Trimis: 27 Aug 2012 17:30 Download mesaj |
ca de obicei, jos palaria
Vlad Membru
Data inscrierii: 10 Sep 2008 Mesaje: 691
Localitate: Alicante
Trimis: 27 Aug 2012 21:53 Download mesaj |
Sehr schön, intr-adevar!
Inevitabil imi amintesc ca am vazut nebuloasa asta acum o saptamana printr-n un tub de 50cm
Se vedea aproape la fel...
auriga Membru
Data inscrierii: 22 Dec 2008 Mesaje: 2174
Trimis: 29 Aug 2012 05:13 Download mesaj |
| Vlad a scris: | Sehr schön, intr-adevar!
Se vedea aproape la fel... |
@vlad, presupun ca doar zona centrala sau si filamentele exterioare? cu/fara filtre?
Vlad Membru
Trimis: 29 Aug 2012 11:13 Download mesaj |
Si filamentele, cu un filtru - nu-mi amintesc exact ce filtru, cred ca ceva gen UHC sau alt filtru asemanator de nebuloase.
cu un binoviewer, a fost o adevarata excursie prin tot valul, care nu se mai termina..
Cand te uiti printr-un asemenea monstru la un obiect cum este valul, incepi sa urmaresti unul din filamente si pana la urma te pierzi
