Numar total de mesaje in forum: 242346
oculare
Oculare/Filtre
kiss marco paul
Data inscrierii: 12 Aug 2012
Motto: Did i ever tell you......the definition of insanity!!!
MesajTrimis: 08 Dec 2012 01:40 Download mesaj
Titlul subiectului: oculare
buna am nevoie de ajutor va rog, cine poate sami spuna ce tip de oculare as putea sami iau pentru modeulul meu de telescop celestron powerseeker 50 az? astept raspuns.. Very Happy
Сталинград
MesajTrimis: 08 Dec 2012 02:05 Download mesaj
Nu ai deloc oculare?
Incepator
Data inscrierii: 28 Iun 2012
MesajTrimis: 08 Dec 2012 21:14 Download mesaj
gasesti manualul la http://www.celestron.com/c3/images/files/d..._21039.pdf
care spune :
Eyepieces – An assortment of 1¼” eyepieces are available to give you a wide range of
magnifications.
• OMNI Plössl - Plössl eyepieces have a 4-element lens designed for low-to-high power observing.
The Plössls offer razor sharp views across the entire field, even at the edges! In the 1-1/4" barrel
diameter, they are available in the following focal lengths: 4mm, 6mm, 9mm, 12.5mm, 15mm,
20mm, 25mm, 32mm and 40mm.
• Ultima – Ultima is not really a design, but a trade name for our 5-element, wide field
eyepieces. In the 1-1/4” barrel diameter, they are available in the following focal lengths:
5mm, 7.5mm, 10mm, 12.5mm, 18mm, 24mm, 30mm, 35mm, and 42mm. These eyepieces
are all parfocal. The 35mm Ultima gives the widest possible field of view with a 1-1/4”
diagonal.
sternchen
Data inscrierii: 02 Iun 2012
Localitate: austria
MesajTrimis: 09 Dec 2012 11:42 Download mesaj
la un telescop cu diametru de 50mm s-ar putea sa ai nevoie de oculare pe 1",nu pe 1,25".
nu sunt sigur dar la unele lunete am observat asta.
MrMxyzptlk
Data inscrierii: 02 Mai 2012
Localitate: Sfantu Gheorghe
MesajTrimis: 09 Dec 2012 12:01 Download mesaj
strenchen de data asta are dreptate, desi vorbim de diametrul de 0.96" nu 1" (nu este idiferent, daca va cauta oculare de 1" nu va gasi).
Daca ma uit la manualul postat de Incepator si ai acest telescop se pare ca chiar vine cu oculare de 0.96" din dotare. Insa tot in acel document spune:
"Diagonal, Hybrid Mirror 90° (.96 to 1¼") #94106 - The economy Hybrid Mirror Diagonal (90°) provides a cost
effective way to upgrade telescopes supplied with .96" eyepieces, to higher quality 1¼" eyepieces."
Probabil ca ar fi indicat sa cumperi diagonala indicata si sa folosesti oculare de 1.25" ...
sternchen
Localitate: austria
MesajTrimis: 09 Dec 2012 12:04 Download mesaj
MrMxyzptlk a scris:
no.in sfarsit.. Wink
MesajTrimis: 09 Dec 2012 12:32 Download mesaj
[offtopic]
O carte de gramatică nu strică niciodată, Paul!
[/offtopic]
